Question about Whirlpool ED5VHGXM Side by Side Refrigerator
FRONT OF SIDE PANELS FEEL VERY HOT - Whirlpool ED5VHGXM Side by Side Refrigerator
    Sergeant:
  • 212 Answers
Need to check to see if your condensor fan is running. this fan is located by the compressor. it will run at the same time the compressor is running. this fan keeps the condensor coils cooled off. if its not running then the unit tries to cool down through the cabinet
Posted on Jun 24, 2009
Circuit breaker feel loose
Make sure dead front (cover) is adjusted properly, check load and line connections if arking has acured @ load side replace breaker, @ line side replace breaker and panel
Dec 06, 2015 | Electrical Supplies
The front display was not working so we replaced it, the main control board was replaced, and the refridgator is still not working. it will not cool. its a samsung side by side model number rs2577sl
you probably have a sealed system problem. is the compressor running? feel the discharge line. is it hot? feel the condenser, does it feel warm?
Jul 16, 2011 | Refrigerators
What are the panels caled at side of windscreen
A pilar panels
B pilar panels are between front doors and rear side windows
Apr 11, 2010 | 2005 Mini Cooper
Top is bent and need to remove it to repair-how does it come off
From the front, insert a putty knife into the space between the top and front panels, about 1 1/2 inches from the end.You will feel a spring. Insert the knife and locate BOTH sides of the spring. Remove the knife and insert it at the center of the spring and push it straight in until it releases. Put a pencil or something small to hold that side open, while you unclip the other side.
Mar 05, 2010 | Dryers
Everytime it rains hard my carpet is wet by the door on the driver side and also driver side rear door
There is a great possibilty that there is a leak on the Left Side of the Windshield. It is most likely in the area of the upper left side.
The reason for this conclusion is:
The rain water is coming in the Left Upper Side; and either coming down the "A" Pillar, or traveling underneath the trim on the inside roof and coming down the "B" Pillar.
The only other explanantion is a torn, worn, cracked or dislocated Weather Seal on one or both of the doors, allowing rain water to come in. Inspect very carefully these Weather Seals, especially on the top front portion of the rear door.
To help you locate these after a hard rain:
Take the trim panels off the "A: and "B" Pillars and the Roof Line above both Doors. Check for wetness underneath the trim. Or take these trim panels off, and place folded paper towels under the trim panels; reattach the trim panels and wait until it rains. Afterwhich, take these trim panel off and check the paper towels for wetness.
The Windshield Seal is easily inspected for cracks and tears.
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Feb 12, 2010 | 2005 Chevrolet Colorado
The sides of my freezer are very hot while the top, front and back are cool to the touch. The freezer still is freezing items fine.
In the newer freezers and refrigerators they are mounting the condenser coil in the side panels of the freezer or refrigerator eliminating the large usually black frame work of tubing that used to be mounted on the back. This saves room but causes the sides to be warm as the heat is now dissipated by the side panels. You should have about an inch of clearance on both sides to let air flow over the side panels to cool them. I have a newer side by side and it also is feels quite warm when you put your hand on the side.
Oct 07, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I own a Faema E92/A Elite and it is leaking water right at the hot water wand. How do I take it apart to repair it
Remove the top panel, there might be 8 screws holding it on to the machine, then loosen the screws holding the plastic front panels from bottom and remove the clip in the back, you might have to bend the side panels out to remove front panels.
Aug 25, 2009 | Coffee Makers & Espresso Machines
The outside middle front & left hand side of the fridge were hot
The reason you feel heat by the middle of the door is because of the "mullion heater' or anti-sweat.
Check the temperature of the freezer, must be below 12*F for the ice maker to work.
Apr 23, 2009 | Kenmore Refrigerators
Hello: I have an old electrical box with the old style Zinsco beakers. For some reason, the left side of the main 200 amp breaker continues to go out. only one side. the breaker arks right where I screw...
The screw is loose. It is always HOT (has electricity going to it) so be careful. If you feel confident, cover a screwdriver with a few layers of electrical tape and tighten it. Depending on how long it has been arcing, the breaker will need to be replaced. Since the incoming wire will have power to it, have a licensed electrician do the job. He will possibly remove the meter head to cut the power while he does the work.
Jan 03, 2009 | General Electric 100Amp 3-pole circuit...
Sky Box by Maytag panels
515-707-3551 $25 each plus shipping for 3 panel sets $15 each plus shipping For Single Skybox by Maytag -Assorted Teams & sports (Three Panels Total) (some are just the front panel) Shipping is $10
These Panels Are New In The Box, Opened For Photo.
Interchangeable Front and Side Sports Panels for Skybox personal vendor.
Panels fit seamlessly on the front and sides of Skybox; front is backlit by the unit.
Panels Can Also Be Used As Wall Decorations Or Anything You See Fit To Use Them For.
Change out sports panels for the season with ease, whether college or professional.
Constructed of durable polystrylene with vibrant full color sports logo art.
One panel measures 20 inches by 16.5 inches(front); Two panels measures 15.5 inches by 30.6 inches.
Pictures available upon request
Feb 09, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
197 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
