Question about Hitachi Deskstar 7K500 500 GB Hard Drive
HDS72505 0KLAT80 USB Device recognised by Vista but the two partitions/drives are said to be unknown devices Any help?
  • Tim Grayson
    Tim Grayson May 11, 2010
    Where does it tell you that they are unknown devices? Did you set up the partitions yourself? Are they using NTFS as a file system?
    Champion:
  • 331 Answers
Make SURE you dont' have any data on the drive that is important (or you have a good back up) Click "COmputers" and "manage" you will need to initialize the drive for VIsta to recognize it.
Posted on Jul 23, 2010
Not recognised windows vista
You have to go to control panel, adminstrative tools, storage and initialize the drive. However the way it sounds, the drive might have an issue, could be the cable or the usb port
Sep 25, 2012 | Iomega 1TB Desktop USB 2.0 Hard Drive
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
My vista does nnot recognize one partition on my
1. In the run command (Start menu bar) type "regedit" to bring up the Registry Editor.
2. In Registry Editor, navigate to:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion
3. In the details pane, double-click DevicePath.
4. Add a semi-colon to end of the existing text, and then add the path to %SystemRoot%\System32. The result should be similar to: %SystemRoot%\inf;%SystemRoot%\System32
Do not remove the %SystemRoot%\inf file path from the DevicePath registry entry.
5. Click OK to save the new value, and then close Registry Editor.
6. Delete “INFCACH.1” FROM C:\Windows and C:\Windows\Inf Directories (if it exists)
7. Ensure that there is a copy of the usbstor.inf file in C:\Windows\Inf
If there isn’t – follow the below steps:
a) From another Vista system (copy it out of another Vista system and copy it directly into the C:\Windows\inf directory
OR
b) From the problem machine, run Command Prompt ( as administrator). From C:\ do a dir usbstor.inf /s . Wherever the file is found, go to that directory and copy all the files located in that directory to C:\Windows\inf directory
8. Open device manager, uninstall all unknown devices (right click, uninstall) so they all disappear from the list
9. Reboot the computer
10. Plug the device in (the drivers will now install and the device will be usable!)
Mar 06, 2010 | Electronics - Others
Vista OS. USB detects device. Does not display
Vista and Win7 lite versions dont have all the drivers and functions of the full version, so some issue will always keep coming up....
if u can install XP then do this
if u know how to partition ur main internal HD then install XP and Vista in different partitions...
when windows starts..choose XP to load.
then try if ur Ext HD works in XP...
else let me know i will guid u the next steps...
Dec 21, 2009 | SmartDisk FireLite 40 GB Hard Drive
HTC Touch Dual not recognized by PC
if you run vista it will not recognise the drivers, you will need to download an update from HTC or from your mobile operator.
faling that check microsoft vista website for mobile device software- vista does not use active sync
Aug 13, 2009 | HTC Touch Dual Slider Smartphone
Re-installing vista
take any vista dvd, pirated , legal or from friends, insert dvd, try recover boot/ mbr. that will help for sure.
Apr 05, 2009 | HP Pavilion dv6565us Notebook
Partitioning a second hard drive
"No need for third party programs to partition hard drive today we will look at how to create partition in Vista for free."
http://askabouttech.com/how-to-partition-hard-drive-in-vista/
Mar 05, 2009 | Dell Factory Refurbished 4500-7MMF821...
ECS780G USB Problem
hiya
this sounds like a driver issue as it is not being recognised upon boot up try and download the lastest driver for this device
Rik
Jan 23, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
USB device not recognized
if it,s showing in the device manager as an exclamation mark. that means it,s found it, but can,t recognise it.
i,d suggest formatting and partitioning it, with some good software. also ensure that it,s powered via 2 usb cables to laptop, from 1 on the drive itself. some bigger hard-drives, need the extra power to drive them.
Mike @ compurepair.
Jul 25, 2008 | Western Digital 500GB My Book World...
Transcend pen drive problem
Dear Sir,
i have a transcend pen drive 2 GB which runs perfectly on windows XP on other computer but it is not recognised by Computer. My Motherboard is Asus and Operating system is Windows XP. Initially it used to show a message "One of the USB driver sttached to this computer has malfunctioned, windows does not requesnized it". How can I do solve the problem. My email : safiqul.alam@gmail.com
Mar 25, 2008 | Electronics - Others
Open Questions:
Hitachi Deskstar 7K500 500 GB Hard Drive Logo
636 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
