Question about Teac Televison & Video
We have severed a cable to the adapter Part No.0451B1270 output 12V. Can i repair the cable or do i need to get a new adapter? If so ,where would i look? Thanks
    President:
  • 1,185 Answers
You can solder it and use a heat shrink tubing to cover the solder joints
Heat shrink can be bought in most electronic stores
My only concern would be if the cables are not colour coded in which case you would need an voltmeter to sort out the polarities.
It the termination is in a standard push in connecter such as a mobile phone charger you would need to make sure that the positive supply goes to the inner and the negative to the outer
That is done by hooking a meter onto the wires from the adaptor and reading the voltages if they have a - sign against them you need to turn the probes around and check it again once you have the + sign in front of the reading mark the cable the red lead is on witha bit of masking tape
Then put the meter on continuity and place the tip inside the plug which goes into the Teac get someone to connect the other lead to the pair of wires leading from it and the one which shows a reading or Continuity goes to the one with the masking tape.
Posted on Jun 24, 2009
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
I have a 17" Scanport
You may buy any adapter with 12V, however, make sure the new one also matches at least the same Amp. of the monitor. Universal laptop adapters are ok to use.
Nov 07, 2010 | Scanport 17" LCD Monitor
Need to buy a replacement power adapter for this model, can you tell me what the dc output and connector size is - Zyxel P660HW-D1
Dc output is 12v and 1amp.
You can buy power adapter for Zyxel P660HW-D1 from nearest computer shop or from internet.
It's power adapter needs 12v and 1 amp.
Let me know if you need further assistance.Thanks for using FixYa.
Jun 13, 2010 | Zyxel P660HW-D1 Router
I no longer have power to my monitor; is there a way to check power source or, if necessary, to buy a new power source pack?
You can measure the adapter output with a voltmeter. The output should match the voltage marked on the adapter. This model uses a 12-volt adapter.
If the adapter doesn't have any output, it may be because the wire has broken inside the cable near the plug from flexing. It's possible to repair this by soldering on a new plug. Sometimes it's tough finding the right plug, though; some brands of equipment use oddball sizes.
You can also purchase replacement adapters. Several sources came up after a search for "scanport n9 adapter". Here's one on eBay. You'll be able to find what you need.
Mar 05, 2010 | Scanport N9 19" LCD Monitor
Need power cord
According to the Maxtor/Seagate knowledgebase information: your adapter calls for these specifications.
Model: SYS1308-2412-W2
PART NO: SYS1308-2412
INPUT: 100-240V ~ 1.0A MAX
50-60VA, 50-60Hz
OUTPUT: +12V - 2.0A
OUTPUT POWER: 24W MAX.
I Googled the part number and found that several power supply dealers sell this unit.
The Jameco Company sells a power supply with this model number.
I hope this helps you.
Circe D, pctechsonline
Jan 03, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
I need an AC 12v-5v powr adapter for a PROSCAN TV.
USE a simple laptop adapter thats whhat i did just tell the guy at local comp store 12 volts and 5 amps they should have 1 or able to order it also try a used comp store they abound on craigs list and kijiji canada
Oct 22, 2009 | Proscan 19LA20Q LCD TV
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Speakers need power scource
Yes, a general purpose 12V DC power adapter can be bought easily from your local electricals shop.Should not cost much.
Alternatively you can look for a cordless phone or CD player adapter with 12V DC output.
Mar 16, 2009 | Audio Players & Recorders
Need cable and power supply
Power Adapter Input AC 100-240V, 50-60Hz, Output DC 12V/4.0A
This may help. Just make sure you have the right dc output mentioned on the back of your monitor (12v4a or 12v5a) if any lower your monitor will shut off after displaying for few seconds then electrical smell will come out from your ac/dc adapter. When it overheats it shuts off.
http://www.alibaba.com/product-gs/51210391/TFT_AC_Adapter_for_12v_4a.html
Manual
http://www.princetongraphics.com/site/download/manuals/vl1716.pdf
Jun 14, 2008 | Princeton Digital VL1716 17" LCD Monitor
Televison & Video Logo
Top Teac Televison & Video Experts
bengsoon Neo
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
