Question about Panasonic Fan FV-05VFL2 WhisperFit-Lite Low Profile Ventilation Fan Light - Fan/Light/Nigh...
I have installed a Panasonic Fan / Light combo. Whenever I attach the 4 inch flex tube to the exhaust port of the unit, it makes a slight rattling noise that my customer says she can't live with. I have supported the flex tube and ensured that the port is tight. I have duct taped the snot out of this thing and still cannot stop the rattle. The unit is secure in the framing and the rattling goes away when I disconnect the flex tube. Any thoughts? Oh, I replaced the first fan thinking it was the fan but the replacement fan does it also. Thanks, Mike
  • Michael Henry Jun 24, 2009
    Again, I do't think its the tube. Another fan installed the same way in another bathroom is fine.
    Yes. I will try the recommended corrections. Even if they don't work, I appreciate the professional response.
  • 520 Answers
I've been doing HVAC commercially now for about two years and i run into this problem often. Check the flex for small tears. They tend to make this sound. Then if that's not it try using a piece of ridged pipe about 2 feet to start the run and put an elbow in it. This way the air is not blowing straight into the flex and it usually takes care of the noise. You may want to check the plastic cover anchors also they rattle sometimes too. Hope this helps. Please accept this solution if you feel that I have helped. Good luck.
Posted on Jun 24, 2009
  • 3,230 Answers
What kind of tube u r using.... There are some flax tubes are coming in market whay dont you use tham.
Thanks
Fedders gas furnace exhaust fan comes on but will not ignite
The induced draft motor you describe has a pressure switch proves the induced draft motor is running, it is about 4 inches across and silver and flat and round, it has 2 wires and a tube that atttaches to the induced draft assembly onto a barbed port, this barbed port will obstruct with carbon and needs to be cleared annually with a tiny dril bit or similar device.
Jan 24, 2014 | Fedders Heating & Cooling
I need to know how to remove the torque converter in the transmission of a 2005 Mercury Mariner
The torque convertor is the part between the engine and the transmission. It is bolted to the "flex plate", or flywheel. You have to remove the engine or the transmission to gain access to it.
Remove or disconnect the following:
Battery cables Battery and tray Breather tube Mass Air Flow (MAF) sensor Intake tube and air cleaner cover Air cleaner assembly Transmission Range (TR) sensor Heated Oxygen (H0 2 S) sensors Transmission harness connector and bracket Wire harness bracket spacer and move the bracket aside Shift cable Shift cable bracket and move the bracket aside Starter electrical connectors Starter Electrical connectors from the valve cover and install an engine support bar Upper transmission retaining bolts Left side upper transmission mounting plate Rear transmission mount Right side engine mount bolt and slightly raise the engine Both front wheels and splash shields Right side halfshaft and intermediate shaft assembly after matchmarking them Cross brace Center exhaust pipe and rubber hanger Front exhaust pipe and flange Rear exhaust pipe flange Driveshaft PTU vent tube Lower transmission bracket Access cover Flexplate nuts Output Shaft Speed (OSS) sensor Turbine Shaft Speed (TSS) sensor Fluid cooler tube and move it aside Fluid cooler line and install a transmission jack Bolts from the PTU unit Transmission with the PTU unit attached
Jun 10, 2011 | Mercury Mariner Cars & Trucks
Broken flex joint on exhaust
it would be the front pipe you can buy new at about 200-300 hundred or go to auto parts and ask for a flex tube they have 3 or 4 different sizes from 1 and a half inch to 2 and three quarters of inch it should costs 40 to 60 dollars and if you can weld with a mig welder you cut the pipe as close to the flex or weld as possible then install the new part and weld it or if you cant weld and no money is loose buy muffler clamps and tighten them on the pipe new part or find one in scrap yard that is better if theres a problem ask me i have done many
Jan 06, 2011 | 2002 Hyundai Accent
How to remove the heater blower fan on 92 chevy 1500
Heater Core - REMOVAL & INSTALLATION
1991-92 R/V and 1991-98 C/K Series
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
  3. Remove the instrument panel glove compartment.
  4. Tag and unplug all electrical leads as necessary.
  5. Remove the center air distribution duct from the floor.
  6. If necessary, remove the ECM and mounting tray.
  7. Remove the hinge pillar trim panels.
  8. Remove the blower motor cover and then remove the motor.
  9. Remove the steering wheel and tilt back the instrument panel slightly.
  10. Remove the coolant overflow tank. Disengage the heater hoses at the core connections.
  11. Unfasten the attaching screws and nut and then remove the heater case.
  12. Remove the seven screws and lift off the heater case cover.
  13. Remove the fasteners and brackets that hold the heater core to the case and lift the core from the case.
To install:
  1. Install the heater core in the case.
  2. Install the heater case bottom plate. Make sure there is a good seal.
  3. Install the heater case into the truck. Tighten the 4 lower screws to 17 inch lbs. (2 Nm); the upper screw to 97 inch lbs. (11 Nm); and the nuts to 25 inch lbs. (2.8 Nm).
