Question about LG Dishwashers
I HAVE A HUMMING MOTOR. ONLY YEAR AND A HALF OLD.
  • 6,784 Answers
HI, it is possible that this motor was defective when it left the manufacturing plant. This AC hum you are hearing is coming form the motor and, this is a sign of damaged internal motor windings. you will need to replace this motor asap.
Posted on Jun 24, 2009
  • Michael Masters
    Michael Masters Jun 24, 2009
    ***(This should be covered by the warranty and, it should be a free replacement)
10 year old carrier 38yra030 fan not turning only a hum
The hum is probably the compressor running. Could be the capacitor or a bad fan motor. A bad motor will usually trip the breaker.
Aug 02, 2014 | Heating & Cooling
Pool pump motor noise/hum would come and go, noise was not constant nor continuous, every few seconds would go from high to low sound but volume would seemed constant. was not an extraordinary noise and...
The problem is the starter capacitor on the back or top of motor depending on make. The capacitor is round and black and about 3 inches long and the diameter of a half dollar. it will have 4 wires with quick disconnects on them, unplug and replace capacitor and put wires back on the same way they came off old one. as far as the noise, the bearings are starting to wear and can be replaced when you get tired of the noise. you will have to take it in to have the bearings replaced.
Aug 31, 2011 | Emerson Pool & Spa
Frigidaire electric dryer. 1.5 years old, stopped turning and only hums when button is pushed
Hello
Is it a pleasant sounding hum, like the sound of a motor running? If so , probably your belt broke.If that hum goes on and on for several minutes, it's definitely belt. Bad motor or start relay, would cut out quickly. Either way ,youv'e got to pull out machine and pull off back to inspect.
Aug 18, 2011 | Frigidaire GLEQ642A Electric Dryer
We have a kenmore 90 series dryer. Probably 6-8 years old. When you press the start button it makes a humming noise but won't start. Any ideas what it might be?
chance it could be the motor is to weak to turn the drum or it is bound up by the belt or bad rollers check breakers if half tripped this can keep motor from fully engaging
Nov 13, 2009 | Dryers
The dryer is 8 years old. When I push in the dial
the motor is not turning and that's what is humming,you either have a bad motor,something stuck in the blower usually a sock or the belt is stuck
Nov 02, 2009 | Amana DLE330RAW Electric Dryer
My garbage disposal is not working. Making humming sound when turned on. I tried to press the red reset button but to no avail. Also tried to turn the little dosposal wrench in bottom hole of disposal but...
It is most likely plugged up there is a clap with a butterfly bolt that you turn counter clockwise remove the clamp and have a trash can under it and wiggle it to remove the lower half of the disposal, when it comes off dump it out and clean with fresh water. Then with hands free of the pump turn the disposal back on, it if still hums the motor is bad and you will have to replace..
Sep 13, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
LG DLE5977W dryer has stopped and developed a motor hum. How can I fix it?
I am assuming that the hum indicates the motor is running but the drum is not turning.  Possibly a broken drum belt however the check filter warning is indicating low air flow so the blower wheel could be broken at the connection to the motor shaft.
Jun 01, 2009 | LG DLE5977 Electric Dryer
8 year old Whirlpool gas dryer will not run - it just hums when put on any setting. Is this a motor problem or the belt?
it sounds like the motor....generally before the motor dies the motor will become louder and louder, and when its hot and you try to restart it it will make a loud hum as it tries to turn
Dec 31, 2008 | Dryers
Erratic goodman GMPN 100-4
sound like you have a bad fan motor
Dec 04, 2008 | Goodman CPLE24-1 Air Conditioner
Won't Run
The humming usually means the motor is trying to start but can't either because of weak windings or not enough electrical power. Need to check the motor control.
Mar 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dishwashers Logo
183 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
