Question about GE MiniCam Pro HO98756 Webcam
I can setup the cam, make video call even, but can't share webcam
I have the exact same camera as the original problem. I installed msn and it shows i have a cam. I've gone to the audio/video setup and it shows the cam working fine. I can even make video calls with it. But it won't let me share it on messenger.
    Scholar:
  • 33 Answers
Please rate me afterwards Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
Posted on Aug 06, 2009
  • libby_98 Aug 06, 2009
    President:
  • 8,637 Answers
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Posted on Sep 29, 2009
  • Weldon Dube'
    Weldon Dube' Nov 23, 2009
    See section C. Windows Live Messenger in the info below to setup the Audio & Video.
    Also send this to your family and friends so they have their computer setup properly.
    A. Skype Setup:
    After downloading and installing Skype http://www.skype.com/intl/en-gb/download... )
    B. Yahoo Setup:
    After downloading and installing Yahoo Messenger http://www.soft32.com/download_30.HTML )
    setup assistant" and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and
    http://www.microsoft.com/downloads/detai...
    Microphone
    Speaker
    Camera
    Notes:
I can install my web camera but can't play on windows live
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
May 19, 2010 | Genius VideoCAM Eye Web Camera
I have a new webcam - mikomi DC - 7130 & its installed on my laptop but will not show up on my msn, can anyone PLEASE help?
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Feb 18, 2010 | Intel Easy PC Camera Webcam
ı hawe a problem whit the cam
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Click 'Finish'
Jan 08, 2010 | Microsoft LifeCam VX-3000 Web Camera
I don't really know how to use it. It was a gift from my daughter after my hard drive crashed.
Well, it's very easy for you to use a web camera. First you have to decide how do you want to use it.. means you can use it for video chatting through Paltalk, Yahoo messenger, MSN messenger, Skype etc. For video chat you will need to install it in your PC.
To install first connect the web cam with PC. Insert the installation CD in CD/DVD-ROM, run Setup.exe and install it. Once setup is successfully completed you may need to restart the PC.
Now open and sign in your chat client (MSN messenger, Yahoo messenger, Gtalk messenger, AOL etc.) For example: If you want to start share your web cam in Yahoo messenger, just Login with your ID and password....click on Messenger choose option My Webcam.One warning message will appear...click OK....your webcam will start....Now if you want to invite someone to view your webcam, simply click on his/her ID and open IM window....click on Actions, choose More Actions from down of the list....and click on Invite to view my webcam....if he/she accepts your invitation...he/she will able to see you....again if you want to see someone who having Webcam....open the IM window by clicking his/her ID.... follow option Actions > More Actions and click on View webcam....yahoo will send the request to him/her...if he/she accept your request....you will able to see him/her....
For MSN messenger....sign in to your messenger and click on Actions and from list choose option Video and click on Show my webcam to view your webcam to others from your contact list.....or click on Start a video call to start video chat.....
To see others webcam click on View a contact's webcam....if the person accept your webcam....you will able to see his/her webcam....
Same to other chat client too...just little different in options....
I think you can get it easily...
For further help please be with us.
Thanks for joining Fixya community...
All the best
Nov 21, 2009 | Computers & Internet
I have installed the camera and it works fine in testing it.....but when i want to use to on MSN, it says there is no camera installed. i have unistalled and reinstalled but am lost how to get it to work?
HI,
First uninstall your msn messenger and then uninstall then webcam software/drivers.After that reinstall the webcam and then reinstall the msn messenger.
This should fix the issue.
Let me know the result.
Thank you for using fixya.
Nov 17, 2009 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
I have a problem with my cam i have set up the video and audio and it show myself but when i got to send it to someone on windows live it comes up with a red x can someone help me???
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Nov 06, 2009 | Logitech QuickCam Express Web Camera
How do I call someone with a web cam
Well, webcams can't connect by themself. You need programs, MSN or Skype if you have them. Whatever program it is you will need to inform me so I can help, this is too generic to fix. MSN: While talking to someone, Tools> Audio and Video> Option> Set up your audio and mic press Next, Set up your video, adjust so you can see yourself clearly, then press Finish. When you talk to someone you will be able to see if they have a webcam, in the meantime you can share your webcam (show your cam) to that person. Like I said, depending on your program it varies.
Jun 08, 2009 | Computers & Internet
MSN problems with my VX 3000 lifecam
did you go into the setting for msn and setup the cam
Apr 16, 2009 | Microsoft LifeCam VX-3000 Web Camera
HOW DO I TURN OFF AVATAR LIVE CAM VIDEO
This problem is not fixed through the settings of your Creative device but by selecting the right webcamin your messaging software.
When you install your Creative Camera it installs the physical Camera as well as a virtual Camera. So there are actually 2 (or more Camera's installed). The Avatar plays through the virtual Camera.
Whatever programme you are using (MSN or SKYPE etc) you need to select the correct video Camera.
So, for example in MSN messenger, select Tools, Audio Video Setup and select your camera from the list (make sure the Virtual camera is not selected).
To be even clearer as an example: If you are using a LiveCam Notebook Ultra 3 camera, you will see the following listed as cameras when you go to select a webcam to use within your messaging software :
Live! Cam Ultra Notebook #3 -- this is your normal camera
Live! Cam Virtual -- this us the Avatar etc camera,
Live! Cam Ultra Notebook Ultra (VFW) -- this is your widescreen camera
Just select the right one!
Fliboy
Apr 05, 2009 | Creative Labs Live! Cam Optia Pro Webcam
Web cam
In msn live click on show menu then tools option for cam setup
If that don't work click again show menu then actions then video then show my webcam or start video conversation.
If taht does'nt work then I would assume it's something in your camera setup itself
Jan 11, 2009 | Acer Aspire 5610-4648 Notebook
GE MiniCam Pro HO98756 Webcam Logo
283 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
