Question about Mitsubishi Televison & Video
I can't get my tv to work with my dish network receiver. I recently moved my 65" Mitsubishi to the 2nd location on my dish network receiver and now I cannot get the channels to work. Before the tv was in the no1 position and connected via hdmi cable, now it is connected with a coaxial cable and I have changed the input to cable, but still nothing. I have checked the receiver to make sure it was on the proper channel and have been on with dish network twice, but still nothing.. Thanks, Bob
  • 17 Answers
SOURCE: RCA 32'' TV .....Good Picture but No Sound
try changing the channel you outputing to. go to your tv1 location hit the menu button and choose number 6 system setup then number 1 instalation then number 5 modulator setup then change tv2's channel to like 65 then select done go to your tv2 put on 65 and see if this helps issue
Posted on Dec 02, 2008
tvtek
  • 1284 Answers
SOURCE: No right channel audio when using HDMI connection to HDTV
Since it is easier to replace, I would go with the cable box first. Sometimes there are software upgrades for the TV's that fix such issues but, almost all HDMI issues are with the cable box not the tv.
Posted on Jan 27, 2007
petraman7
  • 1175 Answers
SOURCE: Connecting an a/v receiver to a Dish network receiver
DO you have manuals for all the units listed?
If not , try the Samsung consumer site.
It would take me quite a while to figure out your situation even with manuals and I have a business to run besides.
Also, ask some questions of Tech Support at Samsung..Let them KNOW how much you spent on their stuff.
God bless,
SF
Posted on Jul 07, 2008
  • 374 Answers
SOURCE: DISH Network DVR-625 DTV - AUDIO PROBLEM ON LOCAL CHANNELS ONLY
I am probably stating the obvious here but here it goes:
If the 625 is connected to the tv using coax directly try using the RCA jacks to connect directly to the tv. If the 625 goes through a peripheral first, eliminate that peripheral and conect directly to the tv.If the problem exists with different media connections still at the same tv you can remove the coax off of the TV1(3-4) output on the back of the 625 and attach it to the TV2(CH60-73) output.You would then change your tv channel from 3 or 4 to ch 60air or 73 cable(which will be the same channel that TV2 is normally on in the remote room without the 625) Once you are on the right channel you will be able to tune TV1 to your local channel using the TV2 remote. If the audio is good here it eliminates the TV coax input on the TV1 and the coax cable connecting it as the source of the problem. You will have already eliminated any other inputs on the same tv as being faulty by using the other connecting media leaving you with the internal components of the receiver as being faulty. In this situation I know of no recourse except the obvious.
Posted on Aug 27, 2008
  • 374 Answers
SOURCE: DISH Network DVR-625 - Audio Problem
FIRST TRY CONNECTING THE RECEIVER TO THE TV VIA A DIFFERENT MEDIUM SUCH AS RCA INPUTS IF CURRENTLY CONNECTED WITH COAX.
If the problem is still evident you can send the TV1signal to TV2 or vice versa. This is accomplished by switching the output cables from tv 1 to tv 2 and changing the tv you want to use as your "monitor" to the proper channel. If viewing tv1 on tv2 change the TV channel from 60 air or 73 cable to 3. if using tv1 to view tv2 the process is the oppposite from 3 to 60air or 73cable.
To check which channel tv2 is modulated to do the following:
go to TV2 and with it on press menu, 6, 1, and then 5 on the Dish remote. That will dispay both tv output channels. You only need to be concerned with TV2.
This should isolate the problem by either it being present on both TV's using the TV1 output, which would mean the internals of the receiver are faulty, or if it is fine on the other TV it would indicate that the problem lies with the TV itself which is unlikely.This is assuming the FIRST method did noyt resolve the problem.
You may also want to try running the medium source from the back of the receiver directly to the TV.
This is all assuming you receive your locals through the satellite and not an off air antenna. Hope this helps you out.
Posted on Aug 28, 2008
Cant get mitsubishi ws-63313 to go into hd
Call Dish back. Your HD signal has to be configured in your dish receiver. They can configure it for you over the phone. If not, then the dish guy has to adjust the wires at the splice box wherever it's located in your house. HD requires a dual cable line from the dish to the splice block. It's not the TV.
Feb 21, 2013 | Mitsubishi WS-65313 65" Rear Projection...
One ir sensor must be covered up in order to control receiver
rogere214
There could be an IR interference from another source, perhaps florescent lights, DVD player, TV, etc. To locate the source, leave everything off except the receiver and TV. Turn one component on at a time and try the remote to see if the remote still works or not. If it still works, turn on next component. Try the remote until it stops working. Once you find the source,try moving it to a new location. If you don't find the source, then we may need to replace the receiver. I hope this helps.
Ray Calo
DISH Network
Aug 03, 2010 | DISH Network IR Remote Control
We recently moved our dish ( we are in an rv) and now we get a signal on one tv only. we have dish network and a 625 DVR. we have moved many times and have never had a problem before. in order to switch...
5shades690,
Are you still having problems with your TV 2 off the 625 receiver? You have a cable off the back of the receiver, TV 2 Home Distribution. That's feeding to your TV 2 location. You might check to make sure it is secure. You can also see if that cable screws into a diplexer if it is being back feed through the satellite cables. These are all potential problem spots, especially since you said it was working before. I hope this helps.
Ray Calo
DISH Network
Jul 28, 2010 | DISH Network DVR-625 DTV Receiver /...
Dish network control not working on 2nd. tv
You have a dual receiver and 2 remotes. make sure that receiver is in dual mode. That you press the sat key on remote 2 if it will still not operate take remote 2 to the receiver. With remote #1 press the menu button twice you should then be on they system info screen. Pick up remote #2 press and hold sat key until it blinks press record 3 times . press red power button and if tv2 light goes off and on the remote should work again for tv2 . Use remote #1 press select exit screen,
Jun 02, 2010 | DISH Network IR Remote Control
DISH Network(r) 311 Satellite System: we moved our tv and ever since we reconnected it w...
Hi myname is Mike Houston of DISH Network and I was going over your post and whenyou move the receiver you always want to make sure all connections are in thesame place. The SAT feed coming into the house will connect to the SatelliteIn, and your TV connects to the CH4 CH3 on the back of the receiver. I willsend a link that will help with these steps. http://www.dishnetwork.com/SupportSection/bbs-screen
May 16, 2010 | RCA DISH Network(r) 311 Satellite System
My remote is not responding to the 2nd tv satellite... but it does work for the tv
Hello walker3putt, my name is Michael Hurst with DISH Network. Is this remote an IR or UHF? There are ways of reprogramming the remote to the receiver. If this is and IR remote for an independent receiver then you can try pulling the smartcard out and System Information will come up on the TV. Look at the Remote Address on the TV and write down the number. Then Hold Sat until all lights on top of remote light up. Let go of the Sat button and pick a number from 1-15 and then press # and Record. Your remote address should change. If there isn't a smartcard in the receiver then try the menu button on the front of the receiver. If this is a secondary remote and is UHF you will have to take remote 2 to the room where the receiver is located and follow the same steps.
May 13, 2010 | DISH Network IR Remote Control
I need help with a new tv its a 65' dlp and i dont know how to set it up to the dish can you help me plese?
Congratulations on your purchase! That's a nice TV, what specifically do you need help with. What kind of dish receiver are you using?
Feb 06, 2010 | Mitsubishi CS-35505 35" TV
Nov 14, 2008 | Televison & Video
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Open Questions:
Televison & Video Logo
853 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
