Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
My Nikon D40 doesn't focus not take pics
I got my Nikon D40 less than a year ago, and haven't been using it very much yet, just thhe occational snap once in a while to get used to the camera. Now I finally got some extra time to really start getting in the mood for photography, but all of a sudden he camera stopped working. as I have it on auto, it won't focus, but occasionally makes the humming focusing sound. It won't take a picture, either, asI push the button, although - yet again ccasionally - it takes a snap as I push the little AE-L/AE-L button, but even then the picture comes out blurry and out of focus. Also,(his is hopefully an unrelated issue), the camera had changed the picure format from normal to RAW without me changing any settings. This was quite annoying, as now my otherwise nice holiday pictures are in a format I can not do anything with. Unlike the manual stated, there was no editing program included on a cd with the camera to help me.. I haven't made any own settings, mainly used the auto mode... Is my camera just moody, do I have bad luck, or is this a problem that could be easily solved at home?
    Problem Solver:
  • 9 Answers
If it's under warranty, use the warranty. It takes my D40x about a half second to focus at most. I keep my camera in a dust proof case when not in use. I've had it for 2 years, it still works fine.
Posted on Jun 28, 2009
Hi, i am using nikon d40 my problem is that i was using 18-55 lens after some years there was green spots on my pics when clicked,i started using 18-105 mm nikkor lens my problem was solved but now af
The D40 is a low end camera, but before you discard it, I would contact the closest Nikon repair depot (see the Nikon website for the location) and ask them for a repair estimate. You will then be able to decide if it is better to have it repaired or replace it with a newer model.
Jan 08, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
When I press the button to take a pic with Nikon D40 it just clicks and clicks but doesn't take a pic what is wrong?
Remove the lens and fire off a few shots while looking inside. Make sure the mirror flips up out of the way and that the shutter opens and exposes the sensor.
Oct 10, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
Is there an adapter for a Sigma lens onto a Nikon d-40 camera?
Sigma makes some lenses for Nikon cameras-- though the Nikon D40 requires a lens with its own internal focusing mechanism, since it does not have an autofocus motor. This entirely depends on what Sigma lens you have, i.e. if it were a Sigma lens made for a Canon camera, yes there would be an adapter for that-- but the likelihood of success is less with the limitation of the D40 needing an internal focus motor on the lens.
Mar 06, 2011 | Sigma SD14 Digital Camera
My Nikon D40 won't take pictures!
Your twin sister #&%@ed up your camera.
Jun 07, 2010 | Nikon D40x Digital Camera
Nikon d40 not working and focusing
I have similar problem on my D40. I think there is something mechanical with the camera's shutter button, some connections, I guess... The only solution I've found is to go to Menu > Custom Settings Menu > "AE-L/AF-L" and set to "AF". Now you can focus by AF-L button. Focusing works then perfectly. The WORST thing is that I can't lock exposure now and that's sad :( Maybe I can try to fix this in the camera center later, we'll see. But it takes months in Ukraine to do the fixing... Hate that!
Jun 22, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 vertical focus problem
Make sure the camera is using the appropriate focus sensor.
Does the problem occur when you focus manually?
Are you handholding the camera? Many people don't hold the camera as steady when holding it vertically. Try putting the camera on a tripod or other steady surface and see what happens.
Jun 11, 2009 | Nikon D40x Digital Camera
Nikon coolpix l16, not taking pics
Take out the media card, then do a factory reset.
Jul 06, 2017 | Nikon Coolpix L11 Digital Camera
Nikon D40 will not focus when shutter pressed 1/2 down
has the lens stuck up? put it temporarily on 'M" and try to turn the focus ring. this should be freely turning;
otherwise you may want to check the camera body to lens electrical contacts (silver).. a small dab of alcohol to a q-tip.. make sure its not that wet..then try to clean the contacts.
Jan 31, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
Apr 06, 2008 | Nikon D50 Digital Camera
Nikon d40 digital camera
When the camera is in auto focus mode, it will not take the picture until it locks onto a subject. If there is not enough light, the camera will "hunt" for something to focus on. Since it can't define any edges, it won't allow the shutter to release.
The D40 base model does NOT have a powered focus lever for autofocus, so if the autofocus is not working, suspect the lens.
Mar 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
336 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
