Question about Sony Cyber-shot DSC-W30 Digital Camera
Flash Problems Ok here is my problem. The flash on my camera won't go. I finally got the flash options to reappear but the flash is still not going. The screen has a lighting bolt symbol with a yellow blicking light and also on the camera itself. Also on the screen this is blicking, E:91:01. This is driving me crazy. Now the flash options are no longer there. Has this happened to anyone else? Please help Thank you. Patty
Re: Flash Problems
I have exactly the same problem. i have had the camera for 1year and this started to happen on new years eve. has anyone got a answer to the problem? its been a great camera apart from this problem and would hate to have to buy a new one. thanks
Posted on Feb 03, 2008
Re: Flash Problems
Go to Menu > Setup > Setup 1 > nitialize > OK
Posted on Oct 02, 2008
0 characters
3 Points
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
Using external flash
Yuo can use external flash in P, S, A and M mode.
To activate the externale flash mode, press Menu/OK and use > to cycle through the different options. Switch External Flash to On. Press OK.
Apr 12, 2010 | Fuji FinePix S7000 Digital Camera
How do i turn off my flash?
select the flash option in the menu,where u find NO FLASH option/rounded off flash icon,then click on, OK
Mar 05, 2010 | Samsung S85 Digital Camera
The flash wont work on the camera...still
1. Even if the flash is set to always ON, the flash will still not work in the following circumstances:
* When shooting MPEG movies. * When shooting in the Twilight or Handheld Twilight mode. * If shooting with the Burst or Multi Burst mode. * Shooting with Sweep Panorama. * Shooting with the Fireworks or High Sensitivity mode. * If an external flash is connected.
2. You can also Initialize the Camera. Touch the Home option. Then, select the Main Settings and then, select the Main Setting2 option. Then, select the Initialize option to OK.
3. You can also try to select the Flash Forced option to ON. The Flash Forced option is located under the Flash Settings.
Jan 10, 2010 | Sony DSC-T70 Digital Camera
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Flash off sign.
I had a similar problem, where the only option on the menu for the flash was off. I initialised the camera (reset everything), and the flash options have reappeared, and it now appears to work fine (initialise is in the settings menu from home).
Dec 31, 2008 | Sony Cybershot DSC-T200 Digital Camera
Hello i want to turn the auto flash off
Press the up arrow on the back of the camera - that seems to be the flash mode setting - select which flash mode you want - you have to hit the down arrow once to see the flash off option which is a picture of a flash symbol in a circle. Then press ok. The flash should now not fire.
Dec 10, 2008 | Olympus i:robe IR-300 Digital Camera
Sony DSC T300. Problems with the flash
I just solved this problem: to put flash, while you are in shooting mode, touch MENU, then REC Mode on the first page, and touch Normal, to take a single picture and then OK, you'll have the Auto Flash which appeares; but I never knew how to put the other kinds of flash...
Nov 03, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Help flash Nixon coolpix L11
make sure when you press the round selection button on the back of the camera flash option, you press the ok in the center of the button on the back.
it will show brief yellow AUTO in the LCD screen upper right corner for a sec.
when you are going to take a picture holding the shutter button half way down, you should see up at the right corner outside of the LCD screen a red led flashing to indicate flash is ready.
one thing to try if this is not working, find the camera reset option in the menu. after doing this you may have to reset the date & time. it will bring the camera back to default settings
on the bad side if these dont work, possible flash circuit may have failed inside the camera.
good luck!
Jun 13, 2008 | Nikon Coolpix L11 Digital Camera
K100D flash doesn´t work
My camera with the dodgy flash is holidaying in Japan as they sent it to be fixed - not sure how old your camera is but I am trying to see if this is an issue that occurs with the camera model.... given that there are only two of us to date I am thinking that we may have just struck the jackpot :(
Dec 27, 2007 | Pentax K100D Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
123 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
