Question about Peg Perego Vespa Scooter
Need to replace front mudguard on vespa px 125e 2003 modle
    Problem Solver:
  • 16 Answers
To replace the mudguard is easy enough but takes a good while.
Remove case from the handlebars (mirrors first then screws and split).
Remove the bolt that holds the handle bars to the steering column and remove the handlebars.
At the top of the steering column you need to unscrew the round nuts that tighten the steering column.
You need to disconnect the brake hose and cable (later you will need to bleed and refil the brake fluid).
Then you need to lift the frame up from the front so that the steering column slips out, be careful not to lose the bearings.
The mudguard is held on with (i think) 2 bolts. remove these and then lift the mudguard up the steering column. drop the new one in it's place and put everythiing back together in the reverse order you took them off
Posted on Aug 23, 2009
  • 41 Answers
Follow this link. Mainly for the older 'P' series but very very similar.
http://www.vespamaintenance.com/body/forks/index.html
Posted on Apr 28, 2011
How do I remove the front mudguard on a Vespa PK125
Hi, Stephen for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to remove front mud guard scooter forums com
Vespa PX front fender mudguard from Scooter Center
VESPA PK 50 Service Manual
https://www.oemmotorparts.com/oem2.asp?M=vespa
VESPA PX 125 T5 Operation And Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 24, 2017 | Vespa Motorcycles
How to decrease the exhaust sound of Vespa PX150
Hi, Saleh that all depends on your current muffler if it's a stock OEM muffler that is in excellent condition then you would have to seek the advice of a muffler expert to fabricate something for you but if it has rusted holes or has a broken baffle or you have an aftermarket performance muffler installed then a new OEM muffler would quiet down the offending noise..
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa Vespa PX 150 exhaust question
Exhaust BGM PRO BigBox TOURING BBT Vespa PX80 PX125 PX150 Sprint GT GTR...
VESPA PX 150 USA Workshop Manual
PartsSchematicP PX PXE STELLA 125 150 200
VESPA 150 Operation And Maintenance
Apr 04, 2017 | 2005 Vespa PX 150
Rear incadicater have stopped working on vespa px 125
The electric connectors of the rear blinkers are on the front bottom of the side panels and need to be clean blank metal (sandpaper) and put in the hole very tightly - use also some W-40 contact spray
-see photos
rear-incadicater-stopped-working-vespa-sxbikrkt5iu1vmjxkjitshw2-5-0.jpg rear-incadicater-stopped-working-vespa-sxbikrkt5iu1vmjxkjitshw2-5-2.jpg
Jul 19, 2012 | 2005 Vespa PX 125
I have just bought a 1978 Vespa 125 px I can't get leaded petrol what can I use ?
The old PX from 1977-1981 need a 2% 2T Oil mixture in the Petrol or it will be broken in an instant....!
The mix should always be 2% oil = ratio 1:50
for 1 Gallon Petrol = 2,6 oz oil
(1 liter =20ml / for 5 liter =100ml of 2stroke oil)
- you better get an oil measuring jug to be sure -see photo
leaded petrl is not needed
Jul 18, 2012 | Peg Perego Vespa Scooter
Vespa px side panels
the newer PX have the side cover latch under the seat
- see picture
the older ones have them at the lower front of the side covers
- see picture
Jun 03, 2012 | 2008 Vespa PX125
Gears clunk when change on vespa px 125
don't worry -the clunk noise is typical when changing gears on a Vespa 125 PX
- it is due to a very old fashioned construction in the gearbox (1940ies) see pictures:
you have to get used to that or change to a newer automatic type Vespa....
May 22, 2012 | 2005 Vespa PX 125
How do i replace brake pads on vespa px 125
if you have experience as a mechanic you can do it by yourself, but otherwise it is better to have it done by a pro, as the brakes are a main safety item....
How to replace Vespa drum brakes NYC Scootering New York City scooter news...
replace-brake-pads-vespa-px-125-hrvlixid2vnvvtoada3i3rpn-5-0.jpg replace-brake-pads-vespa-px-125-hrvlixid2vnvvtoada3i3rpn-5-2.jpg replace-brake-pads-vespa-px-125-hrvlixid2vnvvtoada3i3rpn-5-5.jpg
Feb 23, 2012 | 2011 Vespa PX 125
Vespa px lights do not work
check the connection of the bulb ensure itis fitted correctly also check fuses it maybe that the bulb for the lights has blown, it is common that the brake light is on a seperate fuse for safety.
Dec 02, 2009 | Peg Perego Vespa Scooter
How easy is itto change a mudguard on vespa et2
The mudguard is held on with (i think) 2 bolts. remove these and then lift the mudguard up the steering column. drop the new one in it's place and put everythiing back together in the reverse order you took them off.
Feb 26, 2009 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
2,499 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
