Question about Cameras
Camera does not turn on-it is an hp photosmart m 407, 4.1mp. I have changed batteries .On /off button just flashes once and nothing happens.
  • memorg Jun 25, 2009
    Thank you so much. Camera is now working. Got the right kind of batteries.
    Thanks again
    memorg.
    The camera has a flasing light on the right side -back of camera - what is that? I don't have a manual on this camera.
    memorg
    President:
  • 987 Answers
Step one: Reset the camera
  1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
  2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
  3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
  4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
  • If the is not resolved , continue with the next step.
Step two: Check for damage or corrosion on the batteries
  1. Open the Battery/Memory card door on the camera.
  2. Remove the batteries.
  3. If the batteries are damaged or show corrosion, replace the batteries.
Step three: Recharge the batteries
  1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
  2. Try turning the camera on after the batteries are fully charged or have been replaced.
Step four: Ensure the batteries are installed correctly
  1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
  2. Try turning the camera on.
Posted on Jun 26, 2009
  • Sibananda Jun 26, 2009
    Step five: Turn on the camera without the memory card
    2. Remove the batteries and optional memory card from the camera.
    3. Wait 15 seconds.
    4. Re-insert the batteries into the camera, but not the memory card.
    5. Try turning the camera on.
      • If the issue
        is resolved
        , format the memory card in the camera and then you
        do not
      • If the
        is not resolved
      WARNING:
      Formatting the memory card in the camera will erase any images stored
      on the memory card. To avoid losing the images on the memory card,
      first save the images to a computer or another disk.
    Step six: Connect the camera to the optional AC power supply
    1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
    • If the issue
      is resolved
      , you
      do not
    • If the
      is not resolved
    Step seven: Service the camera
    If the camera still will not turn on, service the camera.
    Cause
    The following conditions can cause the camera to not turn on:
    • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
    • Corrupt images on the memory card
    • More than 300 pictures on a memory card
    • Damaged batteries
    • Dead batteries
    • Incorrectly installed batteries
    • Damaged camera
    Sergeant:
  • 296 Answers
Issue The camera will not turn on. Solution Follow the steps below to resolve this issue: Step one: Reset the camera
  3. Wait 15 seconds.
    • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
    WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
  • Damaged batteries
  • Dead batteries
  • Damaged camera
Thanks for contacting Fixya
Posted on Jun 24, 2009
Same Problem
Check the batteries. Use good quality bateries for these digital cameras. I would highly recommend good quality rechargeables.
Jun 17, 2009 | HP Photosmart M525 Digital Camera
Camera stuck in extended lens, but off state
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=uk&dlc=en&docname=c00045448
Remove the batteries. Wait at least sixty seconds before reinstalling the batteries and turning the camera on.
You may want to print out the page or write down what you need to do and stick it in your camera case for future reference.
Good Luck! : )
May 26, 2009 | HP Photosmart 618 Digital Camera
Camera will not turn on.
Connect the camera to the charger. If it works while connected to the charger you need a new battery.
Jan 01, 2009 | HP Photosmart R707 Digital Camera
My camera wont turn on at alll
The same thing happened to me, I just called HP which took like an hour and told them what was going on and they walked me through trouble shooting steps over the phone which took another hour and then they mailed me a new camera and i sent them the old one with a prepirinted shipping label from them. this happened to me twice.
Nov 22, 2008 | HP Photosmart M525 Digital Camera
Not turning on
The batteries probably need to be replaced. Be sure that any batteries seat properly and tightly. You may have to tape the battery door shut with strong tape to keep the contact tight. This type of damage is expensive to repair compared to the cost of the cameras. You can take it in and have it looked at, but be sure to get an estimate and then you can make an educated decision on whether to repair or replace it.
Best wishes to you and Thank you for using Fix Ya!
Aug 23, 2008 | HP Photosmart 435 Digital Camera
Continuous flash charge
Try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 23, 2008 | HP Photosmart 735 Digital Camera
Charging flash
same problem, exact same camera... I had fixed it already with a guy who fixes all kinds of cameras and he had to change a piece that wasn´t working, but after a few months the problem started again...
Dec 26, 2007 | HP Photosmart R927 Digital Camera
"Charging Flash"
i just posted the same problem a few minutes ago and now i have the solution!! got to this link http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=437509&lang=en
download the driver if needed (the firmware installation will tell you if you need it) and then download the firmware. immediately after i downloaded the firmware, the "charging flash" went away! hope it works for you too~
Aug 22, 2007 | HP Photosmart R817 Digital Camera
My camera will not turn off !!!!!
WOW: All three Solutions Work Fine.
I Removed the 6 small bolts and took the camera apart.
lifted the tape and cleaned the contacts u;nder the tape with alcohol, let them dry then replaced the tape, lineing up the contacts on the tape with the ones on the body of the camera. Put the camera back together and put back the 6 bolts, inserted the batteries and presto: the camera worked. Thanks for the info , it really worked. Wes Reed
Sep 11, 2006 | HP Photosmart M407 Digital Camera
Mi camera wont turn on and all the answers for the others did nothin
hello, i think you have tried everything. After that nothing left to do i straightly advised to go to hp shop. good luck..
Jul 30, 2006 | HP Photosmart E317 Digital Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
