Question about Motorola Mobility MOTORAZR maxx V6 Cellular Phone
Internet connection fail
I can connect to internet using my motorala v6 maxx, but when i connect my phone to my computer and used my phone as modem i can't connect to a network.
  • 76 Answers
Re: internet connection fail
You need to ring your service provider and get them to set it up and you also need to have HSPDA
Posted on Jul 07, 2008
To use the phone as a modem, your area must first have HSPDA coverage.
Posted on Mar 19, 2008
0 characters
3 Points
How to connect my xperia x8 as a modem to connect to my laptop to use internet?
you can connect it by data cable or wirelessly by bluetooth once it is connected to your computer open the program for your phone (it comes in dvd/cd with phone)
then select connect option to connect internet from your phone as GPRS or modem as you need
remember when you first time connect phone with computer it shows notification new hardware found and installs your device as standard modem also you can select your phone as modem in control panel also
further the same procedure to make new connection
good luck
Aug 20, 2011 | Sony Ericsson XPERIA X8 Cell Phone
My mobile is nokia 5800 music express. so i want to connect internet through my pc
First of all, install the Noki Pc suite on your computer, connect the phone in Nokia Mode, you'll see that your mobile is a Modem, Open the Internet Connection and set your nokia modem as the default modem, create a dial up connection using the Internet Connection wizard, you'll need the number to dial, this number is to be obtained from the Network Operator. Now you can connect to the internet using your phone. Note that the speed will be slow as compared to normal (wired/wireless) internet connection. Good luck Thanks for using FixYa.
Jun 01, 2010 | Nokia 5800 XpressMusic Smartphone
Can I use the Samsung alias 2 is an Internet modem
    Using Alias 2 as Modem
  1. The Alias 2 can, in fact, be used as an external modem to connect your computer to the Internet. To do this, the phone must plug into the computer via USB. The USB data cable specific for the phone is purchased separately and can be found at most any cellular phone store and eBay. Because USB is a powered connection, anytime the phone is plugged into the computer for use as a modem, it will also remain charging, so you don't have to worry about battery life while online.
    In addition to the cable, you must subscribe to a specific service through your cellular provider in order to use the Alias 2 as a modem. This plan will be a "tethering" plan and will have a separate charge each month to use it, similar to a cell phone's data plan. By signing up for this feature, your phone will be able to dial into the data network and utilize the Internet connection as a modem, allowing any connected computer to surf the Internet. Once this feature has been activated on your account the option will become available on the phone itself to enable tethering.
    At this point, you should be able to turn on tethering, connect the phone to your computer via USB cable and select the phone on your computer as an Internet connection source.
    It is important to note, however, that the Alias 2 uses a different and slightly older system on the 3G cellular network. Because of this, using the phone as an external modem will produce a slightly slower Internet connection than a traditional modem or even a newer phone would. However, as a backup solution for Internet connectivity or a travel solution, the Alias 2 will work just fine as a modem for your computer or laptop.
Apr 01, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
How can i use jasjam as a modem
Thank you for visiting Fixya Forums
Using a Jazjam as a modem:
• Before activating Wireless Modem, make sure your device has a
SIM card installed, and you have set up a GPRS or phone dial-up
modem connection on your device. For more information about
setting up a GPRS connection, see "To set up a GPRS connection to
the Internet". For more information about setting up a phone dial-up
connection, see "To set up a dial-up connection to your ISP".
Also make sure you have connected your device to a computer (via
infrared, USB or Bluetooth).
• When you activate Wireless Modem, ActiveSync will be disabled
To set up your device as an infrared or USB modem
1. On your device, tap Start > Programs > Wireless Modem.
2. In the Connection Type list, select how your device is connected
to the computer: IrDA if via infrared, or USB if through USB cable
3. To use your device as a GPRS modem, set the GPRS Access
point name. To do so, tap Menu > APN Setting and enter the
access point name.
4. Point your device at the infrared port of your notebook, or plug in
the USB cable adapter between your device and the notebook.
5. Tap Menu > Start.
6. The next thing to do is to add your device as an infrared or USB
modem onto your notebook.
