Question about Durabrand DWT1304 13" TV
Do you all not have a code for the 13 inch tv that will get it back to video
I need a code so I can do this. The tv was a gift for me three year old and I can not find the remote, now she can not wath dvds because I can not get it off of tv. If not and and it is true that you all do not have a code then how can I get another remote for this tv?
Please respond as soon as you can thanks
Re: do you all not have a code for the 13 inch tv that will get it back to video - Durabrand DWT1304 13" TV Standard (CRT)...
Posted on Jun 15, 2008
    Problem Solver:
  • 5 Answers
Re: do you all not have a code for the 13 inch tv that...
Radio Shack has 2 universal models that support durabrand. I had the same problem and purchased the "3 in 1 Easy to use Remote" for $5.99 and used the codes that were listed and the TV works fine now.
Posted on Dec 27, 2007
There are different codes for each universal remote manufacturer. There should be a listing with each new remote. If not, then go to remote manufactures website for additional listings. I also have the name and number to call Funai corporation parts dept to get part#'s for anything dealing with Durabrand TV's
Posted on Nov 23, 2007
Try 0171. That worked for mine.
Posted on Nov 09, 2007
0 characters
3 Points
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
I need the three digit code for a 13 inch Symphonic tv model ST 413B to make a universal remote work.
the code depends on the name brand of the remote you have purchased. they each come with a list. if you have lost this list, contact the remote manufacturer and they can give you the code.
Feb 24, 2009 | Standard (CRT) Televisions
Sylvania 13 inch -- model unknown
Hi DiBd. Some electronic components in a tv can go out of tolerance during long periods of inactivity. I think that's what's happened to your set. Some component in the video section of your tv has given up.
Aug 13, 2008 | Sylvania 6413TC 13" TV
My Sanyo TV, 3 year old turns off with a click sound, as soon as it is turned On
your tv has defective power oscillation! the click sound that is relay power source. if the relay is click back you have defective small parts in power section! do you have experience in electronics?
Jun 22, 2008 | Standard (CRT) Televisions
TV problem
Hello Barbara76,
Is this a Horizontal line (inch or two) across the screen, if so
the fault could be either a faulty Vertical IC,Faulty Electrolytic
capacitors or just simple dry joints.
Feb 03, 2008 | Mitsubishi CS-27205 TV
Nedd code for durabrand tv
We broke our remote for the Durabrand 13 inch tv, bought a RCA universal remote and that did not work. Just bought the radio shack 3 in 1 remote for $7.99 and it had the codes for the Durabrand tv and it worked fine. Hope this helps.
Dec 24, 2007 | Durabrand DWT1304 13" TV
13 inch Haier TV
Plug it into a power strip and turn off the power strip as well as the TV. I've been told that newer TVs are always "on" - standby mode- and someone probably has a device somewhere in the near vicinity that is turning it on. (Or your cat is watching it when you're not home.) Or you could just unplug it when you leave.
May 21, 2007 | Haier HTN13R12S 13" TV
How do I reset the password on the dvd player?
SpongeBob SquarePants 13" TV Is the DVD player in this 13 inch television; if it is then you can ring the product support number 905-940-5089 I hope this is correct for the USA. Or you could try hypnotizing your son to get the password!
Oct 22, 2006 | Emerson SpongeBob SquarePants TV
Durabrand DWT1304 13" TV Logo
337 people viewed this question
Top Durabrand Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Durabrand Standard (CRT) Television Expert? Answer questions, earn points and help others
