Question about Dishwashers
Bauer dishwasher programe keeps sticking
My dishwasher keeps sticking between programes and has to be moved maually . . .any ideas
  • 6,784 Answers
HI, the timer control module is damaged. you should replace this damaged component asap. This will fix this issue.
Posted on Jun 24, 2009
My KD12mm dishwasher's dial seems to get stuck half way through the cycle and keeps washing for hours, wasting water and electricity. I has the same problem with my old Indesit and got rid of it. Can...
This seems a clear case of the timer program controller ebing faulty. The stepper motor has struck on to a point or the gears are worn out which causes the motor not moving the position.
The only way is look carefully and maybe resetting the stepper motor so that the timer moves.
If not the cost of a new program controller must be cheked.\
Present day electronic processors for programs are highly reliable which must be thought of in your next purchase.
Jun 13, 2011 | Kelvinator Dishwashers
I just aquired a Dell PC that is newer than my HP PC. I have no idea on how to move all my files and programs over with out loosing anything. Can you send me some instructions through email? Thanks, ...
You cannot just move your programs over, you need to install your programs using the various program installation CDs, because the installation process copies DLL files as well as putting data onto the registery file.
You can copy your data files from your HP PC to a USB memory stick and then plug this USB memory stick into the Dell's USB port and copy the data files to the various folders on the Dell PC.
Sep 03, 2010 | Computers & Internet
Candy cs455m programe stops at about 3oclock on the dial
Yes heatr should be submerged in the water. Not expose to free air.Check the water level float switch or the pressure switch.
The replace timer should be identical in design. If there is a mismatch it will not function as designed.
If it is elctronic micro controller type the same part no and soft ware version should be used.
May 25, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Hi, our Indesit IDL500 dishwasher has stopped working. The fault light 2 is flashing. The manual doesn't mention what fault this indicates. Any ideas. Cheers, Neil
Hi Niel, If you were to start the cycle from the beginning, where in the cycle does this occur? . So many code numbers for so many units, hard to keep up .Just note if heating is taking place and if drainage is correct. Hear from you soon.
Sep 26, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
My dishwasher is sticks in between washing cycles
These mechanical timer machines have to follow a series of logical steps to complete the program - ie, empty. fill to level 1. wash. heat to temp. etc etc
My guess is the machine is not heating, as you say it works for part of the program - or possibly it is not emptying correctly? check water heating element and drain pump.
Program 4 eco is a separate program from 3, using low temperature washing - the machine does stop between 3 and 4 normally and doesnt carry on through.
Jan 30, 2018 | Siemens 24 in. SE64A630GB Built-In...
The program light goes off and the BF162 doesn't start...
When you keep the button pressed for a few seconds the lights go off, this resets the dishwasher. Then press the p button again to the program you want 1st light is heavy soil 2nd light is normal soil, 3rd light is eco wash, 4th light is rinse. At the end of the cycle the program light you have selected will flash.
Apr 24, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Program sticking
problem sorted we returned the dishwasher to where we got it from but thanks anyway
Mar 25, 2009 | Hotpoint 24 in. FDW60 Free-standing...
FDW85 Dishwasher
turn on your dishwasher and press and hold the start/reset and on/off buttons simulaneously until the display shows d.of this turns off the demonstration mode.
May 12, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
