Question about Ovens
Desa International Self Venting Fireplace manuals
Desa Inernational self venting fire place model CGFB32CA
S/N 014233309.
I need operating instructions and parts list for the burner assembley that goes into this unit. The manual that is on the desa site is only for the shell assembley. This is in a home I own and had rented out 3 years ago. the remote and instruction manual have dissapeard. the fireplace is not working and i need to trouble shoot but have no manuals.
    Top Expert:
  • Ovens Master
  • 40,520 Answers
Try Googling (desa)(CGFB32CA)(manual) without parens.
Posted on Jul 01, 2017
  • 236 Answers
SOURCE: Oven Door Locked
is it locked in the up or down position?
Posted on Jun 04, 2007
  • 57 Answers
SOURCE: Cleaning my self-clean oven
Turn the oven to "clean" and lock the door if the oven has a manual door lock. The oven may have an automatic timer for the clean setting. If it doesn't then you'll have to turn it off yourself in three or four hours. Don't be surprised if the oven puts out a very foul smell while it's cleaning itself as that's normal for an oven that hasn't been cleaned in so long. After it's done, wait for the oven to cool and then wipe out the ash from the inside of the oven.
Posted on Mar 02, 2008
how do I get my self cleaning to come on in my hotpoint stove
Posted on Oct 13, 2008
SOURCE: Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
Posted on Nov 24, 2008
  • 1236 Answers
SOURCE: My fireplace pilot light can be lit but when I
First, and least expensive thing to do is replace the thermocouple. Probably weak.
Hope this helps.
Posted on Nov 21, 2009
How do I operate my self-cleaning manual..
Thank you for your post, Pattie Cromie!
I see that you would like to operate self-clean on your Frigidaire range and you do not have the manual. Typically, to start self-clean you would need to push the button labeled "Self-clean" and make sure there is nothing inside the oven before starting a self-clean cycle. Also before starting self-clean close the door because of the temperatures that are created within the oven the door needs to be closed and locked. I hope this has been beneficial. -Matt
Oct 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
GE Spectra XL44 Oven Overheating
It is a thermistore problem, if you replace the faulty thermic switch inside oven, it should work fine a gain
May 25, 2008 | Ovens
F10 code on a Kenmore self-clean range model #970-6061
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel. Instructions 1 Inspect the area around and behind the oven to ensure you did not place the oven next to a source of heat, such as a register vent or other appliance that becomes very hot. If this is the case, you must remove the oven from the heat source to prevent the issue from occurring again. 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears. 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
Aug 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I need to clean my Tappan oven (it's a range) for the first time, but I can't find the manual for it. I don't want to do anything wrong, cause harm to my oven, or do something harmful that could cause a...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 09, 2011 | Tappan Ovens
How do you operate oven
You should have a bake and broil button and arrows to adjust temp up and down. Of course a start button should be there. If no off button, then there should be a cancel button to turn it off. The door only locks in self clean mode.
May 21, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Can't find manual for Ge profile range and oven. How do I operate the self clean, do the racks come out? do I have to set a time or do I just push self clean?
No I haven't solved the problem, but I don't need to spend money to find out how, I plan to call a sales man at the place I bought it. I bet they don't charge!!
Nov 02, 2009 | GE Profile JTP18 Electric Single Oven
Do I need to vent to the outside?
Hello, No you don't need to vent outdoors, and YES all you need is a electrical supply. **I will add however, allow for an air cushion around the unit when it's installed in the wall as well as a vent or small gap with maybe a custom grill at the top. One of the most common service calls I get for self clean built in ovens is reseting or replacing safety thermostat's. Hope that helps Good Luck :)
Nov 01, 2009 | Ovens
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
VDSC307-4bss how to operate self-cleaning oven
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Mar 28, 2008 | Viking VCSO244 Dual Oven
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
603 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