  4. Connect the heater hoses at the core tubes.
  5. Install the coolant overflow tank.
  6. Install the instrument panel and the steering wheel.
  7. Install the blower motor and cover.
  8. Install the trim panels and if removed, the ECM. Install the air distribution duct and reconnect all electrical leads.
  9. Install the glove compartment. Fill the cooling system and connect the battery cable.
Blower Motor - REMOVAL & INSTALLATION
1992-98 Models
(see Figure 4)
  2. Remove the right rear quarter panel trim.
  3. Disconnect the electrical lead at the fan.
  4. Remove the screws and if equipped, the cooling tube.
  5. If necessary, remove the fan retaining nut and lift out the blower fan.
  6. Remove the blower motor.
To install:
  1. Install the blower motor and then position the fan.
  2. Install the retaining nut and then tighten the mounting screws to 12 inch lbs. (2 Nm).
  3. If removed, install the cooling tube.
  4. Connect the electrical lead. Install the quarter panel trim cover.
  5. Connect the battery cable.
Fig. 4: Auxiliary heating and A/C system
Hope this helps (remember to rate this answer).
Nov 09, 2010 | 1992 Chevrolet C1500
How do you replace the steering rack on my 2001 Ford Windstar??
YOU HAVE TO SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS.MAKE SURE YOU HAVE VECHICLE PARKED ON LEVEL SOLID GROUND.ONCE VECHICLE RAISED.REMOVE FRONT WHEELS.REMOVE TIE RODS END COTTER PINS AND CASTLE NUTS.REMOVE TIE ROD ENDS FROM THE KNUCKLES.REMOVE FRONT STABILIZER BAR.POSITION THE DASH OPENING WEATHER SEAL FOR THE STEERING COLUMN OUT OF THE WAY.REMOVE OR DISCONNECT THE FOLLOWING.REMOVE PINCH BOLT RETAINING THE STEERING COLUMN INTERMEDIATE SHAFT COUPLING.REMOVE STEERING GEAR RETAINING NUTS BOLTS.REMOVE REAR SUBFRAME BOLTS.USE WIRE TO SUPPORT EXHAUST COMPONENTS UNLESS YOU ARE REMOVING THEM COMPLETELY.SUPPORT THE EXHAUST SYSTEM FLEX TUBE AND REMOVE THE FLEX TUBE TO DUAL CONVERTER Y PIPE ATTACHMENT.LOWER THE VECHICLE SLIGHTLY UNTIL THE REAR SUBFRAME SEPARATES FROM THE BODY APPROXIMATELY 4 INCHES.REMOVE THE HEAT SHIELD BAND AND FOLD THE HEAT SHIELD DOWN.ROTATE THE RACK AND PINION ASSEMBLY TO CLEAR THE BOLTS FROM THE FRONT SUBFRAME AND PULL TOWARD THE DRIVERS SIDE OF THE VECHICLE.PLACE A DRAIN PAN UNDER THE VECHICLE AND DISCONNECT THE POWER STEERING LINES.REMOVE THE RACK AND PINION ASSEMBLY THROUGH THE DRIVERS SIDE OF THE VECHICLE***** TO INSTALL ****** INSTALL NEW TEFLON O - RINGS ON THE POWER STEERING LINE FITTINGS. PLACE THE RACK AND PINION RETAINING BOLTS IN THE GEAR HOUSING.INSTALL RACK AND PINION ASSEMBLY THROUGH THE DRIVERS SIDE OF THE VECHICLE.INSTALL POWER STEERING LINES ON THE RACK AND PINION ASSEMBLY. INSTALL RACK AND PINION ASSEMBLY ON THE SUBFRAME.INSTALL ******** HEAT SHIELD.INSTALL TIE ROD ENDS TO THE KNUCKLES TIGHTEN THE CASTLE NUTS AND INSTALL THE COTTER PINS.INSTALL STABILIZER BAR.INSTALL RACK AND PINION ASSEMBLY RETAINING BOLTS.TORQUE THEM TO 85 - 99 FT LBS. RAISE VECHICLE UNTIL SUBFRAME CONTACTS THE BODY.INSTALL REAR SUBFRAME RETAINING BOLTS TORQUE THEM TO 83 - 112 FT LBS.INSTALL EXHAUST SYSTEM FLEX TUBE TO DUAL CONVERTER Y PIPE.INSTALL FRONT WHEELS.INSTALL A NEW PINCH BOLT IN THE STEERING COLUMN INTERMEDIATE SHAFT COUPLING ON THE RACK INPUT SHAFT TORQUE PINCH BOLT TO 25 - 33 FT LBS.POSITION THE STEERING COLUMN OPENING WEATHER SEAL OVER THE STEERING GEAR HOUSING.LOWER THE VECHICLE FILL THE POWER STEERING FLUID RESERVOIR. START THE VECHICLE AND CHECK FOR LEAKS. CHECK FOR PROPER WHEEL ALIGNMENT AND STEERING WHEEL POSITION.BLEED POWER STEERING SYSTEM.
