Question about Kenmore Elite Oasis 27052 Top Load Washer
My Sears 500 washing machine stops in middle of wash cycle.
It will be full of water and won't restart. I try moving clothes around, moving to other settings. Sometimes I close lid hard and it starts again. Sometimes I turn a few settings and turn and reset cycle knob and it will start again. If I do nothing the the machine stays full of clothes and water all day. Other times it works fine. Whats wrong?
  • 351 Answers
Timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to whirlpoolpartssurplus.com call .. ask for mark
Posted on Jun 24, 2009
Water goes in it washes for little while then buzzer starts before wash cycle ends
Hi Gina,
When your machine stops during the cycle does it beep & hold some of the wash progress lights on?
This is how it displays where the fault is coming from.
The motor controller is the most common for this type of fault.
Thanks
Damien
Nov 07, 2015 | Fisher and Paykel Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Whirlpool GSQ963ILL0 top load washer. Stopped dead in middle of agitate cycle. I fear I overloaded it. Now just sitting, full of clothes and water, and won't do anything. Any advice?
Hi jim_zervas,
Firstly, unplug the machine. Then first thing to do is remove the clothing, and bucket the water out. Then run the machine again.
Let me know what happens?
Kind Regards
JEDEMEYER1
* Please accept my solution if it solved your problem
Sep 03, 2011 | Whirlpool GSQ9631L Top Load Washer
Machine stops in the middle of the cycle. I had only a robe and pair of pajamas in the tub and water level set at medium. I moved it to "spin cycle" to get the water out of clothes, but nothing...
Same problem as yours. The GE repair man is at our house right now for this problem. It's the motor, and the "special motor and clutch package" has to be specially ordered.
Jan 04, 2011 | GE Profile WPRE8100G
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Apr 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
1999 Neptune washer stopped in middle of cycle
sounds like the belt from the ele. motor to the wash drum broke. This can happen from over loading the washer or just wear and tear (lots of loads). Did you save the owners manual? It will give you a break down of the machine and contacts to get parts.
Apr 24, 2009 | Washing Machines
Washer stopped after wash cycle
The lid switch is the culprit. Push down on the lid it should start. It needs to be adjusted . the tab on the lid is not activating the switch. Try triming the door bumpers.
Apr 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Kenmore Elite Oasis 27052 Top Load Washer Logo
332 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
