Back to:
Tags:
Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Cracked glass on front glass
posted by bushmb on Nov 05, 2007
I was given a brand new 50 inch Panasonic plasama television due to a small crack @2 inches on the front glass. Is this television fixable or should I ge rid of it. Remember it was free so if a repair is possible I will still be ahead.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 07, 2007
Helpful (85)
tvtechnician
Rank:Guru Guru
Rating: 88%, 92 votes
if the tv turn on this will tell you that the plasma panel itself is ok. if it is ok then the fron glass is replacable. this is just a standard piece of glass so i really wouldnt spend tons of money hiring someone else to order one and install it.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Cracked glass on front glass:
I don't want to Accept this solution
Can you Help with these Flat Panel Televisions problems?
iLO -3200 32 in. LCD Television
picture cuts out after a few mins if i let it cool for 5...
picture stays on for 5 mins then turns off, i have checked...
Short of muting the tv or turning off the speakers, I have...
iLO V27DMBX Television
how to turn it on
Akai PDP4225M 42 in. Plasma Television
color in our akai HD seems saturated w/dark and red...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
