Question about D-Link DIR-625 (790069292637) Wireless Router
Cannot access the internet through my DIR-625
Cable modem>Linksys VoIP Adapter>D-Link DIR-625>MacBook OS X.5
I have unplugged, reset, reconfigured, everything I can think of and I still cannot access the internet. I am able to access the router but no internet comes through. I get this message in the logs:
"The addressing of the Internet side learnt thru DHCP conflicts with the addressing selected for the LAN side. Internet communications will be disabled until you have changed the LAN side addressing to resolve the problem."
Can someone clarify this? I was able to change the IP address of my VoIP Adapter to, but still no luck.
  • Anonymous Dec 31, 2007
    Same issue, using two of the same routers Dlink DIR 625's and have the same error and tried changing lan settings to all extent but internet will still not come through
    Problem Solver:
  • 19 Answers
Check your IP address to on the network settings
after that turn modem and VoIP off.
Click on Setup / Manual Internet
Select Dynamic IP under "My internet connection is"
Click on "Clone Your PC's Mac address"
Click on Save settings, if it ask for reboot click on reboot
After the router reboots (NOT COMPUTER), it will take you back to the router.
Once your are in the router, turn the modem on first then the VoIP.
After the modem and VoIP has finish rebootin
Click on the status tab of the router and check uder the "WAN"
Settings and check the IP address. If you get an IP address then check the internet.
If you do not get an IP address Click on Release and then renew.
If you still do not get an IP address click on Advance tab
Click on Advance network on the left and turn UPNP off and save the settings.
After that it should be able to get an IP address and you should be able to get online.
Posted on Jan 12, 2008
  • Tong Thao Jan 13, 2008
    I meant change your ip address not check :)
  • 193 Answers
Change the LAN ip start range in any one of the router
Posted on Nov 05, 2007
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
Con't connect to internet through d-link dir 625 router
  1. Reset the router and your modem.
  2. unplug the router's power
  3. unplug the modem's power
  4. wait 15 seconds
  5. plug in the modem
  6. wait until you have several lights and not too much blinking
  7. plug back in the router.
Try logging going to website. Give it a couple of tries (refreshes). Sometimes it takes the router time for the first attempt.
Report how that goes.
May 24, 2010 | D-Link DIR-625 (790069292637) Wireless...
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
Dlink DIR-625 permanently stopped working. Connected directly to internet with dsl cable through sympatico and internet works fine but doesn't work at all when connected through Dlink DIR-625
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
Jun 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Constantly drop off the Internet with my new Macbook
The problem which you describe could source from many different issues. I would suggest to first reset the router to the default settings (pushing the little button at the back side of the router) and set it again using the Dlink Wizard.
Aug 21, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
3,224 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
