Question about Microsoft Xbox 360 Console
Sound But no picture
I was away from home wen all of the sudden my dad calls me and says that the xbox will not work right, i have tried the blanket trick twice but i do not want to hurt it. what do i do
    Problem Solver:
  • 17 Answers
Its either a defective video cord or a bad connection in unit where video data connects to binding post which the video cord plugs into back of machine.
Posted on Jun 24, 2009
When you hear it start up push y and pull the right triger this will restart the machine on default setting and hopefully you will see a picture
Posted on Jun 29, 2009
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
Tip
This is a very frustrating problem and there are quite a few possible causes for...
This is a very frustrating problem and there are quite a few possible causes for this failure to happen with the Xbox. You can spend hours on the internet looking for an answer to this issue.
However, thankfully there is one very simple solution that is often overlooked when this problem occurs and I am writing this tip so that anyone who has this issue can check this out as first step in resolving the problem before moving on to anything else.
On the actual cable that connects to the XBox there is a little HD switch right on the side of the connector. If this little switch is in the HD position and your TV is non HD you will end up with sound and no picture!!!
Therefore please check this cable (see picture below for exact location of the switch) to ensure that it is in the position that is correct for your TV set.
If this does not resolve your problem please work through the following steps.
1) You should reset the resolution of the console to 640 x 480. See this link for a simple explanation on how to do this
http://support.microsoft.com/kb/911059/
2) If after this you still do not have a picture - disconnect the cable that is shown in the picture above and then also remove the power cord for a total of five seconds.
3) Reconnect the cables - turn on the console and see if you have a picture.
These are the main steps you can take to troubleshoot the sound but no picture problem. If these fail then there is a component failure and your console will need to be returned for a service repair.
Please note: There are reports of people using a method known as the 'blanket method' whereby the console is wrapped in a blanket and then it is forced to overheat in an effort to melt any solder in the circuit that may be causing a dry joint.
I strongly recommend against using this so called 'blanket method'.
This is due to the risks of fire hazard and the strong likelihood that you will end up causing even more damage to your console for something that is at best a temporary fix.
If your console continues to have display problems after working through this troubleshoot have the unit checked by an authorised technician.
on Dec 06, 2009 | Baby Care
Tip
XBox 360 Sound but No Picture
1) Reset the display resolution to its default settings. To do this;
  • Remove any discs from the disc tray.
  • Turn off the console.
  • Turn on the console.
    (If you are using an Xbox 360 Wireless Controller, turn on the console by using the Xbox Guide button on the controller. Make sure that you use the player 1 controller when you do this.)
  • As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
  • The Xbox will reset to default display settings and automatically restart the console.
2) If you still do not have a picture - disconnect the cable that is shown in the picture above and then also remove the power cord for a total of five seconds.
3) Reconnect the cables - make sure they are securely seated - turn on the console and see if you have a picture.
4) This problem is sometimes associated with faulty cables or damage to the connectors for the cables that are on the console itself. If there is no evident damage to the connector on the console - replace the cables.
These are the main steps you can take to troubleshoot the sound but no picture problem. If these fail then there is an internal component failure and your console will need to be returned for a service repair.
Please note: There are reports of people using a method known as the 'blanket' or 'towel method' whereby the console is wrapped in a cover and then it is forced to overheat in an effort to melt any solder in the circuit that may be causing a dry joint.
This is due to the risks of fire hazard and the strong likelihood that you will end up causing even more damage to the components inside your console for something that is at best a temporary fix.
on Dec 06, 2009 | Video Game Consoles & Games
Problem with my LG TV and my XBOX360 , there no picture and sound when i connect my xbox with hd cable.
Try different AV ports on the TV, if it doesn't work press the right trigger + Y, right after the console starts (this will reset the resolution of the console output) I'm assuming you are using the same cable that worked with another TV, so neither the cable is broken, neither the Xbox. It can only be an output format problem, bad configured or a faulty TV.
Jun 09, 2012 | Microsoft Xbox 360 Elite Console
My xbox 360 fan turns on for 3 seconds then shuts off right away
for the red rings fix rap your xbox in two blankets turn on xbox wait till it shuts it self off wait for 35 min and you wount have any more problems i did that to mine over 2 years ago and i have not had any problems yet brian
Nov 10, 2010 | Microsoft Xbox 360 Console
Sound but no picture
This might just be a bad HD/AV cable. I would recommend that you borrow and friends and try the cable first...well actually the first step would be to make sure they are in correctly & tightened up;)
Jul 07, 2009 | Microsoft Xbox 360 Console
No picture but sound
you can try getting new lead cables, or send your xbox on if you have the receipt for it.
Jun 28, 2009 | Microsoft Xbox 360 Console
When i turn on my xbox it loads then it starts blinking three red lights and i get no picture no sound nothing it started wen i was playing smackdown vs raw 07 and it froze then this happened ever since
Its called the Red Ring of Death, its when the video card gets de-sodered from the motherboard when the system gets too hot,you need to send it into Microsoft for repair.
Mar 07, 2009 | Microsoft Xbox 360 Console
Xbox 360 sound but no picture
ARE YOU PLAYING YOUR 360 ON A REGULAR TV?
Nov 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
65 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
