Konica Minolta DiMAGE A1 Digital Camera
Problem for Konica Minolta DiMAGE A1 Digital Camera
My Minolta DiMage A1 displays
By gartri on Jun 24, 2009
My Minolta DiMage A1 displays "no card" when memory card is inserted. It's not a new card...it's the same 128mb card I've used since I bought it. Any suggestions?!
Comments:
Jun 27, 2009
- Thanks Obertelli for the help...I know it's not a bent or broken pin...that was the first thing I checked. Now to find a small enough memory card. And if that doesn't fix the problem...I am thinking that this is a good excuse to upgrade my camera! :)
Best Solution
posted on Jun 27, 2009
Helpful)
Obertelli
Rank: Guru  Cameras & Camcorders  Expert
Rating: 94%, 366 votes
If you're lucky, the CF card is faulty. It's going to be a very old card now if it's the original one supplied/bought with your A1. You've never upgraded to a larger card in all this time so it suggests you've never needed to. 128 and 256mb cards are virtually worthless now, so I'd be amazed if you couldn't get one for free via Yahoo FreeCycle. You can also try reformatting your card in a card reader/writer, but A1's and A2's often won't recognise a card formatted in this way and it can render them permanently unreadable by all A1/A2/A200 cameras.
If you're unlucky, then you've bent or broken one or more of the pins inside the card slot which connect to your card when you insert it. To check, get a bright torch and look down inside the card slot. Any bent pins will be self evident as there should be a neat double row of pins and missing pins will show up as gaps.
If you have bent pins then you've nothing to lose by trying to carefully straighten them, if you can't or if the pins are broken, then your camera is effectively irrepairable. Scrap A1's and A2's can both provide the part, but retreiving them from the donor camera is really difficult and so far I've never managed to refit one successfully and I've done a few now. A pro repair is simply not cost effective, especially when a perfectly good used A1 goes for around £40-£50 and the better A2's go for around £80-£100. If you're in North America you can expect prices to be even lower.
Comments:
Jun 27, 2009
- BTW: Forgot to mention that if you do buy a new card don't go above 2GB as your camera won't support it. A2/A200's can go higher after a firmware upgrade.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Konica Minolta DiMAGE A1
Questions and Unsolved Problems for Konica Minolta DiMAGE A1
Do you recommend Konica Minolta DiMAGE A1 Digital Camera?
Answer
Answer
dimage a1 switches on, can view photos on play back but wont show image in view finder or rear... (More)
Answer
when I take pictures with my camera they show up on the computer and the LCD as a pink picture.. I... (More)
Answer
minolta dimage a1 switches on read out works but wont show image in view finder or rear screen or... (More)
Answer
flash is not working in this camera... how to possibly fix this problem... thank you
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in Newport, KY
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
