Question about Karcher 2500 PSI Pressure Washer
2400 psi pressure washer... what oil is used in the piston/bearing housing?
  • 174 Answers
Hello cgreers:
I am assuming you are speaking of the pump pistons, not the motor.
10W30 oil is OK but you must be sure it is NON DETERGENT. Also be sure the reservoir is only 1/3 to 1/2 full.
Posted on Jun 28, 2009
I have a Winner 108 pressure washer. I think it's owned by Karcher. I was dismantling it to get the faulty run capacitor out, and when i pulled the housing off, it leaked out about 50ml of oil. What oil,...
The oil is there to lubricate the pistons as they are pushed by the swash plate. This oil is usually normal multi- grade engine oil. In bigger machines, grade 90 oil is used. If you are not sure, get some multi-grade and 90 oil, and test with your hand. It should be very easy to see the difference. When filling, see that at least the pistons with the springs are getting wet with oil. Important not to overflow the oil. This overflow, might cause pressure and oil will get out of the seals and mix with the water. On the other hand, the seals must be renewed once you opened the oil side. This because water can enter through the seals and mix with the oil.
Regards,
MG.
Jan 15, 2015 | Karcher 1750 psi Electric Pressure Washer
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Gas mixing with oil even while motor is running. whats causing this?
if its smoking alot oil ring on piston stuck in oil passing the piston engine will smoke
Feb 11, 2011 | Karcher 2500 PSI Pressure Washer
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Karcher 2400 psi washer- no pressure
if the water is flowing
the valves need to change
if no water pistons in pump need to change.
Jul 22, 2009 | Karcher 2500 PSI Pressure Washer
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 25, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer that leaks oil through the air breather
Most likely your air filter is plugged or dirty, or the crank case vent valve needs to be cleaned.if it still does it check that the oil level is at the full mark, if overfilled it would cause the same problem.
Jun 22, 2009 | Karcher 2500 PSI Pressure Washer
Coleman Pressure Washer Problem
your pressure relief valve is stuck open. i know that may sound too simple but it depends on if you use a cleaner with the water when your using it , not flushing with clean water after use can cause the housing of the aluminum housing of the relief valve to corrode. the valve can't move back and forth as it should because the o ring won't slide.
Jun 20, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
425 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
