Question about Kitchen Ranges
Viking stove top gas burners
Electric spark stopped working on all burners. Circuit breaker is fine...plug that unit is using is functional.
  • 1 more comment
  • Anonymous Dec 16, 2007
    We had a similar problem with our viking stove top. The front two burners quit sparking and the back two burners spark continuosly. I finally just unplugged the power and use a striker to light the burners.
  • Anonymous Aug 30, 2008
    I also have a Viking VGR-36 and the ignition sparks have also stopped working on all 4 top burners. What should I check or replace?.
  • Anonymous Dec 31, 2008
    I bought a 36" Viking and had ignition problems from the get-go.Also, somw of the burbers do not burn evenly.
I have a VGR36 6 burner. All the spark ignitors stopped clicking after a major boilover spill. Liquid got into the spark module compartment and caused a short. The paper wiring diagram under the spark module protective cover was burned from the short. I had a Harper 6542 non-reignition spark module but the replacement part is now a Tytronics PA020041 Spark Module. I bought kit #000511-000 from which includes the module, a black jumper wire, a green ground wire and an instruction sheet.
It's not difficult to replace the spark module but the 2 screws holding down the module toward the back of the stove are not visable and accessible. I used a thumbwheel rachet with a long philips screw driver bit (for cordless drills) to remove and replace the screws. The wiring was simple. The 2 power wires need to be wired to the correct polarity on the module, but the remaining 4 ignition wires can be wired to any of the 4 terminals on the new module. All the wires have plug in connectors and no cutting and splicing is necessary, but I had to cut and splice because one wire shorted and the insulation was burned from the major spill on my stove.
Posted on Mar 19, 2010
  • 288 Answers
When you say plug I'm assuming you mean the outlet in the wall. And you checked it for 220 volts with a meter? If all this is good then maybe you need a new ignition coil. I need more info.
Posted on Nov 05, 2007
My viking oven just sparks no gas to the oven,stove top works fine?
Posted on Mar 23, 2010
  • 5,568 Answers
The 'guest' who posted Solution #2 is way off-base; electrical discharges (sparks) definitely require high voltage, about 3KV per millimeter in 'standard air.' The transformer that 'downgrades' (steps down) the 110 is intended to supply other circuits, not provide ignition.
Posted on Oct 19, 2008
The Vikings only use 110 volts, not 220. Why would the stove be 220 when a low voltage spark is used for ignition. You don't need high voltage to spark. There is actually a transformer to downgrade the 110.
Posted on Feb 09, 2008
Viking model vdsc4874gss small oven works fine large oven element on bottom only gets hot in cleaniong mode, fan comes on when dial is turned to convection but no heat power is on light works
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Oct 18, 2010 | Viking 48" 6 Burner, Grill Professional...
How do I access a spark ignitor on a Viking gas
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by a 'tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and would cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range. Of course you need to ensure it is the correct one for your stove. The ignitor you remove should have a manufacturer part number on it. No calibration required on mine - a sealed electronic unit. Probably about 10 wires that need to be R&R'ed - they are on with reuseable fasteners.
Jan 18, 2010 | Stoves 600SiDOm Gas Kitchen Range
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
Viking 30" gas professional series cooktop sparking problem
And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
Kindly rate the answer
Jul 06, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
My admiral stove stopped working, the elements just arent on anymore, but the stove has power because i plug my toaster into the socket on the stove and it still works, and everything else in the kitchen...
first thing is to check you r circuit breaker,is it an electric range ??? or a gas stove with electronic iginiton???, if its a full electric range then youll have a double breaker powering your unit, and its possible that one of the breakers tripped, allowing only half power to the unit.if its a gas with electronic igniton then slightly different matter and then i would ask of the top elemnts will light with match and perhaps theres an issue with the electronic spark switch
Oct 22, 2008 | Kitchen Ranges
Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Jun 19, 2008 | Viking VGSC306-4B Gas Kitchen Range
All 4 ignitors just stopped working on the stove more 'clicking' sounds
1 Check to be sure unit is properly connected to power supply.
2 Check for a blown circuit fuse or a tripped main circuit breaker.
3 Check to be sure ignitor is dry and clicking. Burner will not light if ignitor is damaged, soiled or wet. If ignitor doesn’t click, turn control knob OFF.
4 Burner ports may be clogged.
Dec 03, 2007 | Maytag MGR6775 Stainless Steel Kitchen...
Kitchen Ranges Logo
1,786 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
