Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
I have a Kenmore 106.5666502 s/s refrigerator. The freezer side is the proper temperature, but the refrigerator side is staying warm (~50 F). I have cleaned the compressor coils under the fridge and pulled the cover off the evaporator in the freezer. There is a small amount of frost built up, but nothing serious (like completely iced over). What should I do next? Thanks for your help.
    Sergeant:
  • 212 Answers
Your on the right track with the frost issue. but make sure your fan is running at the evaporator durning normal compressor run time. if there is not alot of frost build up at the evaporator the only other thing it could be is low on freon
Posted on Jun 24, 2009
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
Have a kenmore refrigerator freezer works but not refrigerator
You mean "How to Fix a Kenmore Refrigerator That Is Not Cold But the Freezer Is Good?"
Well this what i say,
Kenmore combination refrigerator and freezers combine the short- and long-term food storage options in a single unit. There are some occasions when the refrigerator compartment might appear to be malfunctioning while the freezer box stays cool. Ruling out these occasions ensures you have done everything you can to correct the problem before calling for a technician if necessary.
1.Verify that the temperature controls for the refrigerator compartment are properly configured. Tap the "^" or "v" buttons beside the refrigerator's LCD temperature display until "38," the ideal temperature, appears. The compartment could have been set too warm. Allow 24 hours for the the appliance to reach 38 degrees Fahrenheit.
2 Check that the refrigerator compartment door closes completely, objects inside the appliance could be holding the door ajar. When cool air is allowed to escape, the internal temperature rises. Cracked, holed or corroded door seals may also raise the refrigerator temperature.
3 Change how you use the refrigerator compartment; storing hot or warm food strains the appliance and causes a rise in internal temperatures. Do not prop open the door or leave it ajar for more than a few seconds at a time for the reasons outlined in Step 2.
4 Contact Kenmore if the refrigerator compartment remains too warm for your food. There may be a problem with the motor or any one of the other parts that regulate the temperature
If this was helpfu.l please let me know.
Thanks for using FixYa
Sep 06, 2011 | Kenmore Top Freezer Refrigerator
My side side frige is warm to the touch in the middle
Getting warm around the door is OK but getting hot around door indicates a restriction of the airflow below your refrigerator. The compressor produces hot Freon that is pumped out the discharge side of compressor. On many refrigerators the gas goes to the yoder Condenser Loop first and then cooled by the condenser fan motor before going to the freezer section as a liquid.
Anything restricting that airflow will cause the yoder loop to get hotter. Example a defective condenser fan, dusty conditions below refrigerator or room temperatures way above normal for a kitchen or room inside your home. Insure fan stays on when compressor runs because a defective condenser fan does not always stop when defective. Most refrigerators work best with room temperatures in mid 70's to middle 80's. Making sure that airflow is good, fan's stay on with compressor and room temperatures stay in the normal range is important to keep those temperatures lower in the yoder loop. If helpful please rate this solution, Thanks Sea Breeze
Jun 28, 2011 | Kenmore 53642 / 53644 Side by Side...
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Refrigerator will not stay cold
Eeeh, this will prevent you to spend more than you have. Carefully unplug your fridge, remove it from the wall for about 1 foot wait 15 mins and plug back and let it stay there for ever.
Sep 16, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Freezer side cold, food side warm not working
3 possible problems.... Machine is possibly not defrosting (if this is it, eventually the freezer will not work as well) The damper between the two sides is possibly not operating, or the fan on the freezer side is possibly not blowing the cold air into the fresh food side.
Mar 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
203 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
