Question about Vector VEC438 AM/FM/Weather Radio
Atempt programming. Power on, push menu, does not
Attempt programming. Power on, push menu, does not go to ALERT. FM radio comes on.
Returned radio to Black & Decker. They are to send a new one. Easy solution.
Posted on Jul 02, 2009
Fips codes
FIPS are 5 digit codes..the 1st two codes are for the state: the last three are for the county. This link allows you to find both state and county for your area: http://www.epa.gov/enviro/html/codes/state.html
Apr 21, 2013 | Midland Radio Midland WR11 Desktop Alarm...
How to insert the code for the radio of my golf3 /1996
ENTERING SECURITY CODE
Most vehicles are equipped with Heidelberg V or VI radios that are equipped with a theft protection program. When the battery has been is disconnected or if the radio has been removed, the radio will lock-up electronically and cannot be operated until the security code is entered. On the Heidelberg V, if the proper code is not entered in six attempts, the radio will lock-up permanently and cannot be repaired. On the Heidelberg VI, two incorrect attempts will lock the radio for about 1 hour.
The Heidelberg V may have a code assigned at the factory or a personal code created by the owner. The Hiedelberg VI has a code assigned at the factory and entered by the dealer during pre-delivery inspection. New radios come with the code printed on a sticker but not entered into memory. All codes are 4 digits. To code the radio:
Heidelberg V
  1. Turn the radio ON . The radio should display the word SAF. DO NOT attempt to eject a cassette with the radio in this mode.
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear for about 3 seconds, then the display will go blank. Release the buttons then.
NOTE If the buttons are held too long, the radio will interpret this as an attempt to enter an incorrect code.
  1. Use the first four station selector buttons to enter the code. The first digit of the code is always 1. Each time the other buttons are pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When the radio plays and displays a frequency, release the buttons.
  3. If the code was entered incorrectly three times, momentarily disconnect the battery and try again. If the code is entered incorrectly three more times, the radio cannot be coded and cannot be repaired.
Heidelberg VI
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear and remain in the display.
  1. Use the first four station selector buttons to enter the code. Each time a button is pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When SAF appears in the display, release the buttons. The radio should play and display a frequency.
  3. If the code was entered incorrectly two times, leave the radio ON for one hour and try again. This can be repeated as often as required.
Oct 15, 2012 | 1996 Volkswagen Golf
My golf mk4 am/fm/mini-disc player comes on but can't tune to any station. Only displays FM 76.0, do I need a radio code? I bought it as used from Japan 8 months ago. Please, I need your advice!
IMPORTANT NOTE:
You must have the security anti-theft code for your VW radio from the car manufacturer, or from a Volkswagen dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of programming for 2003 VW Golf radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Sep 06, 2011 | 2003 Volkswagen Golf
The alert is to loud, how can I turn down the volume for the alert?
Press the WEATHER/SNOOZE button to turn on the weather radio. Then press the "UP" or
"DOWN" volume button to select desired listening level. (Note: Turning the volume all the way
down [where no bars show] puts the radio into silent mode.)
Hope that helps resolve the issue.
Regards
Anand
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
Roady XT XM Radio Receiver: how do I change the radio station i want my xm to ...
First of all find a clear fm stn. on your car radio.Go to xm radio and push menu until fm freq. shows up.Push sel and use up or down arrows until the freq. matches that on car radio. push select again to set it.
May 07, 2010 | Delphi Roady XT XM Radio Receiver
Radio changes mode without pushing switch
I have never seen a unit change modes on its own without there being an issue with the HB Switch. The only other possibility is if there is a CB module and the weather alert is active. For a better explination, or if the unit is out af warranty, contact Iron Cross Audio (www.ironcrossaudio.com)
Sep 16, 2009 | Harley Davidson 426290 AM/FM Radio
Preset radio
In the settings menu, expand the FM radio menu and the second option is "Preset Delete". Push that and a list of all the presets comes up. Then select the ones you want to delete.
