Question about Lexmark Wheelwriter 5 Series II Typewriter
IBM personal Wheelwriter 2 margins not clearing
Our office has an IBM personal Wheelwriter 2. The tabs or margins will not clear. You can not backspace or type but in a small region to the right.
  • Lexmark Master
  • 3,594 Answers
Return to the L. margin, touch the mar rel key top key on L. of the keyboard, backspace to location where you want the L. margin, touch the L. mar key. Put some WD40 on the silver shaft that the carrier slides on.
DickyO
Posted on Jun 25, 2009
How do i erase tabs on an IBM 6781 personal wheelwriter?
Try a little shot of WD40 on each side of the silver shaft that the carrier slides on,. If that doesn't work you have to lube the carrier motor bearings the front one is accessable from the inside the rear one you may be able the straw thru the release lever hole.
DickyO
Nov 05, 2014 | IBM Model 6781 Personal Wheelwriter...
HOW DO I CLEAR ALL TABS ON IBM WHEELWRITER 3500 BY LEXMARK TYPEWRITER
Tab all the way to the right, hold down the tab clear key, press return.
DickyO
Sep 19, 2014 | IBM Wheelwriter 3500 By Lexmark Electric...
MAKING A NOISE WHEN TURNED ON
Hold down MARGINS key while hitting CLEAR TABS. Then reset right margin. Bye the way, no parts available for machine because IBM didn't sell patent and nothing compatible being produced today. Jimmy
Aug 16, 2011 | IBM Wheelwriter 30 Typewriter
I have a tab set that I can't figure out how to clear.
The "tab" is probably the R. margin. Go to it press mar rel key space or backspace to the desired location, press R. mar key.
DickyO
May 20, 2010 | IBM Wheelwriter 30 Typewriter
Wheelwriter 30 Typewriter: I have a tab set that I can't figure out how to cl...
The "tab" is probably the R. margin. Go to that point, press margin rel, space to the place you desire, press R mar key.
DickyO
May 18, 2010 | IBM Wheelwriter 30 Typewriter
How do I set Decimal Tabs?
From the User's Manual:
Margins and For each setting, move point. key(s) indicated:
• LMar to set left margino
• RMar to set the right margino
• MarRei to the!" left of the margino
• TSet to set a tab. Vou set at the left and right margins. Vou • TClr to clear a tab.
• TClr + CRln elear ali The earrier does not margino when the carrier is tive margino Vou type or space through ríght margino saved when the oft.
Tabs
the carrier to the desired point, and press the
the margin.
margin.
MarRel release the left margin, ther Backspace or +- to move
margi n.
You can up to 26 tabs. Permanent tabs exist
You cannot clear these tabs.
CRtn to clear all tabs.
carrier lock at the right margin. The typewriter beeps
about five spaces before the right margin. You can
the right margin. Margin and tab settings are
typewriter is turned.
You can download the User's Manual from LEXMARK:
http://images.lexmark.com/publications/pdfs/2007/index/en.html
Look for the title 'IBM Typewriters' at the end of the page, open the list box and select your typewritter model.
Aug 07, 2009 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 15 beeps on the sixth keystroke
It sounds like the R. margin is set at that place. Space to the r. as far asd you can and press the R. margin key on the left side of the keyboard.
DickyO
Jul 30, 2009 | IBM Office Equipment & Supplies
How do I clear the tabs on this IBS wheelwriter 1500?
Space the carrier all the way to the right, press and hold the tab clr key. press return this will clear all tabs rt. of the L. margin
Feb 06, 2009 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter 30 won't let us clear the left margin
If the carrier (print head) goes to the left when you turn the T/W on then try this.
Return to the L. margin, press mar rel key, backspace to the location that you want the margin, press L. mar key the wheel should spin and reset the margin.
DickyO
Oct 16, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 1000 - How to clear all tabs
Using the space bar move the carrier (print head) all the way to the right, press and hold tab clear key and hit the return key.
Dec 14, 2007 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 5 Series II Typewriter Logo
629 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
