Question about Mowtownusa Snow Thrower Starter Switch for Toro S-200 and S-620 units # 29-5560 40-594
Snow Thrower stops running after 20 min.
Snow Thrower will not start until i have waited 20 min.
    Champion:
  • 225 Answers
Sounds like the coil is going bad.
Posted on Jul 02, 2009
1500 electric snow thrower just stopped working
motor humming -- replace the start/run capacitor
no noise at all --- press the thermal overload button or replace the thermal overload switch
Mar 16, 2018 | Electric Garden
My two stage snow thrower MTD Briggs & Stratton motor, Start well but after 20 minutes it stops by itself when hot and unable to restart it until it cool off. Could it be the pick up coil defective?
no
more likely valve clearance adjustment
B&S engines stretch the valve stems and when hot the valves to not seat properly and are hard to start until the valve stems cool and the clearance allows the valves to seat properly
coil problems will fail earlier
Jan 11, 2018 | Mtd Garden
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Snow thrower that wont stay running
clean the carb
check you have gas in it
Feb 01, 2014 | Garden
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
1990 vette runs fine after 15-20 min won't start then wait 20 -min runs fine again until i shut it off
I had the same problem. Turns out,( and I didn't believe it when I was told) but, my problem turned out to be cheap (inferiour) plugs and wired. I was reccomended to use NKG plugs and Borg-Warner wires.
May 31, 2009 | 1990 Chevrolet Corvette
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Mowtownusa Snow Thrower Starter Switch for Toro S-200 and S-620 units # 29-5560 40-594 Logo
262 people viewed this question
Top Mowtownusa Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Mowtownusa Electrical Supply Expert? Answer questions, earn points and help others
