Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
Kenmore super capacity 3.5 washer won't begin washing
When loaded, door closed, soap in, push the start button the lights indicate door locked, etc.' but after 20 seconds, nothing. the lights on the far right begin to flash every ten seconds or so
  • wxbully Jun 24, 2009
    does model # 41744152400 sound right? if not, where do i find the model #? also, i removed the top panel and looked behind the control panel and didn't find a troubleshooting guide....
  • Austin Don May 11, 2010
    Model number? Also, if you lift the control panel(may have to remove some screws) and tilt it back, there will be a technicians troubleshooting guide and schematic tucked up in there. The pattern of the flashing lights could indicate what to check on the troubleshooting guide. Not 100% sure though.
    Problem Solver:
  • 4 Answers
Same thing is happening with mine, what did you do to fix it?
Posted on May 03, 2010
Kenmore HE2 Won't Turn On
1) test the power cord for open 2) test the outlet box, see for blown fuse or c.breaker put some desk lamp and see if work 3) test inside of the control board if there fuse blown or c.breaker tripped 4( test the lid switch is closed, can be faulty or open replace 5) test the input voltage 115 if there are the control board faulty.
Jul 18, 2012 | Kenmore HE2 Plus Front Load Washer
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
My Kenmore 3.5 super capacity front loading washer won't start. I can hear the click when I close the door, so I know it's not the latch. The lights on the right side are all lit up (above the...
the model # would be very helpful in diagnosing the problem it usually is on a label on the rim inside the door and sometimes their is a second label on the back of it
Aug 04, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
C45072 Kenmore washer will not start. Did one
I've been going crazy with this too. Turns out all you have to do is hold down the "options" & "select" buttons at the same time until the "lock light" (the light just above the "pause/cancel" button) turns off. I guess that's why there is a line under the option/select buttons that have a lock symbol connecting the two.
Cheers!
Jun 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore front loader model 417 will not start
You have to replace the door lock(switch its all one unit) This will fix it.
Nov 16, 2008 | Kenmore 44102 Front Load Washer
Kenmore HE3t lights up ,won't start
sounds like a door lock/latch issue, its not recognizing your closing door so its not starting unit
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore super capacity 3.5 front loading washer
it may be locked. hold the "options" and "select" buttons down together for 3 seconds.
Dec 16, 2007 | Washing Machines
Washer won't start
First of all, does the washer make a distinctive "click" when you push the START button? This is an indication that your door latch is locking (or at least making an attempt to lock). Normally, however, the display would have an "fdl" fault code indicating a door lock failure if it were bad. I have seen the latch go bad and not register a fault code, though. You can perform this simple diagnostic test to see if any fault codes register: 1. Select DRAIN/SPIN 2. Under SPIN SPEED select NO SPIN 3. Then, under OPTIONS push the PREWASH button 4 times. You should hear the door latch click then "C00" will show on the display. The washer will begin a series of tests (C01...C05 - depending on options and model) by testing the hot and cold fill valves, the various dispenser compartments, followed by tumble, drain and spin. If there is something wrong the diagnostic test will abort and a fault code will be displayed. The washer usually beeps when it displays a fault code. If you attempt to perform the diagnostic and the display momentarily flashes after you press the PREWASH button the fourth time and goes out, this can also be a symptom of bad door latch. You need to perform these simple steps first in order to further diagnose. Let me know what you come up with.
Jun 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
857 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
