Question about Brother MFC-8460N All-In-One Printer
Clicking noise with MFC-8640D
I have a brother MFC - 8640D - I get a large clicking noise when I turn on the printer, and then I get paper jams - and when it goes to print, it makes the same loud noise..What is problem?
  • lmoe Jun 25, 2009
    Guru,
    The grinding noise is there even with the toner and drum taken out. It appears the paper comes up through the toner, but the paper gets stuck in the toner area - and the roller taking the paper up to the final tray is not working.
    President:
  • 2,306 Answers
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Posted on Jun 24, 2009
  • Craig Gillette
    Craig Gillette Jun 25, 2009
    If the noise is still there and paper jams at the rear, it sounds like one of the fuser gears has broken. I've seen so many of these because of the heat always present in the fuser. The gear is around $10.00, but you have to remove and take apart the fuser to replace it. Part number for the gear is
    LJ7416001, if you want to attempt the repair yourself.
How can I scan files to pdf using Brother MFC-8640D
You will need to open the control center program which is installed when you install the printer on your computer.
Start, all programs, Brother, control center. Click on configuration then scan then file (or which ever you normally scan to). There are two tabs at the top, change the file type at top of each tab to pdf and press ok.
Jul 03, 2010 | Brother MFC-8640D Printer
Im trying to open my printer to get a paper jam out. i dont know how nto open it
The front cover with the brother logo will open. then you can pull the toner/drum assy. out and clear the jam. Steven 818-888-0006
Feb 21, 2010 | Brother MFC-8640D Printer
I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Jan 15, 2010 | Brother MFC-8640D Printer
I have a Brother mFC 8640D - paper feeds through
The black exit rollers on top get slick from the paper and toner, they need to be cleaned with a damp rag. You hold the rag against them 1 at a time and open and close the front door so they will rotate while you hold the rag on them. Should help the paper exit.
Oct 02, 2009 | Brother MFC-8640D All-In-One Laser Printer
Clicking noise with MFC-8640D another case
Usually it's because the paper is too tight in the feed tray. The paper length tab on the end away from the feed roller is too tight. If you cant rotate the gear on the paper tray and lift the paper, it's too tight for the machine to lift.
Aug 12, 2009 | Brother MFC-8460N All-In-One Printer
I have a Brother 8640D all in one printer. There is a grinding noise when I go to print. The paper is going through the drum and they getting stuck before coming up and resting on the try where I pick up...
if its going through the drum, then its stopping at the fuser area.
you have a broken gear on the fuser. the fuser will need to be repaired. approx. cost for fuser repair will be about $75.00
Jun 25, 2009 | Brother MFC-8640D Printer
Need paperport software for MFC-8640D i tried to download software drivers from Brother site as i lost CD but unable to get drivers or software for scanner ie paper port software can you please help me to...
Hello Jim Try getting your software from www.cnet.com I pointed another FixYa user in the same direction this Morning and they pressed the Blue FixYa button after download PaperPort for their Brother Machine and well pleased.
I hope this helps you too!
Good Luck,
Paul 'W'
Jun 03, 2008 | Brother MFC-8640D Printer
Phantom paper jam
Same problem here. I'm googling around looking for ideas.
Sep 07, 2007 | Brother MFC-8640D Printer
Brother MFC-8460N All-In-One Printer Logo
2,266 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