Oct 14, 2010 | 2001 Ford Windstar
Installing Broan exhaust fan/light/night light model QTR070L. Am connecting with a single switch power source. Fixture has three whites, one blue, one black, one red and the ground (green). In what color...
Hi .. with only bone switch for this combo unit, the connections would be like this .. all ahites together with the romex white , all colors, red, black, blue with the romex black, all greens together IF you had more than one switch , then the red, black, blue would be connected separately to one switch eack and separately to a 4 wire romex from the switch to the combo unit.
Apr 17, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
My 2005 Corolla XRS has rattling when deaccelerating
I wouldn't say it is common. There are quite a few heat shields around the stock exhaust "header" and exhaust system. There are also FOUR motor mounts that you can check to see if all bolts are tight. They are all 14mm heads on the motor mounts, 12mm on the exhaust shields. These seem to be the main things that may get loose or make a rattling sound. The exhaust gasket is also designed to flex when the engine flexes - I would check into the exhaust. You have to remove the TRD strut bar to gain better access from above.
Aug 13, 2009 | 2005 Toyota Corolla
Panasonic Whisper Warm Installation
The vent fan must be exhausted into the outside air via a 4 inch flex duct, this may be difficult if installed in the wall!
Feb 20, 2009 | Panasonic WhisperWarm FV-11VHL1 Compact...
05 susuki forenza
Removal Procedure
2. Drain the engine oil from the engine crankcase.
3. Remove the exhaust flex pipe retaining nuts from
the exhaust manifold.
4. Remove the exhaust flex pipe retaining nuts from
the catalytic converter or the connecting pipe.
5. Remove the exhaust flex pipe.
6. Remove the oil pan flange–to–transaxle retaining
bolts.
7. Remove the oil pan retaining bolts.
8. Remove the oil pan from the engine block.
Cleaning Procedure
1. Clean the oil pan sealing surface.
2. Clean the engine block sealing surface.
3. Clean the oil pan retaining bolts.
4. Clean the oil pan attaching bolt holes in the engine
block.
5. Clean the oil pan scraper.
Installation Procedure
1. Coat the new oil pan gasket with sealant.
Important : Install the oil pan within 5 minutes after applying
the liquid gasket to the oil pan.
2. Install the oil pan to the engine block.
3. Install the oil pan retaining bolts.
Tighten
Tighten the oil pan retaining bolts to 10 NSm (89 lb–in).
4. Install the oil pan flange–to–transaxle retaining
bolts.
Tighten
Tighten the oil pan flange–to–transaxle bolts to 40
NSm (30 lb–ft).
5. Install the exhaust flex pipe.
6. Install the exhaust flex pipe retaining nuts to the
exhaust manifold.
Tighten
Tighten the exhaust flex pipe–to–exhaust manifold
retaining nuts to 35 NSm (26 lb–ft).
7. Install the exhaust flex pipe retaining nuts to the
Tighten
Tighten the exhaust flex pipe–to–catalytic converter
or connecting pipe retaining nuts to 35 NSm (26 lb–ft).
8. Connect the negative battery cable.
9. Install the oil pan drain plug.
Tighten
Tighten the oil pan drain plug to 35 NSm (26 lb–ft).
10. Refill the engine crankcase with engine oil.
Jun 14, 2008 | 2005 Suzuki Forenza
Panasonic Fan FV-05VFL2 WhisperFit-Lite Low Profile Ventilation Fan Light - Fan/Light/Nigh... Logo
96 people viewed this question
Top Panasonic Dryers Experts
Craig Butler
Craig Butler
michael vanier
Are you a Panasonic Dryer Expert? Answer questions, earn points and help others
