Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washing Machine trouble
The inside barrel, or what ever it is called, keeps jerking really hard when its done with a cycle. It practically moves the washer itself and sometime when it is filling up, the water doesn't go into the center because the center is to the front and the water goes down through to the floor. so.
  • WVLuke Nov 09, 2007
    Mike, sorry i haven't sent a reply, but working so much haven't had time to try to fix the washer yet but am off the next couple of days and i will let you know how it comes out, I wanted to thank you for the advice. It's nice to have an experts brain I can pick for things like this, Have a great day and thanks for the follow up. Luke
  • Anonymous Nov 18, 2007
    I think the porcelain basin in my washing machine is loose--towards the end of a rinse cycle, the whole thing began shaking violently, jumping from left to right. I was afraid my machine would explode! I've tried turning the basin counter-clockwise with my hands, but to no avail; it wouldn't budge.
Hello I have a fridgitaire top laoding washer the barrel is spinning ok but when it is in spin or even power spin cyle its not draining the water into the hose on back instead some water was coming out of the back of the machine what does this mean?
Posted on Jun 28, 2008
Washer is making a high pitched nose when it is spinning
Posted on Jun 01, 2008
  • 290 Answers
The easiest way to solve this without taking the machine apart is to tilt the machine back and look under it.
Above the transmission and clutch you will see the brake assembly. It is a little aggrevating to get to with the cabinet on, but you can spray it with some silicone lube and it will help this problem. You may have to spray it then put into spin, stop it and spray again. After it spins and stops a few times it will usually smooth out.
Posted on Nov 05, 2007
  • Michael  Lindley
    Michael Lindley Nov 08, 2007
    Just wanted to follow up on your washer and see what you found out.
I have a he eterna washer that makes loud noise on spin cycle. It sound almost like bearings grinding. Model # ewa4500d1ww
Your bearings will need replaced. Usually, the transmission is near the end of it\'s life by the time this happens and since it\'s easier to change out the transmission than the bearings (the bearings are part of the transmission) it fixes your bearing problem. However fixing just the bearings is a lot cheaper. There are some things you can check to see if the transmission itself needs replaced.
First thing is to look at the inside of the front panel you removed. If there is a band of slung oil about a foot from the bottom the transmission is toast.
If no oil is present lift the lid and remove the agitator. It pulls straight up (no screws to remove) with a quick jerking motion. I just put my hands around the neck of it like i\'m choking it and give it a quick kind of hard jerk. If it gives you trouble let me know. Once it\'s removed you will see a large plastic coupler. Make sure it doesn\'t spin and wiggle it side to side. There should be no spin or wiggle. If there is wiggle there may be a sick sloshy sound as you wiggle it back and forth. That\'s oil and you will most likely see it on the underside of the coupler as well. Use the machine a few more times and you may see oil on your clothes. Obviously that transmission has gotta go. If you are handy with tools you can change it yourself. There is a large 1 11/16" hub nut that will need removed. Other than that no special tools are required. Still plan on using up the good part of a day replacing it if you\'ve never done it and completely dismantling the machine. When you are done though you will enjoy a machine that is practically new again. You can buy new transmissions on eBay for somewhere between $100 - $150 any day of the week. The $150 ones should come with a new hub nut, tub seal and turtle brake at the very least, if not you\'ll need to purchase them seperately. It\'s also possible you\'d need what they call a tub bearing, but usually those are okay. Let me know. I can walk you through the process or perhaps find you more info. Good luck.
Jan 12, 2013 | Washing Machines
My top loading frigidaire washing machine barrel spins during wash cycle and the aggitator is going as well how do i fix it
Hello fire_rod - From what you have described it sounds like either the transmission is failing or the trunnion, which secures the tub to the transmission shaft has broken. Contact a professional to move forward accurately.
Dec 16, 2012 | Frigidaire Gallery GLWS1339EC Top Load...
My daughter has a new Whirlpool WTW4800XQ0, it takes the machine about 3 hours to go through the cycle. Okay this being said, when it gets to the spin cycle, it doesn't, she is having to pull the...
does it drain water, seems like it's gonna spin then starts filling up again? if this is what's happening it mean the washer is sensing that the load isn't balanced and it fill back up to move the clothes around and tries again, it will keep doing this untill it senses a balance of weight in the drum. if she tries moving the clothes around herself before it done draining she maybe able to keep it from doing this
Aug 05, 2011 | Whirlpool WTW4800XQ Washer
LG Steamwasher after wash cycle left dirty marks on clothes.
You may have some detergent residue inside the tub assembly. You should run a tub clean cycle and use some washing machine cleaner. You can get that at any hardware store. If you don't have a tub clean setting, use the sanitary wash cycle without any laundry inside. You must use the hot water setting for this to work. If you haven't done this in a long time, you may have to run this cycle at least once a week for a month to really clean the machine properly.
Jun 23, 2011 | Washing Machines
Had my machine worked on replacing barrel, clutch ect... Machine sounded like it was a train coming through the house before. Teck called another one to find out how to put it in some program mode or...
I really help DIY owners if you want to try the repair I'll help you.
Most repair tech have little hands on with the machine.
Google this Maytag/Magic Chef/Admiral/Jenn-Air
Open up a repair thread with model number and first two digits of you serial number and if you don't want to DIY we can help the repair person.
""had my machine worked on replacing barrel, clutch ect... Machine sounded like it was a train coming through the house before."" sounds like the Outer Tub bearings are bad.
""had my machine worked on replacing barrel"" Did the repair tech replace the Washer Outer/Inner Tub?
Go to the other DIY forum and lets see what can be done.
Feb 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine jerks hard when stopping from the spin cycle.
The braking mechanism inside the transmission is malfunctioning... Probably a break lining has come off. Sorry to say, it's not a job for the average do it yourselfer.
Nov 20, 2009 | Coffee Makers & Espresso Machines
Need belt for stackable frigidaire washer and dryer. Model is FEX831CS The washer jerked and threw a breaker. Now the dryer won't work and the washer lets water run in and the inside starts jerking hard
If you think that the washing machine belt is the cause of your troubles you can find it in the very bottom of the machine (behind the front panel)
Would need more info on the dryer problem, (Is it running with no heat or not running at all)
the washer drive belt is the only easy fix on this model.
Good Luck
Aug 21, 2009 | Frigidaire FEX831CS Top Load Stacked...
Admiral clothes washing machine AAV7000AW
Hello calmtouch,
You said,
When in spinning cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
sounds like the coupling connecting the tub to the transmission may be loose and throwing the wash tub out of rotation causing the banging and walking washer.
Bless You
Sep 19, 2008 | Admiral AAV7000A
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
472 people viewed this question
Dan Webster
Dan Webster
Sal De
