Question about Bryant Heating & Cooling
The AC unit is not working on my bryant model number 561cj048-A
  • 614 Answers
Does the blower inside work. If so check breaker and float switch on Air handler. That is about as far as you can go without a service tech. Rus
Posted on Jun 24, 2009
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 30, 2017 | Bryant Heating & Cooling
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
My AC doesn't seem to be as cool as usual ive checked the pressure ( 100 and 30 )but i cant find what normal is. the model # on my unit is 561cj048-f
Hello, if the high side pressure iS 100 and low side 30, then the unit is undercharged. Im assuming this is a R-22 unit. Typically your low side should be between 65-70 psig and high side should be between 220-230 under normal conditions.
Jul 08, 2011 | Bryant Heating & Cooling
I am trying to replace my old bryant heat pump with a new bryant heat pump, but I am having a difficult time figuring out the tonage. Can you tell me if I have the model number?
yes just post the model number and someone will be glad to help you..
fyi if the model number has for example 373036 373042 373048
the o and number after it usually is the btu value...
12000 btu's = 1 ton so a 036 would be a 3 ton 042 3 1/2 060 would be a 5 ton
post the number someone will help you out... another way to find out
carrier which makes bryant units can help you also
a number for ft. worth location is 817-834-4496 good luck to you
Feb 10, 2011 | Heating & Cooling
How many tons and what Seer is my Bryant model 561CJ048-A
12000 btu/hr equals 1 ton. The 48 in your model number tells me it is probably a 4 ton unit. 48 divided by 12(000) equals 4. Not sure on the SEER
Oct 08, 2009 | Heating & Cooling
What is the part number for the outdoor fan motor?
as old as this unit is you probably cannot read the label on the motor it is either a 1/4 or 1/3 horse power 230 volt motor. a generic motor will work fine, use a 1/3 to be sure. also replace the capacitor so it matches the new motor. if you can read the label the part number is on it, should be an HK # with about 7 more digits
Aug 03, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
747 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
