Question about Kenmore 22422 Top Load Washer
My Kenmore 70 Series Washer stopped working. We are not sure what the problem is?
  • 351 Answers
What cycle? most of the time it is the lid switch ... check that first and let me know..
Posted on Jun 24, 2009
  • 1028 Answers
SOURCE: Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Posted on Jul 20, 2008
  • 11 Answers
SOURCE: My Kenmore series 70, top loading, washer has a mold smell.
thaty have this one stuff called affresh its used for frontloaders but you can use it for toploaders too it works great
Posted on Mar 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: 70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Posted on Mar 27, 2009
  • 234 Answers
SOURCE: Kenmore washer won't stop filling w/ water
The problem is most likely the water level switch. This would be the case if the water is able to be turned off with the dial on the washer and not running all the time.
If it is running all the time and you have to turn it off at the water line valve, then the problem is a stuck water fill valve.
If you need more help, post a comment.
You can find information on the parts at partselect.com.
You can buy parts from them or find them locally if you want.
Thanks,
Tim
Posted on Jun 16, 2009
aasc
  • 1606 Answers
SOURCE: Kenmore 70 Series Washer
The lid switch is bad . You can either replace it , or bypass it under the control panel . Try putting a pencil down into the hole on the top where the lid actuator goes into to see if it drains and spins .
Posted on Aug 20, 2009
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series slow agitator
You have burned the clutch this must be replaced
Jun 09, 2009 | Kenmore 15864/15862 Top Load Washer
Mar 24, 2009 | Kenmore 22422 Top Load Washer
Timer and possibly more.
yes it an cause the water flow to stop....your best bet is to buy another timer and put in or get another washer.
Jan 21, 2009 | Kenmore 22422 Top Load Washer
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
138 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
