Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Have Mastercool. 1/3 of media is not getting water.
How do I remove the upper water jacket to get at the distribution tube?
After looking at an exploded view in an operators manual, I found on another site and reading the "how to replace" media section, no mention was made of anything that fastens the water jacket assembly to the media. The problem was calcification, due to Arizona's hard water that had literally superglued the water jacket to the media. Using a flat bar and some gentle persuassion, I was finally able to lift one side end of the water jacket and slowly work my way to the other side. As I suspected, the PVC water tube was almost totally clogged with calcified debri that had been sucked up by the water pump. As a preventative for this in the future, I fashioned a filter bag from a piece of nylon window screen and placed that under and around the pump section and tied it off just below the motor assembly. Hope this helps someone else. ts
Posted on Jun 25, 2009
Mastercool doesn't seem to be getting enough water circulating
If the pads are old replace them. Take a panel off and look at the water dist. tubes if plugged, best method to remove it and use compressed air blow from the center, and let it rip, the basket maybe dirty. Good luck
Jul 02, 2011 | Mastercool 67471 Evaporative Cooler Air...
Need to replace heater core? how do i remove old one and replace new one?
Here are the instructions with a diagram. If you need to enlarge the diagram save it to your picture files and then enlarge it there.
1. Disconnect battery ground cable, then drain cooling system. See: Engine, Cooling and Exhaust\Cooling System\Service and Repair
2. Disconnect heater hoses from heater core. Plug heater hoses and core fittings to prevent coolant spillage.
3. Remove bolt located below windshield wiper motor, attaching left end of plenum to dash panel.
4. Remove nut attaching upper left corner of evaporator or heater case to dash panel.
5. Disconnect vacuum control system supply hose from vacuum source, then push grommet and hose into passenger compartment.
6. Remove all instrument panel retaining screws and pull instrument panel back as far as possible without disconnecting any wire harnesses.
7. Loosen right door sill plate and remove side cowl trim panel.
8. Disengage temperature control cable housing from bracket on top of plenum. Disconnect cable from temperature blend door crank arm.
9. On models w/Automatic Temperature Control (ATC) , remove cross body brace and disconnect wiring harness from temperature blend door actuator and disconnect ATC sensor tube from evaporator case connector.
10. Disconnect vacuum harness at vacuum connector near floor air distribution duct.
11. Disconnect white vacuum hose from outside recirculating air door vacuum motor.
12. Remove two hush panels.
13. Remove one plastic push fastener retaining floor air distribution duct to left end of plenum. Remove left screw and loosen right screw on rear face of plenum. Remove floor air distribution duct.
14. Remove two screws from rear side of floor air distribution duct to plenum. To remove right screw, it may be necessary to remove the two screws attaching lower panel door vacuum motor to mounting bracket.
15. Remove push fastener attaching floor air distribution duct to left end of plenum, then remove floor air distribution duct.
16. Remove two nuts located along lower flange of plenum.
17. Carefully move plenum rearward, so that heater core tubes and plenum case upper stud clear openings in dash panel, then remove plenum from vehicle by rotating upper portion of the plenum forward, down and out from under instrument panel. It may be necessary to carefully pull lower edge of instrument panel rearward while plenum is being removed from behind instrument panel.
18. Remove retaining screws from heater core cover, then the cover from plenum assembly.
19. Remove retaining screw from heater core inlet and outlet tube bracket.
Heater core removal and installation diagram.
20. Pull heater core and seal assembly from plenum assembly.
21. Reverse procedure to install.
Jan 06, 2011 | 1993 Mercury Grand Marquis
Aprilaire 550 Changed the water panel and the water distribution panel. There is a little u-shaped cradle for the feed tube. But the feed tube is not secure and sprouts water everywhere. Now what?
On the water distribution panel there is an "L" shaped nozzle that the water hose plugs into, this directs the water into the top of the distribution panel. Your's is obviously missing. Look for this part on the parts you removed.
Dec 28, 2010 | Aprilaire 550 Humidifier
Drilled hole in intake manifold at upper radiator outlet
Did the bolt break off flush with the top of the hole? or if you remove the cover is some bolt sticking up? if there is try and use vice grips to get ahold if the bolts if it is flush then drill the bolt out and re-tap the hole. Way cheaper and likely less work too...
Nov 02, 2009 | 1997 Dodge Ram 1500 Club Cab
We bought a Bonaire cooling system at yard sale, it leaks water after it is running for awhile, plus it sprays water out the front
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
Jul 17, 2009 | Mastercool 67471 Evaporative Cooler Air...
The pads are not wet even if I run the pump
The distibuter pipe that comes off the pump is prone to getting clogged with mineral deposits that have to be cleaned out from time to time. But I would check to see if your pump is still working. They only last a couplre years. Turn electric off to the unit, take off the side panels, look in the reservoir and you will find pump. Now disconnect the tubing that goes into the distibuter and hang that end outside of the unit, turn electric on and pump on for just a couple seconds. Return to the unit if water is pumped outside then your pump is still good. Which means the distributer line needs thorough cleaning. If no water came out you probably need a new pump. Good luck
Jul 13, 2009 | Mastercool 67471 Evaporative Cooler Air...
My mastercool blows out hot air upstairs
The one on top probably has no water in it or the pump is not working. Look closely at the front to ascertain if water is being pumped.If not turn electric off and remove one of the side panels with a 1/4 driver. In the reservior there should be water. If not you need to turn water on to unit or adjust/replace float. Also is it's warmer than 100 degrees outside you're unit might be fine...it has limitations.
Jul 09, 2009 | Mastercool 67471 Evaporative Cooler Air...
AC pad not fully getting saturated with water
1. Make sure the pump is getting plenty of water.
2. Make sure the pump is working.
3. Check the pvc pipe with drip holes are not plug. (above the pads )
4. Check the pads directional arrow that should be facing up. When pads are initially installed you can see arrows on the pads. The arrows should be in the up direction. That will allow the pads to get saturated more efficiently.
I hope these steps help you.
Jerry,
Apr 29, 2009 | Mastercool 67680 Evaporative Cooler Air...
Summer
If it was not drained for winter, do so and then remove all scale from the pan, pump inlet screen, etc. Replace the pads if they are scaled up and remove any scale from the louvered panels. WITH THE POWER OFF, check the belt for cracking and check to drive motor and blower wheel bearings for smooth operation, oil bearings with oil ports. With clean water in the sump, a good drive belt, clean pump screen and clean pads, the unit is ready to power up and run test the float action/shut-off, water distribution through the arms, belt tension (just enough to prevent slipping). These units work best when they can fully evaporate the water, so let the air flow out as fast as it come into the cooled space to maximize the evaporative effect. Also note, these unit must be level to work properly.
Apr 27, 2008 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
363 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
