Question about Whirlpool Refrigerators
Vacuumed under my working side by side Whirlpool fridge and now it doesn't blow cold air?
  • 1 more comment
  • knikulin Jun 24, 2009
    The fan is working fine and blowing air into the freezer and fridge, the air is just not cold.
    The fan is working and the compressor did feel hot to the touch.
    I will try that tonight. ~thanks
  • 351 Answers
Hmmm, that should of improved it inless you bent the fan blade in the back or something....
Posted on Jun 24, 2009
  • 1 more comment
  • Mark Nichols Jun 24, 2009
    is the fan by the compressor running? is the compressor running if so is it hot to touch?
    i would unplug it for about 1-2 hours if you can, then plug it in and tell me. whirlpoolpartssurplus.com Mark
    pulling it away from the wall and giving the compressor air would not be a bad idea,
Why is my fridge warm
There is a fan and a damper the blows cold air from freezer to refrigerator compartment. Damper is stuck closed or fan is not working is a good starting point.
May 07, 2017 | Whirlpool Refrigerators
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
The blower in frig is not working, frig is warm freezer is working fine, we have vacuumed all area & unplugged for serveral hours. please tell us what else we can try.
all it does is blow cold air from the freezer into the fridge section,open the freezer door,you should hear the fan blowing,no fan fridge will be warm bad evap fan motor,also send the brand name and model number,some machines have dampers in them if the damper is bad it blocks the cold air from entering the fridge section,send model number and brand name,
Sep 25, 2011 | Refrigerators
Whirlpool fridge not blowing cold air but freezer
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
May 28, 2010 | Refrigerators
Fridge side works, but the freezer doesn't
Hi, there is a common fault with these side by side models, the electronics fail in many ways. The first sign of failure is either due to the compressor not working or the 'evaporator' (the cold bit) ices up and air can't pass through it to cool the freezer and fridge.
You can buy a kit to repair the boards for about £30 on ebay
Look for Whirlpool repair
An engineer would charge £200 +
Hope this helps
regards
j
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile Artica side by side - freezer not cold enough
replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
Aug 10, 2009 | GE Profile PSI23NCR Side by Side...
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
Whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Jan 05, 2009 | Whirlpool GC5SHEXNS Side by Side...
Freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
51 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