Sep 09, 2008 | Insignia Sport MP3 Player
Manual
Hi, not sure why the manual I uploaded doesn't show up anywhere so here it is in 2 posts (too large for 1 post)
Stormtracker Vector Model: VEC438 Classified: UNOFFICIAL USE AT YOUR OWN RISK!
Programing Instructions
To Program Alert:
Turn the radio on and then press:
1. Menu button (may have to hold it a few seconds) and Alert should show in the Display.
2. Press Channel/Snooze button to the right of the Menu button which will display one of the following: Voice/Siren/or Off.
3. Then use the Menu button to select between Voice/Siren/or Off.
3. After making your selection, press the Memory button to the left of the Menu button. This completes the programming of the alert function.
Example: If "Siren" is displayed on the LCD screen and you push the Memory button to the left of the Menu button, when a weather alert is broadcast the siren tone will sound and the appropriate yellow or red light will activate. If "OFF" is displayed on the LCD screen and the Memory button is pushed, the alert will not activiate.
To Program County
1. Menu button (may have to hold it a few seconds) and when ALERT appears, tap Menu button to scroll to County.
2. Press Channel/Snooze button to the right of the Menu button which will display one of the following: All/Multiple/or Single
3. Then use the Menu button to select between All/Multiple/or Single (You'll need to know the S.A.M.E. codes for the area you want to listen to, otherwise select ALL and you will recieve "All" Statements, Watches & Warnings without having to select a specific County).
4. After making your selection, press the Memory button to the left of the Menu button if ALL was selected or Channel/Snooze button to the right of the Menu button if you chose Multiple or Single (You'll see CODE01 on the display) If you chose Multiple use the Menu button to choose which Code Position to enter (01-10) then press the Channel/Snooze button to the right of the Menu button. Enter the first digit of the S.A.M.E. code then press the Channel/Snooze button to the right of the Menu button to move to the next digit of the S.A.M.E. code. Repeat this for all digits of the S.A.M.E. code. Then press the Memory button to the left of the Menu button to lock in that code. Press the Menu button to select the next code position to enter. Then press the Channel/Snooze button to the right of the Menu button, then the Menu button to select the digit of the next S.A.M.E. code to be entered. Repeat these steps as necessary to enter in all the S.A.M.E. codes you wish to enter, each time pressing the Memory button to the left of the Menu to lock in each code position. When completed entering in all S.A.M.E. codes press the Memory key again to lock in all codes and return to normal operation. This completes the programming of the County Code function.
Example:
COUNTY SAME # NWR TRANSMITTER FREQ. CALL SIGN WATTS
Fulton 013121 Atlanta 162.550 KEC80 500
Colquitt 013071 Pelham 162.550 WXK53 1000
Colquitt 013071 Valdosta 162.500 WWH31 1000
NOAA Weather Radio Frequencies
162.400 MHz (WX2)
162.425 MHz (WX4)
162.450 MHz (WX5)
162.475 MHz (WX3)
162.500 MHz (WX6)
162.525 MHz (WX7)
162.550 MHz (WX1)
Channel numbers, e.g. (WX1, WX2) etc. have no special significance but are often designated this way in consumer equipment. Other channel numbering schemes are also prevalent. Best to just tune to the strongest sounding station in your area, this radio does not display frequiencies, only channel numbers.
NOAA Weather Broadcasts
Channel Frequency
1 162.550
2 162.400
3 162.475
4 162.425
5 162.450
6 162.500
7 162.525
A link to get the S.A.M.E. codes for your listening area: http://www.nws.noaa.gov/nwr/indexnw.htm
Aug 18, 2008 | Vector VEC438 AM/FM/Weather Radio
No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Sep 24, 2007 | Delphi Roady XT XM Radio Receiver
Vector VEC438 AM/FM/Weather Radio Logo
166 people viewed this question
Top Vector Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Vector Audio Player and Recorder Expert? Answer questions, earn points and help others
