Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
Hot center strip
The center strip is hot on my fridge too
    Sergeant:
  • 212 Answers
When the center mullion is hot then it means your units condensor fan motor is out. the fan is located by the compressor. this fan keeps the condensor coils cooled off. if the fan is not running then the unit vents through the cabinet.
Posted on Jun 24, 2009
3 Suggested Answers
SOURCE: samsung model # rs2630sh side by side fridge. center strip is hot
I had the same problem, and it was the condenser fan motor. I ordered mine from www.partstore.com. It was half the price of sears.
I would suggest ordering the 2 "plastic bushings" for front and back of motor. I was able to reuse mine, but for a few dollars more it's worth it.
Posted on Feb 04, 2009
rajak2009
  • 527 Answers
SOURCE: The center strip that divides the fridge and the
Sir,
Sounds like there is a problem in the sealed system. Remove the rear lower cover and tell me if the condenser fan is turning. While there, is the Compressor hot to the touch?
Pull the unit away from the wall and then remove the rear bottom cover. Is the condenser fan running? If it's real dirty there, unplug the unit and clean real well. In the freezer section...look on the rear wall and tell me if you see any frost building up.
Thanks Good Luck
Posted on Aug 14, 2009
The fridge is hot the center deviding fridge and freezer hot enough burn hand and center of fridgeon side with water/ice despenser is hot also i just pluged in fridge is that normal for the fridge
Hi, welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal, yes...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.(where the doors come together when shut)
If all else appears fine (temp. Ok, fans running, no significant frost build up on freezer back wall) it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor...In fact that is what I`d look for based on your post.
But just so you know, the amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further.
Thank's for coming to "fixya" and good luck moving forward.
Please take a second to write a brief testimony and rate the info provided here.
Regards,
Macmarkus :)
Jun 30, 2011 | Samsung RS2630SH Side by Side Refrigerator
The black strip down the middle of the fridge ( between the fridge and freezer) is VERY hot to touch..for about 2 days. just for the record our ice machine hasnt worked for a year..I dont know if they are...
check you condenser fan motor to see if there something jammed in fan or if it just quit running, remove back panel to acces fan motor, that would cause that center mullion to get very hot
Sep 07, 2010 | KitchenAid Superba Architect KSCS25INSS...
Center strip between doors on kitchenaid kscs25inbt00 gets hot. I replaced the compressor fan motor and saw that it spins 3 or 4 times when fridge is plugged in, but it wont come on again no matter how hot...
That heat strip is in all refrigerators that don't want condensation rusting them out. It's called a mullion heater and there are several of them around the door.
Find the defrost timer and advance it a few clicks and the compressor should come on. If it doesn't let us know what happened.
And if your fridge has an Economy switch, it is there so you can turn the mullion heaters off.
Sep 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Fridge KSRF25FRBL00 - Hot Panel between doors
This strip is warmed to prevent condensation forming here during humid weather. Some models use a refrigerant pass of the compressor to warm this strip other use a heater that can be controlled by a 2 position switch in the refrigerator control panel that reads something like "Turn this on if moisture appears on cabinet exterior". If you have no such switch you should be aware that the strip is ALWAYS warm but barely noticeable until you develop a problem in the cooling system.
Check temperatures in the freezer (Zero Degrees approx.) and refrigerator (Approx. 30). If these are normal don't worry about the heat from that strip. If you find a temperature not normal you have the beginning of a cooling problem unrelated to that strip.
Aug 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
I have a 6 yr old Suberba. The center post between fridg & freezer is HOT and has been for several days. Any ideas?
That is normal and you may have just noticed that it gets warm or a little hot there. It is a heat strip placed behind the metal around your door to prevent moisture from forming around the door seal. If it was not there water would appear around the door on a daily basis, Thank You Sea Breeze
Aug 17, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Whirlpool Gold side by side cabinet extremely hot to the touch.
the refrigerator has mullions simaler to the veins underneath your skin to aid in cooling .the first thing to check is the fan by the compressor is it running while the compressor is if so the next thing to inspect is the condensor coils usaly underneath the fridge or directly on the back of the fridge alot of times these get clogged with lint and or animal hairsimply unplug the fridge and gently brush off the lint and vacume.your feed back on the resolve for this issue would be gratly app.
Aug 13, 2009 | Refrigerators
Sides of the refrigerator get extremely hot
The coils below fridge need cleaning very badly ( if G E then behind fridge) or the fan behind refrig which cools the compressor , is not working . Model number would have been helpful .
Aug 12, 2009 | GE Refrigerators
Ihave a Galaxy side by side and the center metal strip where the two doors meet and the magnets connect is very hot to the touch, any suggestions?
It's has to be warm to keep out the moisture, but not very hot .It will help if you clean (or blow out) the dust out of the coil in the back of the fridge (you'll see it at the bottom when you pull out the cardboard cover.Always disconnect the fridge before do any work.
Aug 06, 2009 | GALAXY Microsystems 25.4 cu. ft....
Water leaking into fridge
When your frig defrosts the water should go outside to the pan on bottom but it ain't cause the drain is stopped up. So the water just floods the ice box. Solution: Clear dat popcycle paper clogged drain up . Use some hot water to flush out dat drain.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | Refrigerators
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
707 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
