Question about Dyson DCO7 Animal Bagless Upright Cyclonic Vacuum
Belt intact but not turning when motor runs...
I've tried to fix this problem by taking the whole Dyson DC 04 apart but I cannot get to the drive shaft! Is there a trick to this? Any help will be appreciated. Thanks. Hylton
  • 65 Answers
Most of these have a clutch system, the only other thing would be that it may need a new brush sometimes the brush rollers have hair and string in the bearings that melt and make the brush a sold non moving piece
Posted on Oct 02, 2009
How do I fix the carpet brush on my dyson dc14 vacuum?
this is what is is broken it is the clutch Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
most likley needs to be changed it is also a good idea to change the roller brush at this point also
Dyson Dc 07 14 33 Upright Models oem 904174 01
Jun 12, 2016 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hi,dyson dc25 overdrive,my brusher's wont go round,i have cleaned the brusher's and filter,loads of suction.the belt is intact and the roller move's feely by hand,could it be the switch
Hi Stephen,
I'm sorry to hear you've had difficulty with your DC25 Overdrive. If the brush bar won't rotate, and you've already checked the cleaner head is free of obstructions, it's likely it just needs resetting.
You might like to take a look at the video below to make sure everything is correct with the machine. Once you've done this, if you turn the machine on, recline it into the vacuuming position, then press the silver brush control switch twice, this should reset the brush bar.
If you'd like any further assistance or advice, please give our Helpline a call on 0800 298 0298. Just to let you know, calls are free from UK landlines, and the Helpline is available from 7am-10pm, 7 days a week.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Aug 01, 2012 | Vacuums
Bottom agitator brush bar doesn't rotate.
First, check to make sure the brush bar is on. The switch is right next to the machine's on-off button, and it is easy to accidentally turn it off when you turn the DC 25 on or off.
Next, check for and clear any obstructions in the brush bar housing.
Finally, check for belt wear and replace if necessary. There is a very video online showing the procedure.
Jul 21, 2012 | Dyson DC25 All Floors Bagless Upright...
Brush does not spin
Here's a parts diagram for the machine. It took me a bit to find it. Dyson doesn't want to give any kind of parts diagrams or such that I could find. Anyway, I'd say your drive belt is probably either broken or slipping. More than likely the first one. Just make sure that the Brush bar isn't all jambed up with hair and whatnot. Which you've probably already done, but I fixed my neighbors about a year ago, and her's was so clogged up that it would barely turn with the belt intact.
The diagram will also give you a good idea of how they go together and what parts will come off of what. Hope this helps.
http://www.searspartsdirect.com/partsdirect/part-model/Dyson-Inc-Parts/Vacuum-Parts/Model-DC25/3207/0645000/50033527/00004?blt=06&prst=&shdMod
Mike
Aug 08, 2011 | Dyson DC25 All Floors Bagless Upright...
Dyson dc07 brush not turning belt is intact?
DC07s have two drive belts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look atwww.dysonmedic.com which has some excellent info on dismantling and repairing a DC 07, but unless you have access to such tools, and feel confident to tackle it, it's probably time to callDyson or a Vacuum repairer.
Sep 30, 2010 | Dyson DC07 All Floors Bagless Upright...
Fix a belt on a dyson dc 04
need to know if your unit is clutch or clutchless but if you go onto youtube and look for fit dyson belt or fit dyson clutch that mite help
Oct 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Not picking up and the brush does not move
Check to make sure that the knob for carpet/ bare floor has not slipped, the brushroll will only turn when carpet is selected. The most likely culprit is a stretched belt on your clutch assembly; you have one tor the brushroll and one to the motor. These belts will stretch out though Dyson will not tell you this. Best remedy is to replace the clutch assembly with OEM # 900252-04. Dyson will sell the Brusholl belt but I suggest shopping arround to find someone willing to pull the clutch apart; to my knowlege Dyson will NOT sell the motor belt.
Jan 17, 2009 | Dyson Vacuums
Dyson dc 04
Hi.
Which machine have you got Dc04 or Dc05 ?
Jul 01, 2008 | Dyson DC05 Cylinder Bagless Canister...
Dyson DCO7 Animal Bagless Upright Cyclonic Vacuum Logo
136 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
