After repairing the pipeline it's inevitable that some debris/stones/cement etc. would find it's way into your machine. Even though there is (or should be) a filter in the water input hose, I'd guess that the water pressure was so high that some debris damaged the electrically operated solenoid valve which controls the water input flow. A mechanical problem then, with possibly some associated electrical fault. If you can get the machine out, I suggest unscrewing the inlet hose and having a look at the valve - they're usually easy to get to. But please DISCONNECT THE ELECTRICAL SUPPLY AND WATER first.
SOURCE: aeg 72630 update will not rinse during rinse cycle
if is an asko remove the top panel and check the triple valve for a faulty solenoid,also remove paddle from inside the drum with a screwdriver in the middle hole and pull toward you,and look inside the black sump hose to see if theres a plastic ball in the hose if so you need to remove it take of front panel/s to get access to the hose.also check for coins in the hoses acting like a valve.let me know and i will think of somthing else
SOURCE: my asko regardless of selected wash program stops
When
your rinse cycle does not work it is your outlet filter that is clogged. If this
is a front loader the small door is in the bottom front side of machine. Be
prepared for some water to come out when u open the door. Unscrew and clean out
filter and refit.
Also please note with the Asko there are several possible things that can interupt the cycle
either during wash or drain/spin. Have you checked the pump insert/button trap
for debris or obstruction of any kind ? ( below main door to the left ) Are you
using "he" ( lo-sudsing ) detergent ? Does the machine provide any error code,
i.e. If it's a mechanical timer model does it stop at "C" or "S" or if
electronic a symbol in the display ? Will it complete a cycle without any items
in the basket ( empty ) ? Will the unit rotate in both directions and will it
spin if you try both parts of that specific cycle ? This will help determine if
the problem is with the drive motor brushes.
