Question about NorStar M7310 Corded Phone
I hooked up a phone in the office on an extended line from another area and all of the memory buttons automatically worked, but the phone doesn't ring even after using feature *6 selecting a ring, and pressing ok. in addition, when i know it's ringing because of the other phones making the noise, I go to pick it up and it automatically puts me on a new line rather than answering the call. I can select the line the new call is and answer it that way, but that doesn't always work because the calls on hold look the same as new calls. what can i do to change the settings? i want the phone to ring when someone calls and to pick up the phone and be automatically connected to the customer
    Champion:
  • 211 Answers
The easiest thing to do is use Direct Pickup Feature.
When the phone is ringing dial Feature 76
Dial internal number of a phone that is ringing (also refered as extension number)
You just answered a ringing phone at your desk.
If you have login information for Feature **config, I can help you set up your phone to be ringing as well.
Cheers
Posted on Jun 25, 2009
Nortel Meridian M7208 page not working...
Press Feature * 3
press the 5th line key you want to use for paging
enter the page-all code (feature 601-603 as you wish)
Aug 20, 2017 | Nortel Meridian M7208 Corded Phone
I have a Lucent 18D in the office and all the lines are working except line 3 of one of the phones. All the other phones and lines in the office are working. I've made sure everything is plugged i
Sounds like the line 3 button on that set is programmed as something else. When you press feature 00 and the line 3 button what does the programming say on the screen?
Feb 22, 2012 | Lucent PARTNER18 Corded Phone
I have nokia 2720a-2, can i extend momory of this???
Unfortunately this phone doesn't even have a memory card slot. Therefore you cannot extend the 10 MB internal dynamic memory.
May 03, 2011 | Nokia 2720 Fold Cell Phone
My mother has a brothers multipurpose and when phone line is connected, you can hear dial tone even with handset hungup
The Brother faxes have a button that you can press to allow you to dial without picking up the phone. Look for a button labeled "Hook." Pressing it should hang up the machine.
If the Hook button doesn't make a difference, unplug the phone line from the machine, partly to make sure it's your fax that you hear, and partly because if you leave it connected and "off hook" the phone company will disconnect you from their network.
Three things that might help if the Hook button doesn't help are:
1. Unplug the power and plug it back in after about 5 seconds.
2. Clear the memory. You need to enter Maintenance Mode for this. You didn't give us a model number, but newer machines use this routine:
Menu
Black Start
Up-arrow
Up-arrow
Up-arrow
Up-arrow
Do the above quickly, ignoring any error beeps. If you're successful, all the lights will flash in unison, and the display will read, "MAINTENANCE." If not, touch the Stop key and try it again.
Enter the number 91: just touch 9, then 1, and wait while the machine clears it's memory. It will not clear your name and phone numbers from memory.
Enter 99 to exit Maintenance Mode, and wait while it goes through it's complete startup.
Plug the phone line in again and see if that dial tone is still there. If so, unplug the phone line again and try exactly the same routine, except that instead of entering 91, enter 01. That will clear all of your memory, as if the machine is fresh out of the box.
3. If clearing the memory doesn't help, you have a bad main board in the fax. If it's under warranty (1 year in the US), Brother will cover all parts & labor. If not, it may not be worth the cost to fix it.
Mar 04, 2011 | Office Equipment & Supplies
Do you have any dealer in new york area for repairing my rca 25450 phone system? The unit is out of guarantee and RCA do not make repair. In fact, how much should be the cost and if you consider appropiate...
Before you call a technician (which will probably cost as much as just replacing the phone) do some diagnostics to see if it's the phone, the phone wire or something in the office wiring.
Jun 15, 2010 | RCA 25450 4-Line Extended Range Multi...
I have 3 of the 954 model. If im using the phone
Do you have DSL on the first line? I would say that you have split the line to the phones so that they are not able to recognize the off hook from your office phone because each phone has a DSL filter. So take your phone line from the back of the DSL modem (line 1) and split it to all of the phones. Put the filter in the line, if you need one before the splitter.
Jun 15, 2010 | AT&T 954 Corded Phone
Norstar M7310 phone doesn't ring and doesn't pick up calls
You can look at the manual here:
http://www.fixya.com/support/p98000-norstar_m7310_corded_phone_nt8b21ac03/manual-34096/page-3
Jun 24, 2009 | NorStar M7310 Corded Phone
Avaya Partner 34-D phone goes off hook on its own
Sounds like a phone.
Replace unit and see if problem reoccures
Apr 16, 2009 | Avaya Partner 34D Corded Phone
HOW TO CHANGE THE AUTO LINE SELECTION WHEN PICKING UP HANDSET
Sounds like you have two seperate line groups programmed in the system, Program 32 " Automatic Preference " controls the lines the phone will automatically be connected to when the telephone handset is taken off hook or the Spkr button is used.
Apr 24, 2008 | Toshiba DKT-2010 Corded Phone
Phones won't ring
Your memory battery on your telephone system is bad. when power is lost , so is the programming. to fix this , you must go into system programming. From any phone, without picking up the handset. Press #20 Dial 12341, Press #. Press # again and dial 62, Press Line 1 and then press the button of each stn you want to ring ,( The display will show 1 if you press stn 1 and so on.) program each line the same way.
Nov 19, 2007 | Samsung Prostar 816 Phone
NorStar M7310 Corded Phone Logo
215 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
