Question about Datel Action Replay MAX for GameBoy Advance, DS Nintendo
Our Nintendo gamecube does not work on all the discs. It says to look in the instruction manual for assistance.
  • mhder May 11, 2010
    Does the machine turn on? Does the disc spin etc?
  • 26 Answers
The discs may be dirty. run them lightly under cold water (do not worry, this will not damage them.) then rub them down with a paper towel going along the grooves. if that does not work, your disc may be scratched and it needs to be replaced.
Posted on Aug 18, 2009
    Problem Solver:
  • 5 Answers
What u could do is clean all the discs with alcohol or take them to a game crazy to have them cleaned 4 u
Posted on Jul 12, 2009
  • 21 Answers
You may have bought an American copy of the game so then it won't work on a British gamecube search on sites like ebay for a freeloader insert into gamecube first then whencit says swap discs do so and the game should hopefully load
Posted on Jun 26, 2009
I just bought a pokemon colosseum game for nintendo gamecube and it says the disk cannot be read please cheak the nintendo gamecube instruction manual but i dont have 1 how do i fix it
If all your other games work, the disc couold be scratched or dirty. First, try to clean the disc with a dry microfiber cloth, wiping away from the center. Next, you can try a CD repair or cleaning kit. If all else fails, try to return the disc as a defective product.
May 19, 2011 | Nintendo GameCube Console
I have a gamecube.on the game smashbrothers,it will play for a few moments and then it says:can't read disc,refer to gamecube manual but i don't have one.please tell me what to do.
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
  1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
  2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
  3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  4. Check for specific game issues. Some games may have known issues or game play elements that appear as problems.
  5. Ensure the game is being loaded properly. With the power turned off on the system, replace the Game Disc (label side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
  6. Look for obvious physical damage to the disc. Remove the Game Disc and check the non-labeled side for cracks, scratches, smudges, or dirt. The Nintendo GameCube has extensive error correction capabilities and minor scratches or contamination should not cause issues in most cases. However, it is important to determine if disc damage is causing the problem.
    • If the disc is cracked
      Review our disc replacement policy to determine how to get your game replaced.
    • If it's dirty, scratched, or shows no obvious damage
      1. You may try cleaning the disc again with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
      2. Make sure the game is dry, then re-insert it and see if the error occurs again.
      3. If the game had been working normally, shows signs of physical damage, and now displays errors or lockups in areas it previously didn't, the problem is likely to be the damage to the disc. Use the disc replacement policy to determine how to get your game replaced.
      4. If the game never worked or you are discovering errors in areas you have entered for the first time, it is possible that the problem could be with the system or the disc. (The system may still be the problem even if the disc shows some signs of damage.)
  7. If possible, try the disc in another Nintendo GameCube. If the disc works properly in another system, the problem is with your Nintendo GameCube. Please check out our system repair options. If the game still does not work in another system, it is likely a problem with the Game Disc. Please review our disc replacement policy to determine how to get your game replaced.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 begin_of_the_skype_highlighting 1-800-255-3700 end_of_the_skype_highlighting for assistance.
Jan 19, 2011 | Nintendo GameCube Console
When i turn on my gamecube it says an error has occurred and to shut it off and check the instruction booklet for further instructions
  • An Error has occurred:
    If you are getting the specific message, "An error has occurred. Turn the Power Off and check the Nintendo GameCube Instruction Booklet for further instructions." This means there may be an internal problem with the system.
    1. Check Individual Game Disc problems or Multiple Game Disc problems (depending upon how many games exhibit the problem) to see if the cause of the message is a dirty or damaged disc.
    2. If the disc appears fine or works properly in another system, this means there is an internal problem with the system. A repair will need to be set up. Please use our convenient repair options.
  • Nov 01, 2010 | Nintendo GameCube Console
    My gamecube freezes in the middle of a game and says an error has occured, it tells me to check the gamecube manual but i don't have one! PLEASE HELP!
  • Aug 03, 2010 | Nintendo GameCube Console
    The screen says the disc could not be read. See nintendo gamecube instructions for into. Don't have the instrucstions. trying to load Mario Kart double dash
    this error message usually means that you cannot use this disc because it is either too scratched up on the bottom or it is corrupted by something. try wiping the bottom of the disc off with a soft non-abarasive cloth/substance and try re-inserting the disc. if that does not work you will need to try and find another copy of the game. whatever you do do not touch the lens inside the gamecube console because that will prevent it from reading any games
    Jun 23, 2010 | Nintendo Mario Kart: Double Dash for...
    Game cube says error when turned on any ideas how to fix
      Please contact Nintendo's Consumer Service Department at 1-800-255-3700 for assistance.
  • Dec 05, 2009 | Nintendo GameCube Console
    My gamecube wont work
    Jun 01, 2009 | Nintendo GameCube Console
    Games initial load before Play Starts receive error 'cannot read disk see instruction manual'
    If this happens for only some games, you should try cleaning the discs with a disc cleaner. Otherwise, you could try asking around at stores like circuit city, radioshack, best buy, etc. for what you could use to clean the lens, the part that reads the disc in your gamecube. If that doesn't work, chances are that the lens is damaged and your only hope is to send it in for repairs or get a new gamecube (or Wii).
    Oct 13, 2007 | Nintendo GameCube Console
    Datel Action Replay MAX for GameBoy Advance, DS Nintendo Logo
    96 people viewed this question
    Top Datel Video Game Consoles & Games Experts
    Michael Galve
    Michael Galve
    Martin Murray
    Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
