Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
I have Rheem furnace imperial it will not fire up
My furnace will not come on
  • krajewskiw Jun 24, 2009
    I have a rheem furnace that will not come on ,the blower will not come on .went I put the thermalstat on .not a thing happys
Without much detail, I can tell you that one of the most common reasons for a furnace not to come on is a failed thermal couple. If this is the case, you can start the pilot light when holding the switch down, but it will always go out when you turn the pilot switch to the on position. It is a relatively cheap part, it is the copper wire with a steel point that sticks out above the pilot light. Replacing it should cost less than $20.
Posted on Jun 24, 2009
Rheem Imperial 90 plus furnace filter size model# RGEA 10EC-FS
Measure the housing that the filter goes in, reason being it is not the same in every installation.
Oct 21, 2016 | Filter Heating & Cooling
My Rheem oil furnace is coupled with Rhuud heat pump. Oil furnace runs on emergency mode only and heat pump doesn't work at all!! Now the oil furnace will not even fire up even on emode.
Try and jump it out by taking the wire hooked to R and W terminals on your thermostat and connecting them. It could be you have a bad thermostat.
Feb 11, 2010 | Ruud UBHC Air Conditioner
My Rheem furnace fires up but the fire keeps cutting
Hi check out the pressure switch ,jump it out see if it fires clean flame senser if fitted, clean airfilter check fan afc is clean might be dusty
Feb 02, 2010 | Heating & Cooling
How can I get a manual for my Rheem Gas Furnace
Contact Paloma/Rheem customer (800-432-8373) support and tell them what you have; they'll send you the documentation - by regular/email.
Happy Holidays;]
JZ...
Nov 25, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Working on a Rheem 90+ gas fired furnace with A/C. Replaed the 24vac fuse twice now. Unit runs 1-3 days then blows the fuse. Thoughts?
Could be a couple of things check the low voltage wiring going from the furnace to the outside unit. It will look like a small telephone wire. Sometimes rodents like to chew this wire and it can cause a short which will blow the small fuse.
Jul 20, 2009 | Heating & Cooling
Rheem LX2000 intermittent start problem
check all wires are tight and good on both ends if you are not a sparky then turn it off first at the power box
Mar 01, 2009 | Heating & Cooling
Trouble shooting manual for Model# RGUJ-05EA-ER RHEEM GAS FURNACE
replace the gas valve....test for 24volt at the gas valve input.  if you have this then it's a def gas valve relay not working.
Dec 09, 2008 | Heating & Cooling
Heating & Cooling Logo
674 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
