My 1999Ford Ranger with a 2.5 ltr. broke a timing belt while driving up the road. set the timing marks where they supposed to be and put new timing belt on. finished putting everything back together and tried to start it up. it sounds like it is out of time. it just popping but not starting. What do I do?
It sounds like you have some bent valves and you need to pull them out and check them. good luck
You need to pull the timing back apart pull the number one spark plug and role the motor over by hand to top dead center on the compression stroke the the mark for the crank should be lined up or almost lined up line it up perfect on its mark then set the cam to its mark install belt role over by hand 2to4 full rotation marks should line up perfect . install crank pulley fire it up for a split second shut it off and put it all back together
you will need to pull the distributor cap off and pull the #1 plug out and timing covers need to come off leave the harmonic balance on or take it off an put it on temporally so you can line up timing marks. with the #1 cylinder at top dead center and the rotor pointing to #1 plug put air into the cylinder to see if it holds compression if it does your in the right postion. Next trun the crank until the cylinder is at the top of the stroke power stroke, next make sure the harmonic balancer marks are lined up next look at the two timing gears I believe they are supposed to point towards each other if not move the one you think is wrong one tooth in the direction oppisite of the way it slipped if it is not lined up you will not have compression pull valve covers off so you can see the valves both the valves should be fully closed on the # 1 plug if it is your timing should be right if one is slightly open then tuen it till the #1 valve is closed and the gear marks line up then slide the belt back on once you are sure you have it set correctly put it all back together to set the timing with the light look at the hood and under the hood it will tell you how to set the timing and how many degrees they very from engine to engine where it was manufactured for and you need to follow the emmison sticker timing proceedure, if you need more information let me know.
SOURCE: hello , i have a problem with my 1996 ford ranger
code 1131 refers to the upstream O2 sensor before the cat converter.(NO heated sensor detected)
code 1116 means the water temp signals are out of range.(Maybe its unplugged?)
The codes for the O2 can also mean a Lean condition which may be caused by a vacuum leak.
Regardless of the electronics you should be able to do a compression test and figure out if the valve timing is off.
Remember to wipe the memory after you change things to see if they helped.
SOURCE: Timing marks on 1999 Ford Ranger 2.5L.
Rotate the engine so that No. 1 cylinder is at TDC on the
compression stroke. Check that the timing marks are aligned on the
camshaft and crankshaft pulleys. An access plug is provided in the cam
belt cover so that the camshaft timing can be checked without removal
of the cover or any other parts. Set the crankshaft to TDC by aligning
the timing mark on the crank pulley with the TDC mark on the belt
cover. Look through the access hole in the belt cover to make sure that
the timing mark on the cam drive sprocket is lined up with the pointer
on the inner belt cover.
To install:
The spring cannot be used to set belt tension; a wrench must be used on the tensioner assembly.
SOURCE: timing belt broke on a 95 ford ranger.new belt
you have to line up the two marks on the gears and set the tension to the correct setting. then check the marks again. trial and error. i just did my timing belt on my ranger haha
SOURCE: have a 2000 ford ranger, 2.5 engine, timing belt
Damn. Bad news friend. That truck has what is known as an "interference engine" Which meant that if the timing belt brakes while the engine is running the pistons will hit the open valves and destroy them and possibly damaging the pistons as well.
So now you either need to do 1 of 3 things, 1 have the head removed and rebuilt, 2 have the head removed and replaced with a new/used one, or 3 replace the engine entirely.
If you replaced the belt yourself then you are probably capable of replacing the head yourself. Just get one from a junk yard, swap it for the old one and your good to go. While you have the head off take a look at the pistons to make sure they are ok.
Personally I would just swap the engine for one from the boneyard. They are relatively cheap. I'm sure this is the last thing you wanted to hear but unfortunately until you do one of the 3 things i mentioned she will never run again. Good luck, If you have any more questions shoot me an email [email protected]
