Question about Philips Under-Cabinet Alarm Clock Radio with CD Player
Model #AJ6111-37. Serial #lm100728050845. I have
Model #AJ6111-37. Serial #lm100728050845. I have it plugged into a working outlet. Nothing will turn on. No light, no radio, no cd.
    Problem Solver:
  • 6 Answers
Is the unit under warranty? If not problably a fuse. take unit a part. main power pcb located on left side towars rear. remove scews holding it and have a look there. these are typically pico fuses labeled f1...f2 etc. Check for continuity with a meter if blown it will say OL if ok should read 0. Fuses and are available at your local electronic store.
Hope this is helpful.
Posted on Dec 29, 2009
It did help, but, i changed the fuse, plugged it back in, and it blew the new fuse. i dont know if it be one of the two transformers or the relay.
Posted on Aug 02, 2012
Went dead, will not power up,, looking for service manual or any help
Double check outlet with another appliance or light. No power
check Circut breaker box. Doublecheck Power cord, try a substitute known good. Talk to or email MFG Customer service you may need make model and possibly serial. Usually they are helpful. I presume it's out of warranty? if not go that route.
Mar 12, 2015 | Samsung HT-E5400/ZA - 5.1ch 1000w 3d...
I bought a model 365 remington dehumidifier. I plugged it in and nothing lights up. I have it plugged in for the past 8 to 10m hous and still nothing. Should i be seeing the blue light up ?
Two things that you need to check: Make sure that the outlet the dehumidifier is plugged int, is in fact working. The circuit breaker for that outlet may be tripped or there may be a loose or damaged wire connection to the one of the outlet's terminals. I assume you are turning the Master ON/OFF Switch to ON of the dehumidifier, after you plugged the unit in and set the humidity extraction level below 40%?
Jun 27, 2011 | Remington Model 365 Dehumidifier
While running in a screw to install a new electrical outlet cover, the outlet made a small pop and the lights flickered but immediately came back on. I plugged in the unit to see if it worked and nothing...
You say the unit is 220 volt, but the plug you installed has a white wire which is normally on a 120 volt outlet. A 220 volt outlet would have 2 black wires and ground. If you do have 220 there, and the reset does no good, I've seen those resets(they are basically built in GFI) blow out and had to bypass/put different chord on. there are fuses on the control board but I would check that last
Jun 24, 2011 | Frigidaire FAS257S2A WallWindow Air...
My GE spacemaker xl1400 model JVM1451BA 001 DOES NOT TURN ON, serial # HT9897895 , it wont make a noise or nothing, not lights, someone told me its a fuse, but I dont know what the fuse is called to go to...
First try plugging it in a different power outlet to eliminate a possible defective AC outlet, than if it still does not work, your friend could be correct it could be a fuse, if you have electrical skills you can verify your self. first unplug the power cable, than unscrew the cover to get to the electronic board, locate all the ceramic fuses and with a good multimeter set to (Ohms) check the continuity of all fuses if it reads 0 ohms it's good if it reads nothing than it is bad, replace that fuse with the same amperage and type than put the cover of the oven back, plug the power cable and give it a test if the fuse burns again than the problem is much worse, it could be a defective safety switch on the door frame or a defective circuit board, take it to a good repair shop...
REMEMBER TO ALWAYS UNPLUG THE POWER CABLE BEFORE OPENING THE UNIT!!!
Hope this helps!
Jun 18, 2011 | Microwave Ovens
When I plug my Bose clock radio into one outlet, I get nothing but static. When I plug it into a nearby outlet (with out really moving the cord), I get perfect reception. The problem is the outlet where...
The Wave Radio uses the AC power cord as an antenna. Perhaps the two outlets are wired differently regarding ground and hot.
An interesting article...
http://www.gcaudio.com/resources/howtos/acpolarity.html
As the man says in the article thecircuit tester like this...
http://www.idealindustries.com/products/test_measurement/electrical_testers/circuit_tester_e-z_check.jsp
... can be found at many Dollar Stores for cheap.
Mar 06, 2011 | Bose Wave Radio
My machine is portable. Model: DP840SWPXO, Serial: FS1107915 It was washing a load of dishes. Set at "HEAVY/NORMAL & NO HEAT/DRY". It stopped working between the NORMAL and RINSE ONLY part of...
Hello & Welcome to FixYa
This can be reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
You can clean the drain pump assembly if the problem returns. Please get back to me if you have any other questions.
Kevin
Feb 06, 2011 | Whirlpool Dishwashers
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
When radio is plugged in only the gfi outlets work not the radio.
Mines similar, outlets work but radio will only work on battery. Radio will not work on mains only. Charger works at same time so ok. SORTED IT TONIGHT. Inside the charger inside the box there is a fuse (240v 2A) I think, tiny radio fuse. Changed that tonight and radio now works on mains only or battery. Very awkwark job but better than watching a load of cr** on tv. Hope this helps someone.
Aug 12, 2009 | Bosch PB10-CD Radio/CD Boombox
Philips Under-Cabinet Alarm Clock Radio with CD Player Logo
851 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
