Question about Macplay Baldur's Gate II: Shadows Of Amn for Mac
Does Baldur's Gate II install on an intel mac running 10.5.7?
My original BGII disc 1 is damaged. I don't want to replace it if I can't play anyhow. I'm also interested in IceWind Dale and Neverwinter Nights. Do any of these play on the intel macs?
    If they do play, can you offer any advice on how to find a new disc to replace my faulty one?
  • 19 Answers
There's currently no reports of BG2 not working on the new updates of OSX
So it "should" work. Providing your mac is above the original system requirements the game suggests.
Posted on Jun 26, 2009
I purchased a used copy of "Baldur's Gate: Dark Alliance II" for the original Xbox on Ebay. It played great until Azorgiath's (?) Cellar then the music cut-out, I could see my character &...
It sounds like a bad disc, if you have a few extra bucks that you are willing to spend ask around to see if you have a local store that offers a disc resurfacing service. Usually they wont cost you more than $5 and if it is only minor scratches, the disc will be good as new. If that doesn't fix your problem and this is the only game that freezing issues occur on it is likely you have a corrupt disc.
Mar 11, 2011 | Vivendi Universal Baldur's Gate: Dark...
HOW TO UNLOCK MY MAC BOOK I FORGOT MY UNLOCK CODE
When working with Mac OS, you're required to use an administrator password to install just about anything. If you forget your password, or if you're using a hand-me-down computer and you don't know the previous owner's password, there is no workaround to bypass the admin password. Your only solution is to reset the password with the discs the computer came with. This project has two phases. Changing the admin password is the first step, but you must also follow through and change the keychain login as well.
Instructions
Things You'll NeedMac OS X install CDResetting the Administrator Password in OS X
1 Locate the Mac OS X install disc your computer came with. If you don't have it, you may be able to get another one from Apple by calling (800) SOS-APPL. (You will most likely have to buy another one.) Insert the disc into the optical drive.
2 Restart the computer while holding down the "C" key. A "Utilities" or "Installer" menu will appear, depending on which version of OS X you are running. Select "Reset Password."
3 Select "Macintosh HD" from the available volumes. On the drop-down menu, select the name of the original administrator account. Do not select "System Administrator."
4 Choose a new password and enter it in the two fields. Click "Save."
Resetting the Keychain Password in OS X
1 Go to the "Go" menu from the Finder. Select "Utilities" and scroll down to locate "Keychain Access." Double-click it.
2 Select "Keychain List" from the "Edit" menu.
3 Highlight the "login" keychain and delete it. The next time you log in to the account you can save your new password.
Don't forget to backup your files before you change anything. Your files shouldn't be affected, but it's better to be safe than sorry.
Thank you and Goodluck
Nov 01, 2010 | Apple aluminum 13-inch MacBook laptop-...
Will Macplay's Baldur's Gate 2 run on this computer?
Baldur's Gate is roughly ten years old so it was made to run on hardware that would be a fraction of what you have. If it doesn't play it certainly wouldn't be because of your hardware.
I also found this site with users running it on much older Macs:
http://www.versiontracker.com/dyn/moreinfo/macosx/12466
(see the comments toward the bottom)
Jun 09, 2010 | Macplay Baldur's Gate II: Shadows Of Amn...
After I installed Baldur's Gate II on my MacBook, when I tried to start up the game, I got the error "An Assertion failed in ChDimm.cpp at line number 645 Programmer says: Unable to Open...
I love that game dude, but it's old and sadly depending on the OS you have, it doesn't run. You're probably using Mac OS X, or even Mac OS X Snow Leopard and BG2SoA doesn't run on Mac unless you have bootcamp.
Mar 20, 2010 | Macplay Baldur's Gate II: Shadows Of Amn...
Can i play Civ II on my brand new mac?? or do i need an older mac
Civ II is a fairly old game. It seems that your PC runs Windows XP or earlier. It is likely that the site you read was correct, and your computer is too new to run it. However, you may be able to get another newer version of Civ for Mac, but check the system req's for any game you try to install. I don't know for sure if this is the case, but I hope this helps you somewhat.
Jun 01, 2009 | Macsoft Civilization 2 Gold for Mac
"Please Insert Disk 2"
try cracking it..
dont know what crack is? :
1. insert disk..
2. open my computer and find the drive where the disk is inserted,
3. right click on the selected drive and in it find the folder crack.
4. copy the image of the game inside the crack..
5. and paste it to the original folder in your computer..
hope this will help you
Mar 30, 2009 | Macplay Baldur's Gate II: Shadows Of Amn...
Macplay baldurs gate 2 disk ejects before loading
I manage to start the game on Mac OS X Leopard. I have burn the CDs (CD 2 - 3 - 4, because you need them to play) and than, to solve the problem of "ejects of the disk" I have also mounted the image dmg. Then to start the game I insert the CD 2 for example, then I mount the disk image dmg (the same that I have burn on the CD) e then I open a file .bif in the folder CD2/Data/
The computer open this file and start the game!
Gimmy
Dec 28, 2008 | Macplay Baldur's Gate II: Shadows Of Amn...
Installation problem
hi
it is coz of old drivers or ur system does not meet the requirments of the game
Nov 07, 2008 | Macplay Baldur's Gate II: Shadows Of Amn...
Baldur's Gate II Keeps crashing!
uninstall anything you dont need is a good start. If, when you have done this, it persists, then reinstall the game. If it still does it, check if all the system requirements match to the RECOMMENDED, NOT MINIMUM. Some games wont actually work on minimum. Plus, some games dont work on some operating systems.
Please rate me.
Aug 01, 2008 | Macplay Baldur's Gate II: Shadows Of Amn...
Macplay Baldur's Gate II: Shadows Of Amn for Mac Logo
921 people viewed this question
Top Macplay Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Macplay Video Game Console and Game Expert? Answer questions, earn points and help others