To add your device as an infrared modem to your notebook
1. After you tap Menu > Start on the Wireless Modem screen
of your device, the Found New Hardware dialog box will then
appear on your notebook and will show that your device has been
detected as an infrared modem. In this dialog box, make sure that
Install the software automatically (Recommended) is selected
then click Next.
2. Wait for Windows to finish installing the infrared modem, then
click Finish.
3. You can now connect your computer to the Internet. Follow the
steps in “To dial up and connect to the Internet.”
To add your device as a USB modem to your computer
1. After you tap Menu > Start on the Wireless Modem screen of
your device, your computer will automatically detect that your
device has been connected. The Found New Hardware dialog
box will then appear on your computer.
2. In the Found New Hardware dialog box, select Install from a list
or specific location (Advanced) and click Next.
3. Select Search for the best drivers in these locations.
4. Insert the Getting Started Disc into your CD drive. Select the
Include this location in the search check box. Click Browse
and choose the CD drive and root folder where the modem driver
is located, then click Next.
5. Wait for the installation to complete, then click Finish.
6. Click Start > Settings > Control Panel.
7. Double-click Phone and Modem Options.
8. Click the Modems tab. Select the new modem from the Modem
list, then click OK.
Getting Connected
9. You can now connect your computer to the Internet. Follow the
Once the computer recognizes your device as a modem, you can now
use the computer to dial up and connect to the Internet.
1. On your computer, click Start > Settings > Control Panel.
2. Double-click Network Connections.
3. Click File > New Connection.
4. In the New Connection Wizard, click Next.
5. Click Connect to the Internet then click Next.
6. Select Set up my connection manually then click Next.
7. Select Connect using a dial-up modem then click Next.
8. Select the infrared, USB or Bluetooth modem that you previously
installed, then click Next.
9. Enter a descriptive name for this connection, then click Next.
10. If you are connecting to the Internet via GPRS, enter the
telephone number as *99#. Otherwise, enter your ISP‘s dial-up
phone number, then click Next.
11. Under Internet Account Information, you may not need to
enter a user name and password when using GPRS. Just click
Next to proceed.
12. Click Finish to exit the wizard.
13. The Connect dialog box then opens. Click Dial to dial up and
To end the modem session
• On the Wireless Modem screen, tap Done or tap Menu > Stop.
(Please give me a big thumbs up when you rate my answer, thanks.)
Jan 28, 2010 | i-mate JasJam Smartphone
I want to use my motorala l7i phone in my linux os
can u explain how u r connecting ur phone with blietooth or data cable
Jun 12, 2009 | Motorola Mobility L7I Cellular Phone
Motorola v6 maxx won't turn on
sounds like a faulty software in your phone , it need flashing
May 27, 2009 | Motorola Mobility MOTORAZR maxx V6...
How to connect to internet with my cell phone motorzr max v6
Using your cell phone as a modem is perhaps the most overlooked of all Internet connection options. But a mobile phone Internet connection, whether as a tethered modem or, using bluetooth, a wireless cell phone Internet connection, is easy to set up, and with a laptop and cellphone you can check email and surf the web from anywhere, any time, with the Internet in your pocket!
Here are the basic instructions for creating a mobile phone Internet connection. The instructions are for a cell phone with bluetooth (which most cell phones these days have), but if your cell phone doesn’t have bluetooth you can buy a cable to connect your laptop to your phone from any cell phone accessory provider. Conversely, if your cell phone has bluetooth but your laptop does not, you can buy a small USB device which will enable bluetooth on your computer.
Feb 20, 2009 | Motorola Mobility MOTORAZR maxx V6...
Computor connection
lost disc to read photos from camera to computer
Jun 22, 2008 | Motorola Mobility MOTORAZR maxx V6...
Cannot connect to Internet
there nothing really to be bothered about, internet connection depends on your networks capability. try to check if your network supports internet connections. thanks.
Jan 26, 2008 | Motorola Mobility MOTORAZR maxx V6...
V3i as modem
yep simply attach the cable start your motorola ponetools and tada you are done
Nov 18, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility MOTORAZR maxx V6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
