Question about IBM Infoprint 1332 Laser Printer
I am getting paper jam error code 201 and it has been happening more often the last couple of days. Would this indicate I need to install maintenance kit??
  • 32 Answers
It can indicate you need pickup rolllers. You can confirm this by checking the rollers in each tray. If they feel smooth, then they need to be replaced. These do come as part of a maintenance kit, but the full kit cost a couple hundred dollars, while the rollers cost under 10. If it is not prompting you for a kit, only buy the rollers.
Posted on Jul 24, 2009
I keep getting a paper jam 201 every time I print. Then I have to open it up and take out the cartridge. What is causing the paper to jam?
A 201 paper jam error indicates the paper did not reach the fuser sensor within the proper time period. This usually indicates the fuser has a problem and needs to be replaced. The part number for the fuser is 56P1333 and it is user installable. You can get one from many places online such as Amazon.com
Aug 20, 2012 | Lexmark T630 Laser Printer
I had a paper jam a few days ago. Turned printer off then cleared jam and when I turned it on again it still had the E3 error code indicating it is still jammed. There is no paper in it anywhere. I have...
Check the paper feed tray for bent papers. Also, try blowing over the sensors to clear any debris. Check for small pieces that may have been left behind. If all fails, unplug it from the outlet, then start it up. Good luck!
May 06, 2017 | Xerox WorkCentre XE90FX Laser Printer
My printer lexmark e342n 201 jam error code, what the are problem, fuser or pick-up roller and how to soft that problem. tq
If you are getting 201 error code, it means a paper jam has occurred. To fix this problem please Open the front door. Remove the toner cartridge and remove the jammed print media.
Click on the link http://bit.ly/p1jJcd to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
Jan 22, 2011 | Lexmark E342n Laser Printer
Have an Imagerunner 5180 giving err code E000007-0102 - Tried to clear it while in the service mode and it continues to give shutdown sceen - cant find anything physically wrong with the copier - Anyone...
Item Description Remarks AAA Indicates the numbers of jams
(larger the number, the more past the jam). 1 to 50 (50 max.) BBBB Indicates the date of occurrence. Month, day (2 digits each) CCCC Indicates the hour of occurrence. 24-hr notation DDDD Indicates the return of recovery. 24-hr notation E Indicates the location of occurrence. 0: copying machine
1: feeder
2: finisher
EFff Jam code. FF: jam type (T04-201-01)
ff: jam sensor (T04-201-02)
(For the feeder, T04-201-04.)
G Indicates the source of paper. (T04-201-03) HHHHHH IIIII Indicates paper size.
Mar 14, 2010 | Office Equipment & Supplies
KEEPS SAYING PAPER JAM AND THERE ISNT ONE. DOESNT SEEM TO WANT OT PICK UP PAPER
ok im going to guess here that you are getting a 201 paper jam error with no paper in the printer. this would indicate a bad main motor drive replace it.
if its a 202 error check the 2 sensors on the fuser for stuck flags
if its a 241 error clean the pick wheels with aresol elctronic contact cleaner to remove the glue build up from them. or replace them
Dec 04, 2009 | Lexmark T640 Laser Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
Just installed a maintenance kit in my HP laserjet 5p now it won't work. Followed step by step cd on install. Printer worked before install. Printer keep given me a paper jam code (amber light at top)....
Did the maintenance kit include a fuser? If it did, then check to make sure you didn't break the sensor flag. If it's broken you'll get a constant paper jam indication. It's a movable lever usually where the paper comes out of the fuser.
Nov 29, 2008 | Office Equipment & Supplies
Hp laserjet 8100 8150 13.1.42
hp printers typically do not have an error message to cover every known condition, thus if the printer needs maintenance in an undefined area, it will invariably indicate a paper jam. The printer usually responds to the installation of a maintenance kit which will include transfer roller, pickup rollers, and fuser.
Oct 03, 2008 | Office Equipment & Supplies
202 paper jam error, but no jam present
I cleared that error on one by replacing the fuser. It had a small piece of paper stuck in the roller.
Oct 30, 2007 | Dell W5300N Laser Printer
IBM Infoprint 1332 Laser Printer Logo
226 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
