Question about Refrigerators
I have a 10 year old Amana side-by-side refrigerator, SRD26V/VP. It periodically stops cooling, but a fan is still running. Any ideas what could be the problem?
    Sergeant:
  • 212 Answers
Compressors start device overload is going out. replace both stat device and overload.
Posted on Jun 24, 2009
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
My 10 year old side by side refrigerator freezer stops working and then after a few hour it works.
The defrost timer/board/ termination thermostat is hanging up and holding it is defrost too long....
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana Refrigerators
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Fan doesnt stop in Amana side by side refrig.
The fan is supposed to spop while defrosting kindly check the timer contacts or wiring short
Jul 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Freezer no cooling
check continuity thro the fan motor and check it rotates freely
Oct 02, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
