Question about MXL Audio Players & Recorders
The sound is really low, it only works for 3 seconds when I turn on the phantom power and then it goes really low almost soundless
  • miguelochagu Jun 26, 2009
    I think I need a preamp maybe . My interface has phantom power do you think that maybe the condencer needs the preamp anyway?
  • Georges Oct 18, 2011
    Hello, did you catch a solution for your problem ?
    I have exactly the same problem with a 990, if I want to speak in the mike, a few close to the mesh, the sound is working for 2 or 3 seconds and then it disappears. The sound is going back later, gradually from 0 to 100% after a few seconds.
    I've tried several phantom power, berhinger stand alone and with the 48V from a Soundcraft mixer, it still the same issue.
    Others mikes work with this configuration, without any level problem, even if I shoot in them !
    I noticed that it's above a certain speech level that the problem begins. It looks like any electronic component in the mike is 'overloading' or something like that when I speak very close to the mesh, and the sound is fading instantly.
    Do I have to speak farest from the mesh and getting less s/n ratio ?
    I presume this behaviour is not normal, is not ?
    Thanx for your 'feedback'.
    Georges G.
  • 4 Answers
Are u sure the type of mic ur using is made for phantom power? if it is. try opening up the gain on the sound board just a tad. if that doesnt work turn the master slider up. try other mics and see if it isnt ur soundboard or speakers
Posted on Jun 25, 2009
    Problem Solver:
  • 4 Answers
You're an idiot, you should just get out of audio recording and go die.
Posted on Oct 04, 2011
    ? thanx for your help...
C1000s hum/buzz on phantom power
possibly the microphone needs more power than your sound card can supply although I cannot imagine as the duet is a good piece of equipment.
Is the duet USB bus powered?
Have you tried another cable? Possibly one wire is defective which means that phantom power will superpose the audio signal. In this case you might hear a hum. By the way this results in 6dB of signal loss. This is why XLR plugs have 3 wires. If connected with a 1/4" jack it has to be a stereo plug (tip, ring, sleeve)
Mar 26, 2014 | AKG Audio Players & Recorders
Mxl 40000: When you plug it in it works for a split second and then volumn drops to almost zero.
Sounds like a weak or missing Phantom Power Supply. This power is supplied by the source "mixing console" and can be turned off on many models of consoles. If you have a smaller and lower end mixer it is possible it does not provide the needed Phantom Power. Also if the mic cable is incorrectly wired the Phantom Power is not being properly supplied to the mic. This also could damage the mic by putting the voltage on the wrong pin connections. Pin 1 is ground, pins 2 and 3 are audio high and low. Sorry I do know the exact connection for 2 and 3. The user/owners manual may supply the correct wiring information. A store bought cable of good quality should already be wired correctly.
Dec 23, 2013 | MXL 4000 Microphone
I have a Yamaha IM8. I had a condenser mic hooked into channel one with phantom power on. I had to leave the room for a while and when I came back, I noticed some rather severe popping in the audio. I turn...
There is really no way for a condenser mic to damage the board UNLESS you break the ground and get a static discharge into the input. That can happen with any microphone and has NOTHING to do with the phantom being on or off. As phantom power goes on and off slight bias at the input preamps can make amps non-linear causing the raspy sound you heard. The Phantom LED means NOTHING as it shows the state of the phantom switch by connecting a 12 volt source through a resistor to the LED... It shows NOTHING regarding the state of the 48 volt supply. Each input circuit has two 6.8Kohm resistors to the swinger of the phantom switch 2nd pole that either grounds those or connects them to a filtered 48 volt source. As long as you don't have a static buildup there is NO need to turn phantom power on or off while connecting a condenser microphone. At each input when using the XLR jacks are two per side 470pf capacitors for RF bypass. For the XLR's there is a 10Kohm between the signal lines and two series 10mfd/50 volt caps in series of each input to block the DC, when using phantom power, from reaching the preamp stage. These caps have to charge and discharge when changing the state of phantom power so you should AVOID having the main amps being driven while changing the state of any phantom power. Always have the fader(s) down and any monitors down to avoid a thump and also the non-linear raspy transition as the input caps charge/discharge. So fix the microphone... don't know what type you have, but DO check the cable (first) as ALL three conductors MUST be good for a condenser mic to work on phantom power. A ground leakage or noisy connection will cause your symptoms. Use a SHORT known good cable right at the board to test the mic. The 48 volts is applied through the two 6.8K resistors between both the signal lines to the shield of your XLR cable. The microphone picks off the 48 volts with a similar circuit.
Now let's cover a very important thing regarding system safety: ALL, and I do mean ALL interconnected equipment MUST be powered from the same source. Professionals run a power cord back to their mixer right alongside the snake. This is to avoid ground bounce damage due to bad building grounds or ground faults.
Mar 22, 2011 | Yamaha IM824 24 Channel Mixing Console IM8...
Do phantom power only work for 3 4 mic input
Hello Aaron, I will need to have you clarify exactly what you are asking. The question could either mean the pin connectors on the sound board to the instrument / mics or can you connect 3 or 4 mics to a phantom power supply.
Nov 28, 2010 | Music
I bought a GXL2200 and i cant hear my vocals.
The GXL 2200 is a condensor microphone. It needs Phantom power to operate, and get the correct levels for recording. Your lexicon interface should have a button/switch that says +48V phantom power, or something similar. This needs to be enabled before the GXL 2200 will work.
Mar 07, 2009 | CAD Microphones GXL2200 Professional...
Connecting phantom microphones without result
if you have a volt meter check the supply is working correctly
48v dc phantom power should be found between these pins on any xlr mic cable.
pin 1 and pin 2
also between pin1 and pin 3
make sure you have amps turned down before checking/switching 48v phantom power
as if all is up and running it can cause big noise in the speakers.
let me know how it goes
Apr 29, 2008 | Sanken 48V Phantom Power Supply P11SPT...
6288 soundless
Try this code *#4720# . It might or might not work. It's a deactivated low sound volume to save battery.
Apr 06, 2008 | Nokia 6288 Cellular Phone
(I have Antec Phantom 500) when I turn on my computer it turns on for about a split second and it goes off ..
Most likely the power supply but it could be the motherboard.
Do you see anything on the screen when it comes on?
Jan 18, 2008 | Antec Phantom 500 (PHANTOM500) 500-Watt...
Open Questions:
453 people viewed this question
Top MXL Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
rhodesworks
Are you a MXL Audio Player and Recorder Expert? Answer questions, earn points and help others
