Question about Hotpoint NBXR463EBWW Electric Dryer
Can't open the dryer to check the belts. Where are the screws to view the motor?
    Problem Solver:
  • 13 Answers
OK. There is only one belt. To open the dryer, pull forward on the TOP of the dryer at the corners. You may have to open the lint filter cover and remove 2 screws holding the lint filter guide in place.
The top is held in place by two clips that, when you pull forward on the top, will release. Pull forward and lift up. I always put a knee up right below the top in the center to aid in making sure the dryer doesn't move when pulling on the top.
The top will then lift up from the front tilting backwards.
Posted on Jun 24, 2009
    Sergeant:
  • 212 Answers
Open door. at top of door opening their are two long phillips screws. removes those and the top panel will pull up. where the top panel and front panel meet there should be two more phillips screws. remove those and the front panel will come off. be careful cause the door switch wires are still connected!
Belt has borken
how to open a cabinet:
http://www.partselect.com/dryer+open-cabinet+repair.htm
belt diagrams:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Apr 15, 2011 | Dryers
I have a Maytag gas dryer model #LDG8420 and the belt broke. I need a diagram on how the new belt goes back on.
Go to this website and view the pictures of your dryer belt routing
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Dec 31, 2010 | Maytag Dryers
How install a drive belt on GE Dryer DBVH512EFWW.
Instructions Things You'll Need:
  • Phillips screwdriver
  1. Unplug the dryer and open the dryer door.
  2. Unscrew the screws under the top lip, where the dryer's door closes, with your screwdriver. Once these screws are removed, lift the top off of the dryer. On older models, the entire top will hinge upward out of the way, and on models made after 1997, half the top will pull off.
  3. Remove the screws on the inside-top corners of the front panel so the front panel of the dryer can be removed and set aside. On models made before 1997, the front panel should be carefully set to the right side; on newer models, the panel should be set to the left side of the machine. Be careful not to damage the door-control wires.
  4. Locate two screws approximately 6 inches off the floor on each side and remove them, allowing you to push the sides of the dryer slightly apart so the drum can be removed. Pull the drum slightly toward you and reach around to remove the dryer belt from the motor pulley. If the belt is broken, this step should not be necessary. Once the belt has been removed from the motor pulley, the drum should pull up slightly and out of the dryer toward you.
  5. Remove the old dryer belt and put the new one in place, with the ribs of the belt facing the drum. The slack part of the belt should be placed near the motor. Reverse the previous directions to replace the drum, replace the screws that hold the sides in place, replace the front and replace the top.
  6. Pull the dryer out from the wall and remove the four screws holding in the panel near the bottom of the back of the dryer. You will see the motor, the drum and the belt you just set in place. Loop the belt around the motor pulley and the idler pulley, and turn the drum by hand to make sure that the belt is straight and will stay in place. Screw the panel back on and push the dryer back into place against the wall.
Sep 22, 2010 | GE Dryers
I have a portable stacking GE dryer Model D7003KW419. I have to replace the belt. How do I do that? Thank You-----John
Hi
Thanks for using FixYa. Please check this video on how to replace the belt which also provides you info. on the idler pulley tension. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Dryers
No power to dryer
I wonder if its the belt,check switch see if you can bypass switch,can you hear the motor run its very quite when the belts not hooked up.Open top by removing screws under the front edge use a flat head to pry open top to chek belt
Jul 26, 2010 | Maytag PYE2300AY Electric Dryer
How do i replace the motor belts on GE Dryer model DPSR475E0WW? The squeeking is unbearable.
  1. Step 1 Unplug the dryer and open the dryer door.
  2. Step 2 Unscrew the screws under the top lip, where the dryer's door closes, with your screwdriver. Once these screws are removed, lift the top off of the dryer. On older models, the entire top will hinge upward out of the way, and on models made after 1997, half the top will pull off.
  3. Step 3 Remove the screws on the inside-top corners of the front panel so the front panel of the dryer can be removed and set aside. On models made before 1997, the front panel should be carefully set to the right side; on newer models, the panel should be set to the left side of the machine. Be careful not to damage the door-control wires.
  4. Step 4 Locate two screws approximately 6 inches off the floor on each side and remove them, allowing you to push the sides of the dryer slightly apart so the drum can be removed. Pull the drum slightly toward you and reach around to remove the dryer belt from the motor pulley. If the belt is broken, this step should not be necessary. Once the belt has been removed from the motor pulley, the drum should pull up slightly and out of the dryer toward you.
  5. Step 5 Remove the old dryer belt and put the new one in place, with the ribs of the belt facing the drum. The slack part of the belt should be placed near the motor. Reverse the previous directions to replace the drum, replace the screws that hold the sides in place, replace the front and replace the top.
  6. Step 6 Pull the dryer out from the wall and remove the four screws holding in the panel near the bottom of the back of the dryer. You will see the motor, the drum and the belt you just set in place. Loop the belt around the motor pulley and the idler pulley, and turn the drum by hand to make sure that the belt is straight and will stay in place. Screw the panel back on and push the dryer back into place against the wall.
May 15, 2010 | Dryers
Dryer won't spin just hums
It could be your belt or the motor is froze up. The belt is an easy fix.With a flat head screw driver pop the top of the dryer open ( make sure it is un plugged) and check belt around the drum. You should see it right away. If the belt is tight then your motor is shot.
Jan 09, 2010 | Maytag Dryers
Whirlpool Dryer LEQ9558KQ1
If you can hear/see the motor running, but the drum does not spin, you probably have a broken or loose dryer belt. You can easily determine this by opening the top panel and looking at the belt. Just lift the lint sheet cover on the top of the dryer and and pull out the screen. With the cover still open, locate and remove the two screws. Once the screws are removed, the top panel will lift up. The belt should be seen wrapped around the drum. If the belt has broken or has slipped off the idler pulley, it may be fitting loosely around the drum, or lying on the cabinet bottom. If so, the following instructions explain how to access the interior and replace or reinstall the belt. Replacing the dryer belt on this model dryer involves the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. With the lint screen door open, remove the two screws and lift the top panel.
3. Unplug the door switch conector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws. NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you still have questions, please let me know. I hope this helps you. PS Appliancepartspros.com has some excellent exploded view diagrams of your dryer, along with parts listings that you cna use for reference as well.
Aug 04, 2009 | Whirlpool LGR5636L Gas Dryer
Loud sort of grinding noise while drying stops then restarts again maytag front loading mdg308daww need help as to how to get panels off to access drum and motor
unplug dryer
front panel screws are mounted in the bend at the bottom of the panel, hidden from easy view by the bend.
  • may be torx secure screws, either cut a slot in the screw head and use a flat screwdriver, or buy a torx secure #2 bit at the local alltools
swing front panel up and forward, unplug door switch wires, set panel aside,
examine roller bearings,
drum felts,
belt tensioner
for wear
takes longer to type than to open the dryer
good luck
Aug 26, 2008 | Maytag Dryers
How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Dec 21, 2007 | Dryers
Hotpoint NBXR463EBWW Electric Dryer Logo
341 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
