Question about Teac AG-V8060 Receiver
Teac stereo receiver model # AGV8520
When I turn it on, it reads the word protect in the window
Fan motor seems weak, must be started by flicking it with a finger. Know how to replace the fan motor, can it be done where it sits or does the whole board need to come out with it.....?
Posted on Jun 21, 2008
You need a new amp in it
Posted on Mar 22, 2008
  • 45 Answers
One or more output channels has dc voltage present or the protection circuit itself is at fault. Protection ckt keeps speaker destroying DC from reaching the speakers. Connect a dc meter before the speaker relay(s) to isolate which channel if any, is bad. The protection ckt has a small value electrolytic cap connected to the power supply that needs to be checked. Small so that as soon as power is turned off the relay(s) release. This cap will fail causing this error. Measure the AC ripple across this cap, over a couple volts, replace. Also this error could be caused by a missing supply. Inspect all heat sinked parts and other parts for bad connections.
Posted on Nov 05, 2007
Why does my Teac ag h500 keep saying protect?
Hi. Unfortunately the protection circuit is saving your speakers from a fault, most likely one side of the amplifier in the unit is defective.
This needs an engineer.
Service manual is here if you need it. TEAC AG H500 Manual AM FM Stereo Receiver HiFi Engine
Oct 02, 2016 | Teac Audio Players & Recorders
I have this issue, my teac ag d7900 which itself off to standby and when I switch it "on" again, it says protect and shut itself down again
Right. This means that either you have a short in your speaker cable somewhere or the short-detector circuitry inside has problems. Disconnect all speaker cables and turn the receiver on. If the symptom goes away, turn the receiver off again and connect one of the speaker wires. Repeat until it starts to go into protect again. When it does, the last speaker you hooked up has a short somewhere in the wire.
If protect always comes on, you'll need to get the unit serviced.
Jun 28, 2015 | Teac Audio Players & Recorders
Where can I get a manual or any info at all for our vintage TEAC AG-78 AM/FM STEREO RECEIVER? Age..?
May 16, 2015 | Teac AG-780 2 Channels Receiver
The stereo plays for a few minutes and then turns itself off
hello it sound like the output transistor has blown or a capacitor has swelled up
Sep 16, 2009 | Teac AG-D8900 Receiver
When im playing my vinal it come out in stereo but when i download it to the computer it plays in mono what im i doing wrong the system i have is prolectrix usb three speed turn table hope you can help...
if you open edit/preferences in audacity you can select the stereo option, make sure that windows/control panel/audio out is set for your pc sound system and not the usb turntable, as was in my case, there is no speakers on that.. jacko
Mar 05, 2009 | Teac DRH300DAB Receiver
Receiver keeps flashing "PROTECT"
The protect message indicates that a problem was detected in the last stage of the amplifier and that it has shutdown to prevent further damage. Usually this indicates that the output transistors have failed. Any shop that works on audio should be able to repair this. Expect a part cost in the $20-$40 range. Add in the local labor rate for the total repair cost.
Dec 17, 2008 | Teac AG-V8060 Receiver
Magnavox Console Stereo turntable does not turn at correct speed
I'm in Nashville, where can I have my 70"s Magnavox stereo console serviced to get bugs out of it as well as get new cartridges?
Nov 24, 2008 | Teac AG-V1050 Receiver
Teac g-v8520 protect problem
Check the thermal sensor, TH1. This causes the unit to go into protect, it is a common failure part on this model.
Oct 26, 2007 | Teac AG-D8900 Receiver
You may have shorted the speaker wires. Remove all wires from the output connections and make doubly sure no strands are left there. Turn volume to zero and turn the receiver on. If the problem persists, you probably fried the output stage. Have it repaired.
Jan 22, 2006 | Teac AG-D8900 Receiver
Teac AG-V8060 Receiver Logo
1,095 people viewed this question
Top Teac Audio Players & Recorders Experts
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
