Spin speed selector swith does not work. I need a part number to find a replacement.
  • blc3 Jun 26, 2009
    My washer is Hotpoint Model WLW4700BALWH, Serial No. TH918617H. The spin speed selector for this machine is no longer sold by Hotpoint, so when you give me the part number, please give me suggestions for where I might purchase it.
  • blc3 Jun 29, 2009
    Very helpful
  • 334 Answers
I found the part number, still trying to locate the part. I did not call this number if you want to give it a try
seth
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230304
Posted on Jun 26, 2009
  • seth veloso Jun 26, 2009
    Ok I found you one, go to the following link to purchase the GE part number is WH12X728.
    Enjoy!!
    seth
    http://www.partstore.com/Part/General%20...
  • seth veloso Jun 27, 2009
    Hey, I haven't heard from ya, hope you are good to go now, let me know if there is anything else I can do for you
    seth
    Genius:
  • 1,269 Answers
Can you tell us the exact model of your unit? You can visit the website below for the part.
www.repairclinic.com
Posted on Jun 24, 2009
Fan does not run on high speed .
dear sir
if you how know to read a electric tester then check you air con,s selector switch please find out the fan motor wire in selector switch and test one by one and turn to fan on high speed mode and check on selector switch there electric supply comes on selector switch if it,s come and motor doesn't work then it,s mean motor high speed is defective if supply not come on selector switch then it,s mean selector swith is faulty .
if you can check like this then do if not then contact to a technician,
thank you
hope answer the question
please vote1
Sep 30, 2010 | Maytag Heating & Cooling
Wash cycle won't start after the tub fills up with water.
There's no delicate or regular spin or agitation If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | Washing Machines
GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Starts and stops immediately
Selector switch
Clutch assembly
Drive motor
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 03, 2009 | Washing Machines
Only have fifth gear and second in reverse on my 54 pd thrust motor guide
my trolling motor has same problem, I replaced the (5) speed selector swith on the foot control and that solved nothing. I have the side selector switch (3 postiion) on order after testing with a meter
Apr 19, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Machine stopping mid-cycle
Selector switch
Clutch assembly
Drive motor
Mar 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Faulty AC swith vw polo 2005
Hi Bronkhhl ? Sounds like your heater motor resistor ir wiring is faulty . Regarsd VW Audi tech
Jan 06, 2009 | 2001 Volkswagen Beetle
GE washer model WNSR3120
Selector switch
Clutch assembly
Drive motor
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 21, 2008 | GE Washing Machines
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
