Question about Microsoft Xbox 360 Wireless Controller
Broken knob We have a broken knob on one of our wireless controllers...is there somewhere we can take it to get that repaired?
    Problem Solver:
  • 6 Answers
Call microsoft and ask them
Posted on Jun 24, 2009
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
Is the knob that turn the light on repairable? The oven light is on but would not turn off. The knob just keeps turning...
HI,and a merry Xmas.
Yes it is repairable, it is going to be one of two things.
1--the control knob is cracked or broken causing it to twist round without turning the control.
2--the spindle on the control is broken or loose inside the switch.
Pull the knob off, and see if yopu can turn the switch on and off with a pair of grips or pliers.
This way it will enable you tell if it is just the knob or the switch that is faulty.
Good luck.
Please leave feedback for my suggested solution.
Dec 25, 2009 | DeLonghi Ovens
Internal air vent only working on upper screen
The cable from the vent control knob is probably broken or come off somewhere, you'll have to trace it from the back of the knob onwards.
Oct 10, 2009 | 1997 Ford Escort
The control knob for the washer is stripped is it easy to repair and how do i remove the broken knob?
Use a flat blade screwdriver under the control know to pry it up as you turn the control knob.
This should help you to remove the knob
Sep 25, 2009 | KitchenAid Washing Machines
Temperature control panel is broken.how do i get face panel off to fix.1998 ford taurus. air conditioner works but does not come out.
You will need a Ford radio removal tool to fit into the 4 holes in the panel. It will pull out if they are properly engaged. Then, each control knob will pull off revealing nuts that hold each control assembly to the panel. Sounds like you have a broken cable or a vacuum line off somewhere. Hope this helps.
Sep 21, 2009 | 1999 Ford Taurus
Cycles are off
if you can pull knob off make sure shaft is not cracked inside if thats alright take screws out of dishwasher down the sides and around console to access timer make sure timer mounts are not broken
Sep 08, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dash Control Unit Replacement
You can save a LOT of money by fixing it yourself.
All that is wrong with the knob are broken wires from the knob's PC board to the main PC board on the AC control.
All you have to do is remove the AC main control, take it apart, and resolder the broken wires from the PC board with the knob on it, to the main AC pc board. There are 3 wires, any number could be broken.
If you take it apart and solder the broken wires, this WILL fix your issue. Just make sure you put the wires back exactly where they go.
A FIXYA rating (4 blue diamonds) would be most appreciated for my assistance.
Mar 21, 2009 | 2002 Toyota Highlander
Broken Knob for fan control
once you take off the front housing, the switch itself shoud be easy to remove and replace...sometimes, a used appliance store/repair office can get a suitable replacement part. Trick is to mark the wires as you remove them from the switch and take hte switch with you while you go part hunting. Also would help to have model and serial number (and brand name) noted to take along. Papdaddy
Sep 22, 2007 | Comfort-Aire CS-101A Air Conditioner
Microsoft Xbox 360 Wireless Controller Logo
107 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
