Question about Acer Aspire 5610-4648 Notebook
Email attachments that say you need a new app to open on Asus transformer pad 3000
Can't open internet brawser IE.its open to asus.com
Just change the settings. If you are getting to the "asus.com" site then the browser is working. If you want it to open to a different site, tap on the 3 dots in the upper right portion of the page. This will open a new dialog box. Go to the settings and from there you should be able to set a new homepage to open to.
I do not know which browser you are using, but recommend google) Download the app from the Play Store https://play.google.com/store
IE (Internet Explorer) does not work on ASUS tablets as it is windows based and your tablet is running Android operating system. stick with Google or maybe Firefox browsers.
J
Apr 25, 2015 | ASUS Eee Pad Transformer TF101A1 Tablet...
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
My asus transformer pad isn't charging ?
IF cable is not an fault, try to replace the power adapter, even if fails try in the desktop or laptop rear USB ports. Hope this may helps U
Feb 28, 2014 | ASUS Transformer Pad TF300 10.1" 32GB...
Will installation of a asus miracast dongle allow me broadcast from my asus s400ca to my LG TV wirelesslyasus asus support
ASUS Miracast Dongle lets you experience Full HD wireless entertainment and lets you stream your favorite movies, videos and photos through to any compatible large screen TV. Easy to set up and play, Miracast Dongle supports dual-band wireless (2.4GHz and 5GHz) and HDMI to ensure no latency in signal transmission.
  • Compatible Model ASUS MeMO Pad HD 7/ME173X
    ASUS MeMO Pad FHD 10/ME302C
    ASUS MeMO Pad FHD 10 LTE/ME302KL
    Nexus 7 (2013)/ME571K/KL
    ASUS Transformer Pad/TF701T TF103C
    ASUS Fonepad 7 /ME372CG
    ASUS MeMO Pad 10/ME102A
    ASUS MeMO Pad 8/ME180A ME181C ME181CX
    ASUS MeMo Pad 7/ME170C ME176C ME176CX
    ASUS Fonepad Note6/ME560CG
    ASUS FonePad 7/FE170CG
    ASUS FonePad Pad 7 Dual SIM/ME175CG
    ASUS The new Padfone Infinity/A86
    ASUS VivoTab Note8/M80TA
    ASUS Transformer Book/T100
    ZenFone/A400CG A450CG A500CG A501CG A500KL A600CG
    PadFone mini/PF400CG
    Padfone S/PF500KL
ASUS Miracast Dongle Specifications
Feb 06, 2014 | Computers & Internet
How to put pictures on facebook from a asus tablet
Download the facebook app, and there's probably a upload photo button somewhere in the app, usually when posting a status or on your wall. Then, you can upload from your photos.
May 27, 2013 | ASUS Eee Pad Transformer Prime TF201 10.1"...
Error 101
Found this with a google search, try this:
To fix it if you go to Settings > Accounts & Sync > Select the Gmail account you originally setup, top right of the screen hit "Remove Account".
Now open the Market, it will prompt you to Sign in, Sign in using the same Gmail account as before and fingers crossed it will let you download apps again.
Mar 11, 2013 | ASUS Transformer Prime Eee Pad 10.1...
Need Asus EEE Pad Transformer Manual in English
Here is a link to ASUS support for you pad. you will need to put in the OS, and then scroll down and you will see manual. In my case 43 were available. Eglish was the second one down. Follow the instruction on the page, it looks like you have to do this via your phone.
http://support.asus.com/download.aspx?SLanguage=en&p=20&m=Eee+Pad+Transformer+TF101&hashedid=gHh4q7I8dvWJzhdV
Hope this helps
Mar 21, 2012 | ASUS Eee Pad Transformer TF101A1 Tablet...
Acer Aspire 5610-4648 Notebook Logo
54 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
